Safety Recall E02, 2005 - 2011 leaf springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyotacerttech, Sep 26, 2014.
  1. Apr 26, 2019 at 9:44 AM
    #2021
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    If that how you interpreted the recall notice then you're absolutely right. It's a difference of opinion that cannot be settled, because ultimately we agree.
    The recall says:
    (1) The chance exists for a leaf to break and move out of position.
    (2) When this happens damage may occur.
    (3) The remedy is to inspect the pack for the number of clips to determine if it needs to be replaced with a set that has additional clips.
    Leaf spring clips are used to retain springs from shifting so, yeah, my opinion is the number is apparently important to NHTSA and the recall steps they approved from Toyota.
    If it was a question of fatigue or corrosion resistance then Toyota may have suggested replacing with springs built with improved quality steel or better paint that would still only require 3 clips. But seems to me wrapping more clips is a cheaper option that doesn't change anything about the fundamental problem of workmanship or material quality.
    So there's no reason in my opinion to worry too much about recall springs when adding your own clips seems to achieve the same outcome of protecting against a leaf shifting out of place for whatever reason might have caused it. Even perfectly intact high quality leafs can fan out when you flex them, so having enough clips is always important.
  2. Apr 26, 2019 at 6:15 PM
    #2022
    Glamis
    Glamis date joined 03-18-2009 this is my new ID
    Anaheim & Glamis, CA
    08 PreRunner DC/LB Sport-2 Debadged
    Debadged, TRD exhaust, Devil Horns, Pop n lock, Stock wheels chromed, K&N, DRL's on/off switch, bed mat, lock & unlock beeper, Disable Seatbelt Warning Chime, 12v Cigarette lighter plug always on, 2009 LED Brake lights, TSP springs, Fire Stone Ride Air springs.
    here is what you need
  3. Apr 26, 2019 at 9:49 PM
    #2023
    Tennessee98
    Tennessee98 Well-Known Member
    2007 Tacoma supercharged
    If I haven't had the recalled leaf springs replaced yet, will they give them to you if you wanted to install yourself. I have aal I want to put back on. Would the dealer swap over aal to the new leaf springs? Thanks
  4. Apr 27, 2019 at 7:33 AM
    #2024
    NBourque
    NBourque Well-Known Member
    Nick
    Maine
    ‘21 PRO
    Can anyone chime in on this? I believe my leafs have 4 clips. Does this mean they won’t swap the springs out?
  5. May 1, 2019 at 8:17 AM
    #2025
    327
    327 Well-Known Member
    Mark
    Covington, LA
    Former 06 TRD Sport Silver Current 06 Sport 4Runner
    I've been putting off getting mine done. Glad to see the dealerships are still doing this job willingly.
  6. Sep 27, 2019 at 6:52 PM
    #2026
    Mr.Tacoma
    Mr.Tacoma Well-Known Member
    toronto
    DoubleCab4x4
    TRD Exhaust, Side step bar & ARE cap
    Hey Folks
    Is this TSB still open for a 2010 model, my recently bought taco not sure if TSB is done but leafs are flat without even any weight on bed & it's 3 leaf.
  7. Sep 27, 2019 at 7:26 PM
    #2027
    el_smurfo
    el_smurfo Well-Known Member
    I did mine about a year ago and they are already sagged, flat and can't even tow a 1500lb trailer. Don't bother with the tsb, buy some aftermarket upgrades.
    TRlPPlN likes this.
  8. Mar 19, 2020 at 6:29 PM
    #2028
    boxxed
    boxxed Well-Known Member
    Denver, CO
    09 Off Road
    I just saw this was available for my 09 Double cab. I had the TSB leaf added in 2010. I have added the Firestone air bags about 5 years ago to help me tow a trailer. I dont really need them now. I plan on replacing the coil overs and rear shocks soon. I am going to put Bilstein 4600's on the back and KYB strut assembly on the front.
    Learning about this now, should I remove the bags and get it done or just leave them? Also, I had to cut off the bump stops when I installed the bags.
  9. Mar 20, 2020 at 5:05 AM
    #2029
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Why not get new leafs? They wear out over time and there is a potential that the ones you have are faulty. Pull the airbags and go get the springs replaced. Due to safety concerns, they won't (or at least shouldn't) give you back the truck without it being like it came from the factory (i.e. new bumpstops and all). You can probably sell the airbags to someone on here to recoup some of the money that you spent on them.
    boxxed[QUOTED] likes this.
  10. Mar 20, 2020 at 5:18 AM
    #2030
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    I was in a similar situation, having added an extra leaf. My old springs were in great condition, painted, and taken care of. For me it wasn't worth the risk of the gas tank getting ruptured (I know, low risk) but more importantly what would be the implications if I wanted to sell the vechile in the future and a major recall wasn't complete. I went ahead and had them put the new leafs in. I then got home and had to take it apart again to reinstall the non-factory items the dealer wouldn't reinstall.
  11. Mar 20, 2020 at 5:41 AM
    #2031
    boxxed
    Denver, CO
    09 Off Road
    I am going to go there today and get an appointment set with Toyota.
    CowboyTaco[QUOTED] likes this.
  12. Mar 20, 2020 at 5:51 AM
    #2032
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Shoot me a pm if you decide to sell the air bags
    boxxed likes this.
  13. Mar 20, 2020 at 6:44 AM
    #2033
    SJBlack
    SJBlack Well-Known Member
    Had mine replaced this past Tuesday on my 2010 AC 4X4. Took the better part of 4 hours but worth it.
  14. Mar 20, 2020 at 6:47 AM
    #2034
    boxxed
    Denver, CO
    09 Off Road
    I am hoping to get it done ASAP.. Whos knows how things will change with whats been going on.
    If I remove the air bags can I drive around without the bump stops till I get it done?
  15. Mar 21, 2020 at 5:03 AM
    #2035
    JAGCanada
    Canada
    I'd be tempted to take it to the dealer as is and ask them to put the airbags in the back of the truck after the dealer removes them and ask them to install the bumb stop when they put it all back together. For my truck, I took it in with the add a leaf installed, they said they wouldn't reinstall it, so I asked them to put it in the back once they removed it.... so I could reinstall later.
    *edit - just make sure all of the pneumatics/hoses etc are removed - to make the mechanics job a bit easier
  16. Mar 21, 2020 at 6:05 AM
    #2036
    boxxed
    Denver, CO
    09 Off Road
    They told me they would charge me if they had to remove them.
  17. Mar 21, 2020 at 6:24 AM
    #2037
    JAGCanada
    Canada
    Sounds like your going to have to take them off. You'll be fine without bump stops for a period of time - just don't load up the back of the truck with gravel, tackle bumps at high speed, try to jump the truck etc etc...
  18. Mar 27, 2020 at 6:17 AM
    #2038
    Bubbarut
    Bubbarut Well-Known Member
    2011 Super White Access Cab V6 4x4 6SPD Manual
    Took mine to the shop this morning to have this recall done. I knew the front had a cheap spacer lift/leveling kit but never thought to look at the rear. They just called, they can do the recall but wont be able to put the blocks in because the new ubolts are too short. He said if I bring new and longer Ubolts that they will be able to change them out for me and put the blocks in. Now I need to find some Ubolts and hope they get here soon.
    Any recommendations on where to get good quality longer ubolts?
  19. Mar 27, 2020 at 7:14 AM
    #2039
    CowboyTaco
    North Georgia
    11 TRD Sport
    Toytec Lifts
    Bubbarut likes this.
  20. Mar 27, 2020 at 9:07 AM
    #2040
    Bubbarut
    Ordered and will ship today. Thanks
