Safe PSI to air down to?
Discussion in 'Off-Roading & Trails' started by Madjik_Man, May 2, 2012.
  1. May 2, 2012 at 1:41 PM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    i have reseated tires like that several times
  2. May 2, 2012 at 2:19 PM
    winL
    winL Well-Known Member
    Bay Area, CA
    PreRunner
    Leer 100R Cap, OEM Hood Protector, Bilstein 5100's @0, Wheeler's 3leaf AAL no TSB, Replaced oem OL, OME 885, Pioneer AVIC-D2
    So, just to clarify for my own safety's sake. Valve Core in, or out?
  3. May 2, 2012 at 2:21 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    12 psi here!
  4. May 2, 2012 at 2:47 PM
    la0d0g
    running for the hills
    For crawling not hauling
    I've always seen starter fluid used but I think most flammable aerosols would do the trick. Others, chime in if I'm wrong.
  5. May 2, 2012 at 5:04 PM
    FailRated
    FailRated RTO
    Evan
    Maryland
    03 Double Cab TRD
    5100's w/ Eibachs, Front sway bar in trash mod, Diff drop, 265/75-16 Duratracs or 33x10.50 KM2's on 15x8 wheelers steels, ARB front bumper, Warn VR8000 winch, Trailgear sliders, Allpro rear bumper, Sky Offroad E-Locker guard, Sky Offroad weld on differential guard, Savage skid plates w/ Budbuilt cross member, e-locker rear, ARB air locker front, 4.56 gears, bought it from my mom who bought it new :-D
    I've done it many times. Always left the core in. When I checked the pressure after the bead seated it was always very low. Not sure how the tire would blow up:confused: Once the bead seats the fire in the tire will go out.
    I've always used carb and choke cleaner and on a car/truck tire, a 3-4 second spray is enough.
  6. May 2, 2012 at 5:28 PM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    Thanks for all the replies, everyone.
    I'm glad I started this thread, I learned a lot (the norm at TW)
  7. May 2, 2012 at 5:36 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    This works wonders. Years ago I ordered rear tires for my quad out of a magazine. They banded the things together for shipping. :rolleyes: The beads were bent all to hell and NOBODY, tire shops or anyone I tried could get them to seat. So me and my friend discussed trying it. We were skeered. :eek: His father which had done it several times on his low boy tires did it for us on the first one and it worked on the 1st try. So we did the 2nd one all though it took a couple of tries for us. Point of the story was that I didn't believe it would work and that I would have to ship them back.
  8. May 2, 2012 at 5:39 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    I ran 6psi last time out but feel that 12-14psi on rocks is best in my km2's. This varies from tire to tire and load range also alloy wheels are less likely to pop a bead then steel wheels
  9. May 2, 2012 at 7:28 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    No bead locks I go like this: 14-18 on grippy earth(dirt/rocks). 12 in deep snow.
  10. May 2, 2012 at 8:02 PM
    winL
    Bay Area, CA
    PreRunner
    Sweet. Even gave me a tip on how long to not over spray it. Thanks man.
  11. May 2, 2012 at 8:15 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I carry a can of ether for just that reason. I've also used acetylene on a tractor tire.
    I'll pull the core. Not worried about blowing up the tire but blowing out the damn valve stem. You only need a quick burst of ether.
    Doesn't take much seriously.
    If you do have a compressor, a ratchet strap around the center of the tire can help seat the bead.
  12. May 2, 2012 at 8:43 PM
    FailRated
    FailRated RTO
    Evan
    Maryland
    03 Double Cab TRD
    I just picked up some parts from my buddy who is a Master tech at a toyota dealership. We were discussing this topic and he told me when he mounted 98regstick's 285's the tires beads were so close together from storage/shipping he could not get the beads to seat. So he pulled out the ether. Had to use this method on all 4 tires. Two worked fine, the other two had something strange happen. He said the bead seated with the ether, then moments later the tire would collapse and the bead would unseat. All we could come up with was that the fire in the tire consumed enough oxygen to create a vacuum and collapse the tire. So he just hooked up a compressor to the tire while doing the ether trick and problem solved. Weird.
  13. May 2, 2012 at 8:48 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I've heard of this happening with the core in. Another reason to pull it out.
  14. May 2, 2012 at 8:48 PM
    Madjik_Man
    So I guess I need to ask now...
    where do you buy ether? Home Depot? And I'm assuming it comes in a spray can?
  15. May 2, 2012 at 8:52 PM
    #35
    valon5150
    valon5150 Well-Known Member
    Steven
    redding
    01 taco turd
    all pro lift, 33s, home made sliders, bumpers, skids
    Starting fluid, never looked for it at homedepot i'd go to any auto store, or even walmart, yes in a can. Carb cleaner works well too
  16. May 2, 2012 at 8:55 PM
    #36
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    This all reminds me...
    Thanks to Terry. Re-upped the pictures.
  17. May 2, 2012 at 8:59 PM
    #37
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    2 of ?
  18. May 2, 2012 at 9:03 PM
    #38
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    FWIW I carry ether, valve stems, cores, a tool, tire spoons, patches, plugs, stitcher, reamer, and wire to stitch the carcass if need be in my kit.
  19. May 2, 2012 at 9:06 PM
    #39
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    Hey that's me! :D. haha but ya I got ballsy enough to go down to 8 PSI and it performed amazingly well and I had no problems by going this low. I will continue to go to 8 PSI on very technical trails in the future. Wheel is 16"x8" and tires are 33"x12.5" (no beadlock).
    (and for those of you following my build thread, my most recent flat while offroading was due to dirt/debri/small rocks getting pushed up into the valve stem and causing it to release air even though I had the plastic valve cap on)
  20. May 2, 2012 at 9:06 PM
    #40
    92LandCruiser
    Nevada
    Cummins, tons, 40s
