Safe ambient air temperature
Discussion in '3rd Gen. Tacomas (2016-2023)' started by codemancer, Jul 7, 2020.
  1. Jul 10, 2020 at 3:07 PM
    Tonche
    Tonche Well-Known Member
    Tony
    2018 Tacoma TRD OR ACLB
    I have had my truck sitting and idling for hours before to use the bed outlet to run a rotary hammer for work. Middle of the day in DT Los Angeles. It was pretty warm, high 90s. Didn't have any issues.
  2. Jul 10, 2020 at 3:09 PM
    codemancer
    codemancer [OP] Well-Known Member
    Northern Utah
    2020 Tacoma OR DCSB Voodoo Blue
    KDMAX Pro, RCI sliders and skids, CBI overland bars, 255/85R16 Geolandars, Bestop Supertop 2, ARB Drawers, Uptop Bravo rack
    Thanks for the responses. I think I'm convinced it isn't going to be an issue. I just was bothered by the fact that the alarm kept going off on the UG. Made me a bit nervous :)
  3. Jul 10, 2020 at 6:03 PM
    synaps3
    synaps3 Wag more bark less
    Dave
    Los Alamos, NM
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
    Don't be bothered by the alarm for 4k+ RPM sustained when towing or in the mountains too. That one blips all... the... time... when I'm towing. You have to rev up the motor in the 3rd gen to get power, so don't be worried about that one either, and just send it with that skinny pedal. The engine's up to the task.
    One more, I'm in Atlanta, so my Ultragauge also alarms in midsummer from heat if I park in the sun. That temp alarm is from the actual temperature of the UG itself. It hasn't melted yet, and I've had my UG for 6 years. When it's REALLY hot, the gauge will light up and be almost fully backlight - you'll barely be able to see the screen. I've only had that happen a few times during heat waves.
    My only gripe with the UG is that you can't update the firmware. Mine's old enough that it won't read transmission temps on the Taco, and that is the main thing I wish it did with how much I tow. I've halved my interval for trans fluid changes because of how nasty my fluid was at the 30k change. I'm not sure if the nastiness was from offroading - the auto trans - specifically the torque converter - works really hard offroad in 4lo, or if the nastiness was from all the towing I do. Either way, having insight on those temperatures is good, so I'd watch those more instead of your MPG since the MPG is in the middle of your gauge cluster.
  4. Jul 10, 2020 at 6:32 PM
    codemancer
    Northern Utah
    Yeah transmission pan and TC temps are pretty much the main reason I got the UG! Thanks for the tips!
    synaps3[QUOTED] likes this.
  5. Jul 10, 2020 at 6:43 PM
    ICU1
    ICU1 Well-Known Member
    OP lost me at MX
  6. Jul 10, 2020 at 7:05 PM
    codemancer
    Northern Utah
    What do you mean? The MX variant is the programmable one.
    synaps3 likes this.
  7. Jul 11, 2020 at 8:37 PM
    STi and Taco
    STi and Taco Not a Super Hero
    Steven
    Georgia
    '16 Tacoma SR 4x4 Access Cab Black, 2012 Subaru STi Hatchback Black, 1995 Acura Legend L Gold (RIP), 2020 Corolla Hatchback
    Diode Dynamics LED Inerior Lighting https://www.diodedynamics.com/by-vehicle.html?no_cache=1&find=2016-toyota-tacoma-115242 Hella Supertone Horns Some Joe Schmuckitelli Keyless Entry Intermittent Wiper Mod - Thanks to @moe2o4 Cruise Control Mod - Thanks to @moe2o4, again Anytime Back-up and Front Mount Camera Mod - Courtesy of @Logistics91 (amazing customer service helping me get it just the way I wanted it set up) Drawtite Class IV trailer hitch with 7/4 pin connector and P3 Tekonsha Brake Controller RokBlokz Mud Flaps Access Cab Rear Seat Storage Mod - Thanks to @Cagedodger for the original idea. Just modified it to fit my needs. https://www.tacomaworld.com/threads/access-cab-storage-organization.453774/page-4#post-17877877 Method 701 Black Wheels 265-70r17 Nitto Ridge Grapplers Fumoto Drain Valve Weather Tech Floor Liners and Side Window Deflecors Tuxedo TruXport Bed Cover Access Cover Motion LED Light Strip. Mounted 2 in the bed. Air Dam Delete Demello Off-Road Overlander Aluminum Winch Bumper with Baja Hoop and Squadron Sport LED Spots Warn M8000 Winch Silex center console organizer and tray Full Bed and Under Hood LED Lighting A/C Condensation Drain Relocation Rostra Front Heated Seats aFe Power 51-82722 Magnum FORCE Stage-2 Si Pro DRY S Cold Air Intake System (Part #51-82722) Prolightz clear LED fog lights w/ lamin-x overlay Red line Hood struts Diode Dynamics Hi/Low beam HID conversion kit MesoJDM 4 switch cubby panel, 7 switch Center panel and Center console Coin Holder @mesojdm Carhart Gray Front Seat Covers Curtis Class IV receiver B&W Tri-ball hitch King 2.5 Front Coilover/Rear Shock 25001-119/25001-121 Coming Soon: Differential Breather Relocation Mod New tires, can't decide
    Just toss the gauge. It will drive you nuts and youll spend more time staring at it than the road and end up wadding up your truck. Its a Toyota truck. The 4 and 6cyl are about as close to bulletproof as youre going to get.
    Just drive the damn thing and keep eyes on the road.
    Chew likes this.
  8. Jul 11, 2020 at 8:39 PM
    STi and Taco
    Steven
    Georgia
    Also, Tacomas arent high performance engines. Intake air temp is basically a pointless metric.
  9. Jul 11, 2020 at 8:58 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Finally someone with some common sense. Drive the damn truck!!
    Chew likes this.
  10. Jul 11, 2020 at 9:03 PM
    codemancer
    Northern Utah
    I think you guys are blowing this out of proportion. I wanted to understand why the alarm was triggered: whether it was the UG being wrong or whether I had a potential issue. Neither is a big deal. I don’t stare at the thing while I drive. I bought it solely to monitor transmission temps off road. That is not something you can monitor without a scanner tool and is something that you absolutely should monitor when you’re pushing the vehicle.
  11. Jul 11, 2020 at 9:21 PM
    STi and Taco
    Steven
    Georgia
    99.9% of Tacoma owners who even take the truck offroad dont push it hard enough to ever worry about trans temps.
    Chew likes this.
  12. Jul 11, 2020 at 10:48 PM
    codemancer
    Northern Utah
    No harm in monitoring to be safe...
  13. Jul 11, 2020 at 10:59 PM
    FrayAdjacent
    FrayAdjacent Well-Known Member
    Matthew
    Austin, TX
    2017 Tacoma SR5 4x4
    The only time I worried about it was when I was towing a camper. I used the Torque app and an OBDII thingie. The temperatures occasionally spiked but quickly dropped. Once I saw how it behaved, I really just stopped worrying about it.
    Chew likes this.
