Safety Recall E02, 2005 - 2011 leaf springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyotacerttech, Sep 26, 2014.
  1. May 20, 2016 at 7:48 AM
    #1401
    09TRDSport4x4
    09TRDSport4x4 OCD Approved!
    Nick
    Southwest Ohio
    I'm sitting in the customer lounge at my local dealership right now...
    I had an appointment for 10 AM, as confirmed earlier this week directly with the Service Manager. When I showed up the service writer couldn't even find my name in the system! After she called the Service Manager over they sorted out my appointment and then asked me if the truck had been inspected. I had to explain to the Service Manager (the guy I had been emailing all week) that my neighbor (District Service and Parts Manager for Cincinnati area Toyota Dealerships) had already ordered the parts and that one of the other service writers had called me last week to setup the install. Talk about a huge face palm... Anyway, after they finally got everything figured out and were ready to take the truck back the Service Manager mentioned that the installs for this recall have been taking longer than expected (I was originally quoted 1.5 hours) because they had been advised to check alignment after the install. He confirmed they would not perform a full alignment (unless I wanted to pay for it) but they would check the steering angle and make any necessary corrections so that the truck drove straight after the install. I didn't bother to ask about the new leaf packs but I will crawl under the truck when I get it back to confirm what they installed. My OEM leaf packs were the 2+1 with 3 clips and were covered in rust. It won't be hard to confirm the change assuming they actually install the new springs. I'll post back with an update once I'm finished at the dealership.
    So far this experience has been less than ideal and it confirms exactly why I don't let dealerships work on my truck unless its for recall or warranty work...
  2. May 20, 2016 at 8:10 AM
    #1402
    327
    327 Well-Known Member
    Mark
    Covington, LA
    Former 06 TRD Sport Silver Current 06 Sport 4Runner
    Still waiting in the last round of states lol.
  3. May 20, 2016 at 8:20 AM
    #1403
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    And I still hate it even then.
  4. May 20, 2016 at 9:49 AM
    #1404
    Taco Hunter
    Taco Hunter Well-Known Member
    Hunter
    Triad, NC
    09' Tacoma 2.7l AccessCab 4x4
    Old Steelies to Trd 16'' Matte Black with Cooper ATX3 tires Mech to Electric (Very large but super silent) Single Fan Throttle body coolant bypass + Port and Polish LED Fog lights with custom fabricated mounting 2012 headlight assembly K&N Drop In Intake StopTech Drilled Rotors with EBC Greenstuff Pads StopTech Front + Rear Stainless Steel Brake lines Old Fabric to leather swap on doors 20% Window Tint LCE Long tube headers with Milltek resonator and Magnaflow 12586 muffler WeatherTek In-Channel Deflectors Fox Racing 2.0 Coilovers with Fox 2.0 IFP in the rear Total Chaos UCA's Whiteline Lateral Locks Hellwig Rear Sway Bar Energy Suspension Poly Bushings: Sway Bar, Cab, Rear Leaf Spring
    Thanks! I'll check and see if my VIN is ready too. I'd happily help work through confusion though so long they aren't just trying to be lazy. I don't trust my local dealer... Flow of Winston... Bad things happen there.
  5. May 20, 2016 at 9:55 AM
    #1405
    Imphedup
    Imphedup Trout Addict Whitetail Killer
    CHAD
    LOWELL,MI
    2017 DCLB OR
    Never thought about a alignment? Hmmm..
  6. May 20, 2016 at 10:02 AM
    #1406
    Taco Hunter
    Hunter
    Triad, NC
    How does one do "half/part" of an alignment? Did he mean he wont check the alignment on your front tires? If so then who cares... Changing leafs wont and cant effect their alignment lol but if he meant making sure the rear is perfectly straight like it was then... It's either correct or not
    Why are they so cheap when it's corporate paying for all the labor anyhow? You would never see a doctor turn down insurance payments....
    Imphedup likes this.
  7. May 20, 2016 at 10:06 AM
    #1407
    rhino883
    rhino883 Well-Known Member
    Northeast
    2010 Access Cab 4cyl SR5 4X4
    Bilstein 5100/OME 884
    Just an update. Got my truck back in less than three hours. Despite the uninformed tech, it was pretty painless. They would not do an alignment, but I do agree with most that it doesn't seem to be necessary.
    Only got to drive it 5 miles to work, but it felt smoother and seems to sit slightly higher for the time being.
    Partzguy likes this.
  8. May 20, 2016 at 10:14 AM
    #1408
    Taco Hunter
    Hunter
    Triad, NC
    In my driveway mechanic opinion there should be an alignment done just to ensure garunteed success... You can do the job and not need to make any adjustments but I highly doubt the naked eye could see if it was one or more degrees off which may be even hard to feel driving. I honestly don't know what the "acceptable" amount of degrees off from perfect is or when you could even feel it while driving but wrong is wrong in my book. Even uneven tire wear will suck (Increased costs to you) because a technician was too lazy to double check his work.
  9. May 20, 2016 at 10:42 AM
    #1409
    SYTFUxMBRProjects
    SYTFUxMBRProjects Instagram: b00sted_b18c5
    Mark
    San Leandro
    2006 Super White Tacoma TRD-Sport Supercharged
    You should be receiving a letter very soon. The E02 campaign is currently in the last of 12 phases, which includes: AR, LA, MS, OK, TX, HI, PR
  10. May 20, 2016 at 11:08 AM
    #1410
    09TRDSport4x4
    Nick
    Southwest Ohio
    I think he meant that after the new rear springs are installed they will put the truck on the alignment rack and check the steering angle but they will not make adjustments to correct toe/camber on the front suspension. Either way, I'd assume if you came in with a whacked out alignment it would still suck after the new rear springs are installed but in my case my alignment was fine going in and seems to be fine after the install. I'm also not concerned about the alignment on my truck because I'll be having my truck aligned after my lift is installed on June 3rd.
    Anyway, the job took the dealership less than 2 hours to complete. The first thing I did when I got the truck back was stick my head under there and sure enough, I now have a 3+1 leaf pack with 4 clips (and no rust!) installed. Overall, the ride seems to be the same as the only real difference I noticed on my drive home (I took bumpy back roads on purpose) was how the rear of the truck acted over harsh bumps. With my old 2+1 spring packs the rear of the truck felt very sloppy over harsh bumps and sometimes (especially with extra weight in the bed) it almost felt like the rear of the truck lost traction for a moment. With the new springs this feeling is completely gone. It feels much more connected to the road and while being a touch stiffer, it feels much safer. And as mentioned above, despite the dealership's clear lack of knowledge about this recall and the incompetence of the service writer I'm glad I had the work done. Now I can finally get my lift kit and new tires installed!
  11. May 20, 2016 at 12:03 PM
    #1411
    Taco Hunter
    Hunter
    Triad, NC
    *Nods*. Sounds all good to me! Glad your install went quickly and well. Got me all pumped up for mine.
  12. May 20, 2016 at 12:27 PM
    #1412
    09TRDSport4x4
    Nick
    Southwest Ohio
    One more thing to note, and it's somewhat surprising to me, but my truck sits at exactly the same height in the rear on the new 3+1 spring packs as it did on my old 2+1 spring packs. Considering my truck was never taken in for the TSB I was expecting to gain 1/4" to 1/2" of height in the rear with the new spring packs. Regardless, I'm feeling much better about my choice to go with the Icon 3 leaf progressive AAL in the rear now asthe last thing I want is my truck to sit nose high with the OME 885 springs I'm having installed up front in two weeks.
  13. May 20, 2016 at 2:22 PM
    #1413
    SYTFUxMBRProjects
    Mark
    San Leandro
    For all of you guys asking about alignments being performed after the campaign/recall, it is NOT necessary. Actually, solid rear axle cars [usually] only get front end alignments since the rear is not adjustable.
  14. May 20, 2016 at 2:29 PM
    #1414
    doc1187
    doc1187 Well-Known Member
    new york
    sr5 4x4
    I have a 2010 4x4 access cab. I received a recall notice and they re placed both leaf springs with 4 leafs, I guess the old ones were to week
  15. May 20, 2016 at 2:54 PM
    #1415
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I think we're all aware of this. But some people have had issues after install. It should be part of the recall. Just to make sure the customer does not have to return with further issues. And waste their time. That's why I asked for mine.
  16. May 20, 2016 at 2:57 PM
    #1416
    Arailt
    Arailt Well-Known Member
    Dallas, TX
    2019 GX460
    If the recall springs change the height of the rear end, it will affect the front end. My height decreased because the dealer refused to reinstall my AAL, so my front was noticeably off. The steering wheel was about two degrees off and the truck pulled to the side.
    DEEVON911 likes this.
  17. May 20, 2016 at 5:04 PM
    #1417
    SYTFUxMBRProjects
    Mark
    San Leandro
    I just don't see how it should be apart of the recall if it's not adjustable.
  18. May 20, 2016 at 5:04 PM
    #1418
    SYTFUxMBRProjects
    Mark
    San Leandro
    That makes sense. :headbang:
    Arailt[QUOTED] likes this.
  19. May 20, 2016 at 5:05 PM
    #1419
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    But it can throw the front end out.
  20. May 20, 2016 at 5:05 PM
    #1420
    SYTFUxMBRProjects
    Mark
    San Leandro
    See post above, Lol.
