Safe engine RPM
Discussion in '4 Cylinder' started by vl1500lc, Oct 14, 2016.
  1. Oct 14, 2016 at 8:22 AM
    vl1500lc
    vl1500lc [OP] New Member
    Bob
    Aurora In
    Sr5 black stock
    I will be Towing a 6x10 trailer with a Goldwing trike on it. I have an 02 SR5 preruner double cab. I will stay out of overdrive, & that puts my RPM at 60 MPH at 3000. Can the engine withstand a constant RPM of 3200. That would allow me to run 70 MPH. I will be going about 600 miles.
    Thanks for all replies.
  2. Oct 15, 2016 at 12:00 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Probably be okay, how much is the total weight of the load?
  3. Oct 15, 2016 at 12:05 PM
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    Being that it's only half of the total RPM limitations of the engine I would say yes.
    Gas mileage is obviously going to suffer and I wouldn't push the engine in short burst. Rather allow it to get to 3200 and then sustain.
    Toyko Joe and DustStorm4x4 like this.
  4. Oct 15, 2016 at 12:10 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Slow down a bit and run at 60, your wallet will thank you. However, 3200 RPM isn't going to kill your engine though it will work your idler pulley bearings and ancillaries a bit harder then normal.
    Toyko Joe likes this.
  5. Oct 16, 2016 at 9:32 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    From other posts on this thread that I have read you're engine won't be bothered at all by that. There have been those here that have run theirs at much higher rpm for longer. As a matter of fact I did a 1300 mile round trip in mine a few months ago and was running 75 or 80 mph the whole time which is right at 3000 for 80 mph and I never noticed anything change. I had over 700 lbs in the bed as well. My fuel mileage even stayed right where it normally is. Around 20 mpg.
    DustStorm4x4 likes this.
  6. Oct 17, 2016 at 6:33 AM
    tgear.shead
    tgear.shead Well-Known Member
    DO NOT keep it out of overdrive, unless it "hunts" between gears. If it stays happily in overdrive, LET IT. If you get into any spot where it starts shifting frequently in and out of overdrive, THEN downshift, and only for the duration of the problem, then let it have overdrive again.
  7. Oct 20, 2016 at 3:22 PM
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    What this guy says. Only lock it out of overdrive when and if it's hunting for gears.
    DGXR and DustStorm4x4 like this.
  8. Oct 21, 2016 at 6:21 AM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    In years past I've ran high RPM for extended periods of time. Over an hour at 3800 RPM with occasional bursts of throttle pushing past 4500 RPM and 4200 RPM for 30 minutes constant. Keep an eye on temp, vacuum and oil pressure. Granted all that could contribute to my oil consumption but the engine is still alive.
    uwu likes this.
  9. Oct 21, 2016 at 6:24 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Keep the overdrive on. Like said above, if it starts gear hunting, then turn it off. I used to tow a 17' bass boat with a 99 Prerunner v6. On the highway I kept overdrive on
  10. Oct 21, 2016 at 6:50 AM
    2.7taco
    Texas
    Depending on the transmission programming overdrive is negligible as long as the converter clutch is locked everything is fine. Not sure if the 02 transmission locks the converter when overdrive is disengaged. Now because your a prerunner I wouldn't worry too much. The the final drive ratio is pretty high and that small trailer should haul fairly well with or without overdrive. Have a safe trip.
  11. Oct 21, 2016 at 7:00 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    And switch out the rear diff oil to synthetic
  12. Oct 21, 2016 at 7:04 AM
    2.7taco
    Texas
  13. Oct 21, 2016 at 11:37 AM
    smmarine
    Melbourne FL
    A340E trans does lock the torque converter in overdrive but it also locks it with OD off. OD in that trans is the 4th gear, so with it off it'll lock the converter in 3rd gear
    Ritchie and 2.7taco[QUOTED] like this.
  14. Oct 22, 2016 at 7:49 PM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Giver till she hits fuel cut!!!!
    Warning the preceeding advice may have been given after many beers
    Hartford, 2.7taco and uwu like this.
  15. Oct 24, 2016 at 1:41 PM
    tgear.shead
    ... and yet you were sober enough to remember to include the disclaimer ;)
  16. Oct 24, 2016 at 8:01 PM
    TYetti
    Mat
    I had moments of clarity after the football game lol
  17. Oct 25, 2016 at 8:47 AM
    uwu
    uwu Well-Known Member
    I just drove to Austin and back, 2k miles, engine at 3,000rpm 95% of the time :bananadance:
    Ritchie likes this.
  18. Oct 26, 2016 at 10:24 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I have a 2TR-FE and I wouldn't hesitate and I wouldn't hesitate with your 3RZ-FE either. Personally I believe Toyota designed these 4 bangers to withstand high RPM for extended periods of time. They see very demanding commercial use throughout the world. The 2TR-FE is rated to tow 5,500 lbs in the Hilux which we all know isn't possible without revving the shit out of it the entire time. Keep up on your oil changes.
    Hartford likes this.
  19. Oct 26, 2016 at 3:57 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    ... this depends on several things.
    1. Is the truck equipped with the OEM tow package
    2. Is truck equipped with the ECT button
    3. Current gear ratio
    I say this because the A340E & F trans do not like excessive heat, nor does the converter. I smoked both is how I know.
    If the tow package is there and gear ratio is proper, leave in OD, manually disengaging when needed.
    Turn off the ECT button so you won't have the later shifts at higher RPM's putting stress on multiple components, ie: u-joints, carrier bearing etc...
    If you have 4.56's or lower (a higher number), that will be better for your trans.
    Just my .02.
    2.7taco likes this.
  20. Oct 27, 2016 at 3:31 AM
    2.7taco
    Texas
    My transmission sees 190 degrees just driving around and has been like that since I bought it. If he has the tow package his temps will be lower by 20 degrees or so.
    The converter on the A340E/F will be in lock-up in overdrive so you won't create additional heat. Dropping to 3rd manually on a 2nd gen will still lock the converter while in 3rd. I am not sure if a 1st Gen truck will do the exact same when you disengage overdrive.
    He should be fine running down the road at 3000 RPM.
    Ritchie[QUOTED] likes this.
