Safe to even drive to shop? snapped front axle or wheel bearings...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jhrttn1983, Dec 26, 2016.
  1. Dec 26, 2016 at 11:41 AM
    jhrttn1983
    jhrttn1983 [OP] Member
    Jon
    2009 tacoma sr5 manual 4.0 access cab
    near stock
    Started getting a rattling today in front driver side wheel, jacked it up and I have 3/4-1" of play in the wheel with lug nugs snug and no suspension play, in all directions. Is this even safe to drive to the shop 3 miles away or should I get it towed? 2009 tacoma 108k 4wd manual 4.0 v6
  2. Dec 26, 2016 at 11:47 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    If it's the wheel bearing and you can stay off major roads you can probably drive it.
  3. Dec 26, 2016 at 11:52 AM
    jhrttn1983
    Jon
    near stock
    Thoughts on what it could be besides wheel bearings? Ive got a 35mph road S turns and hills, just what I need to have a wheel flying off
  4. Dec 26, 2016 at 11:54 AM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    can you spin the wheel with it in PARK?
    Then you will know if the axle is broken.
  5. Dec 26, 2016 at 11:59 AM
    TacomaTrav
    TacomaTrav Well-Known Member
    Travis
    07' Tacoma SR5, 4.0L 6spd, ELocker
    NONE
    I bet good odds it's not a "snapped axle UHHMM CV" its a bad bearing, 3 miles should be no issue especially if you just noticed it. I drove on a violent bad DS wheel bearing for 40 mIles, because I HAD too. Just take it slow. OOOoorr, just do it yourself, it's fairly easy and there are some great writeups on here. Side bar: OP assumes all responsibility for driving on said bad bearing.;)
  6. Dec 26, 2016 at 12:00 PM
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
    Inner or outer tie rods?
  7. Dec 26, 2016 at 12:07 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    If you are gonna drive it, have another car follow you, and no more then 15-20 mph just to be safe. But, that's just my opinion...
  8. Dec 26, 2016 at 12:13 PM
    jhrttn1983
    Jon
    near stock
    had the tie rods replaced at 75k, assume that would be both inner and outer but not positive, also Ive been running FJ wheels with 255 17 17 BFG's, stock suspension
  9. Dec 26, 2016 at 12:14 PM
    jhrttn1983
    Jon
    near stock
    Appreciate the help guys!
  10. Dec 26, 2016 at 12:18 PM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    I did the Bamatoy wheel bearings on mine. Fairly easy to do, and a heck of a lot cheaper then having a shop do them! Of course, I'm a believer in the old "if one is bad, do both" school of thought.
    Pigpen likes this.
  11. Dec 26, 2016 at 12:26 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    It's really not hard to do the wheel bearings on these if you know how to swap rotors and diagnose the problem and it's already jacked up your halfway there.
  12. Dec 26, 2016 at 12:42 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    You said you have play in the wheel. Is it side to side play? As in if you sit facing the wheel with the truck jacked up and pull on the bottom of the wheel towards you it moves?
  13. Dec 26, 2016 at 12:44 PM
    jhrttn1983
    Jon
    near stock
    correct, inch of play sitting next to wheel in all directions pulling side to side (tug n pull) 12 and 6, 9 and 3, and about a 1/4" of play at the rotor
  14. Dec 26, 2016 at 12:48 PM
    jhrttn1983
    Jon
    near stock
    The wheel spins fairly easy while its jacked up, not the smoothest of feeling but not super alarming. Passenger side has no play in it side to side while jacked up. What I noticed while driving was just a rattling like the common loose brake pads issue, was checking on those and noticed it.
  15. Dec 26, 2016 at 1:02 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would advise against driving it. IF it comes loose when driving even slowly the potential for a lot more damage is too great. And to add to that a loss of control could cause a wreck and hurt yourself or others that have no say so if you drive it or not.
    Tow it or do it at home.
    jhrttn1983[OP] and 303tacoma like this.
  16. Dec 26, 2016 at 4:19 PM
    Pigpen
    Dan
    Northwest Montana
    Get the Bamatoy bearings and do it at home
    R0dzilla75 and AaronArf like this.
  17. Dec 26, 2016 at 4:24 PM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    This...shop is going to take you over the hurdles. Or buy prebuilt hubs from bama or the NJ guy and bring it to the shop to have them do the labor. save you a big chunk of labor/parts
  18. Dec 26, 2016 at 5:26 PM
    EasyLivin
    EasyLivin Well-Known Member
    Jeff
    Euless, TX
    2014 White TRD OffRoad Double Cab
    Focal PS165AC / Focal PS165V / Alpine PDR V75 / Kenwood Excelon KFC-XW1000F / Leer 100XR shell / Bilstein 5100 lift
    If you get that significant of play in all directions and significant noise on rotation, most def it is a wheel bearing. Like many said before, it's a pretty easy job. It probably won't die driving it but keep it slow and take yourself to get it fixed if you don't feel comfortable doing the repair.
  19. Dec 26, 2016 at 5:28 PM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    If you have to ask, tow it.
  20. Jan 4, 2017 at 9:02 AM
    jhrttn1983
    Jon
    near stock
    yah mechanic said I shouldnt have driven it either. Had it towed and the hub and bearing were shot. CV looked to be ok
