Safety Recall E02, 2005 - 2011 leaf springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyotacerttech, Sep 26, 2014.
  1. Oct 2, 2014 at 6:00 PM
    #341
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
  2. Oct 2, 2014 at 6:12 PM
    #342
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  3. Oct 2, 2014 at 6:15 PM
    #343
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    But .... but ...
  4. Oct 2, 2014 at 6:48 PM
    #344
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
  5. Oct 2, 2014 at 10:34 PM
    #345
    zilla805
    zilla805 Weekend warrior
    San luis obospo
    4x4 TRD
    I'm glad that cough it
  6. Oct 2, 2014 at 10:58 PM
    #346
    1980
    1980 Well-Known Member
    The Dust Bowl
    Thanks for the info. Looking into it a bit more I find that Chuhatsu is owned (or owns, international business organization confuses me) by Chuo Spring Co., Ltd., which is a multi-billion dollar Japanese spring producer.
    The company is older than Toyota itself.
  7. Oct 2, 2014 at 11:20 PM
    #347
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I do not see how they are going to install a clip as mentioned above. The Clip needs to be riveted to the overload spring to prevent lengthwise movement. The overload springs do not have a hole to install a rivet. It is way too labor intensive to disassemble the leaf packs and install a different overload with the clip on it. Shit they won't even replace a Universal joint.
    I see a very good chance of new leaf pack(s). The spring company is probably going to have to eat a good portion of the cost also.
  8. Oct 3, 2014 at 12:04 AM
    #348
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I don't think a clip will do it:notsure:
  9. Oct 3, 2014 at 1:19 AM
    #349
    1980
    The Dust Bowl
    What kind of load do you have on that truck above? Your bump stop is nearly touching the frame.
  10. Oct 3, 2014 at 3:01 AM
    #350
    robssol
    Rob
    S. Wisconsin
    About 900#, well below the GVWR:eek:
  11. Oct 3, 2014 at 6:02 AM
    #351
    Clayton bigsby
    Clayton bigsby Member
    George
    Columbus, oh
    2006 silver tacoma
    Just dropped off my 06 and he said mine is available for the leaf spring recall. I will post what they say when they call.
  12. Oct 3, 2014 at 6:21 AM
    #352
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    do the numbers not add up that all prerunners and 4x4 will recalled? toyota sells a bit over 100,000 on average every year, lets just say for instance 120,000 over that 7 year span would be 840,000, and assumming that 18% of tacomas sold are 5 luggers (which would include the x-runners) that would be right at 690,000. sorry if these numbers have already been discussed
  13. Oct 3, 2014 at 6:34 AM
    #353
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    Isn't that how many they're saying are being recalled?
  14. Oct 3, 2014 at 6:44 AM
    #354
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    The Ford Pinto exploding car recall involved putting a 50 cent piece of plastic on the rear differential so the gas tank wouldn't spark against the diff mounting bolts when it slammed into the diff in a rear end impact. IOW they're not going to fix everything, just the minimum that they need to fix, and at the minimum cost they can manage.
  15. Oct 3, 2014 at 6:52 AM
    #355
    robssol
    Rob
    S. Wisconsin
    I thought Ford decided it was cheaper to pay the lawsuits, than conduct a recall or change manufacturing methods:eek:
  16. Oct 3, 2014 at 6:58 AM
    #356
    BradyT88
    BradyT88 Well-Known Member
    Once again, the problem is not weak leaf springs. It's a punctured fuel tank. A clip should fix that since it apparently did in 2012+
  17. Oct 3, 2014 at 6:59 AM
    #357
    yota243
    E.J.
    north Alabama
    yes 690,000 is how many they say will be recalled. i am stating that sounds like all of the prerunners and 4x4 made from 05-11 will fall into the recall if that number is acurate
  18. Oct 3, 2014 at 7:03 AM
    #358
    BradyT88
    It is all 6 lug 2nd gens made before Oct 2010 according to the stuff around. It only includes a few of the 2011's since some were made before that date and some after.
  19. Oct 3, 2014 at 7:03 AM
    #359
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    I'm thinking that during the earlier spring fix mention, not only did they add the clips, but they changed the specs for the springs. The spring steel not only has it's own mix of metals when made at the steel mill, it also has to be heat treated and tempered . If either of these processes (or specifications by Toyota) are off, the spring can become either too brittle (and Crack) or not hard enough and cause the springs to loose their strength (sag).
    During the earlier spring fix mentioned in the recall, they may of changed the steel and/or hardening specs to prevent cracking and then had to add a leaf to make up the lost tensile difference - hence the change to 4 leafs. As a safety change they added the straps around the springs as well.
    My 2012 4x4 has 3 leafs so I'm not sure if they made a steel change on mine as it's still 3 leafs ?? May be mine will just sag in the future and not crack - hence the reason mine is not in the recall ??
  20. Oct 3, 2014 at 7:05 AM
    #360
    TacoBurrito07
    Jake
    Arizona
    Gotcha.
