Safety Recall E02, 2005 - 2011 leaf springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyotacerttech, Sep 26, 2014.
  1. Jul 28, 2016 at 9:55 PM
    #1781
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    My dealer says they WILL remove the suspension mods (air bags in my case) to install the new springs but will NOT put back any modified suspension parts. It will be reverted to stock. I will need to put them back on.
    Arailt likes this.
  2. Aug 4, 2016 at 6:02 AM
    #1782
    gnfreak
    gnfreak Active Member
    keith
    Normal, IL
    2007 Tacoma Access Cab
    I had to take off my Timbrens but not the add a leafs. But they also did not reinstall the aal.
  3. Aug 4, 2016 at 6:07 AM
    #1783
    Arailt
    Arailt Well-Known Member
    Dallas, TX
    2019 GX460
    I got the same treatment.
    My dealer boxed up my old leafs that included my AAL and left it in my bed.
  4. Aug 12, 2016 at 6:57 PM
    #1784
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Got the call today set to get new leafs and alignment on 08/22/16. Along with the 90,000 mile service.
  5. Aug 14, 2016 at 11:40 AM
    #1785
    gnfreak
    keith
    Normal, IL
    put the add a leaf back on last week and took camper out this weekend. man these new springs really sag. looks like time to get new leaf pack and get my height back the right way. should have just left it the way it was.
  6. Aug 15, 2016 at 5:57 PM
    #1786
    Glamis
    Glamis date joined 03-18-2009 this is my new ID
    Anaheim & Glamis, CA
    08 PreRunner DC/LB Sport-2 Debadged
    Debadged, TRD exhaust, Devil Horns, Pop n lock, Stock wheels chromed, K&N, DRL's on/off switch, bed mat, lock & unlock beeper, Disable Seatbelt Warning Chime, 12v Cigarette lighter plug always on, 2009 LED Brake lights, TSP springs, Fire Stone Ride Air springs.
    has everyone seen this dealer Document. I need to call my dealer and make shore I'm getting the right springs.
  7. Aug 16, 2016 at 4:48 AM
    #1787
    nivek5sfe
    nivek5sfe Well-Known Member
    Marietta, GA
    05 DCLB 4x4
    Well 2 months after having it inspected toyota put the new springs on my truck yesterday. looks like its sitting a bit higher now in the back. Im sure theyll settle eventually, i only drove it home about 5 miles from the dealership.
  8. Aug 16, 2016 at 7:58 AM
    #1788
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    I had the leaf springs recall installed this past weekend and now the Bed of my truck seems to be uneven. One side is higher than the other you can physical see it from the rear. I measured it after I got home and sure enough one side is 1.5 inches higher. I drove it over the weekend and it still the same no change. Does anybody know if that's adjustable and something that the Dealer needs to correct? Since it's their screw up.
  9. Aug 17, 2016 at 11:09 AM
    #1789
    jleebo77
    jleebo77 Member
    Lee
    Suburbs of Atlanta
    06 PreRunner...Silver, Shortbed
    After 23 months... Mine are done. I'm not a car guy but they are definitely firmer and may sit up a little higher but with my shell it's not much of a difference. Hard to complain about something free on an almost 11 year old truck. Took 2 months to get the springs in. Was told it would take 2 hours and it took 3.5. Then I had to wait 25 minutes for the idiots to find my keys. They pulled the truck around and I'm guessing who ever pulled it around went on break off site with my keys.
  10. Aug 22, 2016 at 10:00 AM
    #1790
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    So this dealership actually called my wife last week and said that my springs are in. . . . WTF And looking underneath that note, it looks like some stuff was ordered that I didn't realize when I looked at it originally.
    Go up to the dealer to talk to them and turns out they ordered the regular set of springs not the ones you get if you had the TSB. So here I wait again on another back ordered set of springs.
    And I did go to another dealership, so now I have leafs on order with them also. (likely the wrong ones) :laugh:
  11. Aug 22, 2016 at 1:55 PM
    #1791
    matadorCE
    matadorCE Well-Known Member
    Melbourne, FL
    '05 Prerunner Accesscab TRD Offroad
    I've been waiting on a set of springs for about two months now.
  12. Aug 22, 2016 at 2:01 PM
    #1792
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    That's old..there have been several newer versions released.
    If I had it to do again, I would have skipped this recall and just kept the TSB packs I had. The new springs are garbage! They settled more than two inches in a weekend of the truck sitting in my garagears immediately after install....
    #Toyotafail
  13. Aug 22, 2016 at 6:59 PM
    #1793
    Tiedie
    David
    WFOY
    Got the recall done today along with the 90,000 mile service.
  14. Sep 15, 2016 at 4:56 AM
    #1794
    esse10
    Texas
    update; it level out a few weeks back I just hadn't had the time to come online and update this thread. So you folks that have the springs installed with the same possible issue can read & learn about this.
  15. Sep 16, 2016 at 9:44 PM
    #1795
    jtkkz
    jtkkz Well-Known Member
    Bay Area, Ca.
    2005 Tacoma DC 4WD
    OME lift kit / Fifteen52 Analog wheels
    I got a recall notice but i ended up upgrading my suspension with complete OME kit with dakar rear leaf, since stock 3 leaf kept bottoming out.
    I submitted a re imbursement form , and finally toyota approved and re imbursed me for my new dakar leaf springs.
  16. Sep 20, 2016 at 11:19 AM
    #1796
    j.d.mason
    j.d.mason Well-Known Member
    Toronto, Canada
    2014 White TRD Sport DCLB
    I'm scheduled to bring my vehicle in next week to have a service done and to have the leaf recall done. They indicated to me on the phone that the springs and shackles would be replaced (Canadian recall - not sure if this is different from the American one?). Is there anything else that it would be beneficial to have done while the vehicle is in for this work(s)? Anything while it's up on the hoist that would line up with the work required? Just figured I'd check and ask!
    Thanks in advance!
  17. Sep 20, 2016 at 11:20 AM
    #1797
    j.d.mason
    Toronto, Canada
    Oh wow - I'm scheduled to get the recall done next week but I was planning on putting some kind of lift in after the fact anyway. Maybe this is the better route to take and I should just forgo the recall work?!?
  18. Sep 20, 2016 at 6:38 PM
    #1798
    Brian B
    Brian B New Member
    Brian
    07 Tacoma SR5
  19. Sep 20, 2016 at 6:57 PM
    #1799
    alanmeyer
    alanmeyer Well-Known Member
    Alan
    Anaheim Hills, CA
    2011 DC PreRunner TRD Sport
    Took our 2011 DC in to have the leaf pack replaced and they wouldn't do it without removing the lift. And they won't just give us the leafs to allow me or a shop to swap it.
    Also, if they removed the lift (at a cost to us), the wheels won't fit anymore in the front. If they only removed the spacer in the back (front high, rear low) temporarily, then they said the drive shaft would be at an angle, which adds risk to damaging the diff. So they wouldn't do that either.
    So I'm at a loss. I'm considering just buying a 3rd party leaf pack and then having a shop do the swap for me. Any advice? Should I just buy some OMEs? I'm in SoCal (Anaheim) in case there's someone local that can help me.
  20. Sep 21, 2016 at 2:07 PM
    #1800
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    That document specifies the incorrect(?) 37ft lbs for Ubolts.
    It also calls for an alignment.
