safe to run 90 ethanol free ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AMGTRDPRO, Sep 4, 2021.
  1. Sep 4, 2021 at 5:24 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    You’ll get better mileage and ethanol free and is better is so many ways I loose count, corn based ethanol (that we get in the US) is an absolute diabolical political fuckup that really does deserve many people being executed over. But power is something that it is actually good for, you get more power with ethanol which it why you get less gas mileage.
  2. Sep 4, 2021 at 5:27 PM
    TRDSlow
    TRDSlow Well-Known Member
    Maxwell
    2018 Tacoma SRUP
    Although I agree on your earlier points, Ethanol does not have as much energy as gasoline. It is just a fact.
    R4D4G4ST, NC_Pinz and Trail Limo like this.
  3. Sep 4, 2021 at 5:39 PM
    Trail Limo
    Trail Limo Well-Known Member
    100% true. I think a lot of people get confused by the fact that many high performance cars run alcohol. Gasoline has a higher energy density than alcohol. High performance cars run alcohol for other reasons than energy density in the fuel.
    In an engine designed to run on alcohol, it's possible to make more horsepower (at the cost of higher fuel usage) but this is only possible when the engine is specially designed to run on alcohol, not a gasoline street engine.
    AODRN and TRDSlow[QUOTED] like this.
  4. Sep 4, 2021 at 5:58 PM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    Wow! I'm not a big fan of ethanol myself, but this seems a bit over the top.
    cryptolyme likes this.
  5. Sep 4, 2021 at 6:00 PM
    Thatbassguy
    James
    I think it's due to alcohol requiring less air to burn. It's crazy how those top fuel drag cars will burn through like 8 gallons of fuel in 4 seconds! :burnrubber:
  6. Sep 4, 2021 at 6:01 PM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    Other way around chief.
  7. Sep 4, 2021 at 6:06 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    https://youtu.be/xGTbQuhhluY
  8. Sep 4, 2021 at 6:06 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    In THEORY ethanol free gas should give more power. And MAYBE a little better fuel mileage, maybe not. But in the real world you'd have to have some pretty sophisticated equipment to measure the difference. The average driver will never notice any difference except that he is paying more at the pump.
    Trail Limo likes this.
  9. Sep 4, 2021 at 6:12 PM
    Trail Limo
    It's due to the fact that you can run more boost, or higher compression before the fuel starts detonating, allowing for more power. The burn rate of the fuel is a testimony to just how much fuel and air they can cram into an engine in a short amount of time.
    Thatbassguy[QUOTED] likes this.
  10. Sep 4, 2021 at 6:13 PM
    Trail Limo
    Skydvrr[QUOTED] and Thatbassguy like this.
  11. Sep 4, 2021 at 6:36 PM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    I usually use the 87 mix at Costco. When using ethanol free 87 or 88 it gets about 30 more miles per tank.
    OEM tune at 4-5,000 feet.
  12. Sep 4, 2021 at 6:41 PM
    mutely
    I do agree with you. But It does depend on how you want to look at the equation. Ethanol has a higher octane than gas, so it’s got increased power when blended with gas. But 1 gallon so gas contains more energy that 1 gallon of ethanol.
    https://afdc.energy.gov/fuels/ethanol_benefits.html
  13. Sep 4, 2021 at 6:51 PM
    mutely
    People have been executed for less…;). The corn industry in the US is despicable, I also fundamentally disagree with lobbyists, put the two together and you get an industry that’s cost the tax payer billions, both in medial issues from high fructose corn syrup, ethanol that’s created more greenhouse issues than solved, the list goes on and on.
  14. Sep 4, 2021 at 6:54 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    I say ditch the ethanol and use pure petroleum. Better yet, fill your tank with diesel. :thumbsup:
  15. Sep 4, 2021 at 6:55 PM
    #35
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Umm. No.
    knayrb likes this.
  16. Sep 4, 2021 at 6:56 PM
    #36
    JayRolla
    Colorado Springs
    Actually ethanol free will get better gas mileage and will be no power difference.
    R4D4G4ST likes this.
  17. Sep 4, 2021 at 6:56 PM
    #37
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    it's just better fuel. No need burn food. Eat the corn. Don't burn it.
    This thread has potential.:boink:
    Skydvrr likes this.
  18. Sep 4, 2021 at 7:01 PM
    #38
    JayRolla
    Colorado Springs
    You don't get less gas mileage because it makes more power. It's because stoich for gas is 14.7 and stoich for e85 is 9.7. Roughly need 30% more e85 to make the same lambda value as gas.
    R4D4G4ST and Trail Limo like this.
  19. Sep 4, 2021 at 7:04 PM
    #39
    JayRolla
    Colorado Springs
    That's why you tune and add more fuel. Just swapping to e85 gives an n/a motor 10-15whp and tq across entire rpm band. If boosted you can add timing and boost to make 150+whp on almost any application. It's better than some race fuels due to its 105 octane and amazing cooling properties.
  20. Sep 4, 2021 at 7:41 PM
    #40
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Just tag @tonered and mention the word ethanol! We'll get this dumpster big enough for steaks n dogs.
    9th[QUOTED] likes this.
