Safe to tow 2600lb trailer without brakes?
Discussion in 'Towing' started by Tibouchina, Aug 4, 2017.
  1. Aug 11, 2017 at 6:21 AM
    Cnasianfire
    Cnasianfire Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    I am not sure I understand what you meant by this.
  2. Aug 11, 2017 at 6:28 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    I am assuming, since I don't live in NC, that if it's a dump, landscape or equipment trailer that it can be 4000lbs without any auxillary brakes, but if it's a mobile home it needs brakes if it's over 1000lbs. My question is what is the definition of a mobile home? Do they consider a 3000lb Jayco travel trailer a mobile home? Or do they only mean what is typically found in trailer parks, like single and double wides?
    Are you towing something with a bathroom or is it a utility trailer?
  3. Aug 11, 2017 at 7:05 AM
    Cnasianfire
    Charles
    Wilmington, NC
    I was just curious. I am not towing anything in the near future. But that is a good question. Who knows, I just moved down here, NC is ass backwards! lol.
  4. Aug 14, 2017 at 6:00 PM
    Backinblack03
    Backinblack03 Well-Known Member
    Brian
    VT
    2003 Xtra cab 4x4 2.7/5spd
    ABS sucks.
    I've been yanking around an enclosed trailer that weighs in at just about 3100#, no brakes. I had the trailer weighed in at the local scrap yard, because I had a feeling she was all there... Even with my drilled/slotted front rotors and good pads, it was a little sketchy braking at the bottom of hills!
    It *can* be done, but I smartened up and am installing electric drum brakes soon as all my parts arrive...!
  5. Aug 15, 2017 at 5:16 AM
    jethro
    Geoff
    Southern NH
    Yep, absolutely can be done but it sucks in the weather or on dirt. I have a fairly steep dirt driveway at my place, when I'm hooked and loaded I creep down that driveway or my trailer pushes the truck into the road at the bottom.
