Safety Inspection
Discussion in 'Hawaii' started by bs63366, Oct 23, 2017.
  1. Oct 23, 2017 at 2:10 PM
    bs63366
    bs63366 [OP] Well-Known Member
    San Angelo
    2014 Tacoma TRD Off Road DCSB
    ARE Z-series shell, ImMrYo mirror lift, always on fog-lights.
    I was getting my safety inspection done through one place and he has gone on vacation until after my 30 day voided inspection runs out. So I am looking for another shop to get my safety inspection done through if anyone has any recommendations on a place to get an inspection near Honolulu. Thank you for the help.
  2. Oct 23, 2017 at 5:15 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    If all your stuff is all good to go, it shouldn’t matter where you go. If you looking for that “other place”, I can’t help you there...
    Even if someone does know that “other place”, they should PM you rather than blasting it on here...
  3. Oct 26, 2017 at 6:11 PM
    bs63366
    San Angelo
    I was more looking for any shops that people like to give them the business. Wound up just getting it taken care of at a Firestone.
    raycie likes this.
  4. Oct 26, 2017 at 8:16 PM
    raycie
    Oahu, HI
    In need of $$$
    I used to go to Tandall’s 76 in Waipahu, but they closed down and went to Kailua side.... I would still go there, but the drive just makes me go to a jiffylube....
  5. Jan 23, 2018 at 10:31 PM
    bwhitaker
    bwhitaker Well-Known Member
    Oahu
    2013 Tacoma Double Cab TRD OR 4X4
    Took my truck to Firestone. They failed me on wiper blades being too "streaky". I basically had to purchase the wipers from Firestone or come back a different day. I think some shops like to fail on small things to upsell their products.
    When I lived in town I went to Hiram Texaco (formerly chevron) https://www.yelp.com/biz/hirams-chevron-honolulu
    pinktaco808 likes this.
  6. Jan 24, 2018 at 2:36 PM
    bwhitaker
    Oahu
    From my experience anytime you need to leave your car at the shop i.e they won’t do it with you in the vehicle you have a greater chance of failing.
    76 stations and gas stations with garages seem to be the best and easiest.
    Goodyear / Firestone seem to take the longest and more failure rates for ridiculous reasons (maybe to upsell product).
    Anywhoo...YMMV
  7. Jan 24, 2018 at 11:32 PM
    808matt
    808matt Well-Known Member
    hawaii
    19 Ranger
    Ditto. This shop seemed to let “little” stuff slide. But then again that was before the iPad and now my truck is stock so idk anymore
  8. Jan 24, 2018 at 11:37 PM
    ZekeR7
    ZekeR7 Well-Known Member
    2018 TRD Off-Road 4x4 Quicksand
    Man, do shops really fail people for stupid stuff?
    I haven't gotten any of my vehicles inspected for the past 6 years cause I'm military (Texas doesn't require you to get inspected if you are out of state, just have to inform them you are military and they'll give you the registration sticker without inspection).
  9. Jan 25, 2018 at 4:32 PM
    pinktaco808
    pinktaco808 Hot Steppa
    same here
    jasonleegalaxy likes this.
  10. Feb 2, 2018 at 10:02 PM
    bwhitaker
    Oahu
    As a follow up to this...
    Driving through Kailua the other day the passenger side wiper Firestone installed fell off. Had to pull over on a side street walk back and retrieve it.
    Talk about safety :facepalm:
    flash5twelve and jasonleegalaxy like this.
  11. Feb 18, 2018 at 4:59 AM
    GrisMunkyNinja
    GrisMunkyNinja Well-Known Member
    '16 3.5 AC 4x4 SR5 MGM
    Mililani Chevron failed me once for wipers.
  12. Feb 27, 2019 at 7:46 PM
    Kailuayota
    Kailuayota Well-Known Member
    Kailua, Oahu
    2017 Tacoma TRD Offroad Access Cab
    If my TPMS light is on will I fail safety?
  13. Feb 28, 2019 at 12:47 AM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
  14. Feb 28, 2019 at 10:27 AM
    pinktaco808
    Depend on the shop I think
  15. Feb 28, 2019 at 10:29 AM
    pinktaco808
    Same thing happened to me.
  16. Mar 4, 2019 at 12:11 AM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    shouldn't
  17. Mar 4, 2019 at 8:24 AM
    pinktaco808
    Should pass if not cover with tape lol
    jasonleegalaxy and inksin like this.
  18. Mar 4, 2019 at 12:47 PM
    inksin
    Hawaii
    interesting. I'll admit that I didn't research it before I answered the question and my answer was based off of being denied safety before because my light was on with the reasoning given to me was that it is a federally mandated system required by the government for safety much the same as airbags and safety restraint systems and if those lights are illuminated it means the system isn't working and so it was a no pass. Made sense to me but since you guys brought it up I went and looked and it appears that you guys are right. Federal law says you can't disable the system (specifically the light) but it's alright if it's on saying there is a problem with the system. Sounds about right for government stuff
  19. Mar 4, 2019 at 10:54 PM
    luka
    Kailua, HI
    since around 2005, its a federal mandate for cars to have a TPMS system, though if you change our your tires and don't transfer the sensor, or the battery in the sensors die after 6-7 years, the light will come in, it doesn't mean your car will fail, its just a dummy light that your car doesn't know if your tires are low.
    kind of like the blind spot monitor system on cars, having it or not will not make an impact on the cars ability to physically safely drive down the road.
    I think shops tagging the stupid stuff are protesting the system
  20. Mar 6, 2019 at 3:15 PM
    trdtacomahi
    trdtacomahi 2018 trd off road 4x4
    Hawaii
    Currently being upgraded One @ a time
    Anyone knows if this headlights pass safety inspection in hawaii?
