Safety Recall - J06 Master Cylinder Brake Assy
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Speed Nut, Jan 12, 2019.
  1. Jan 29, 2019 at 7:34 AM
    ba_chamberlain
    ba_chamberlain Member
    2018 Cement TRD sport
    Yes, at the connection to the brake master cylinder. Sorry for any confusion!
  2. Jan 29, 2019 at 7:42 AM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    I know we don’t all park where it’s noticible, but did you see drops or anything under your truck? Seems like that much fluid leaking may leave a trace behind? This isn’t to bash you for not seeing it, an actual question! Might’ve been slow enough to not see yet drain enough over a week still.
  3. Jan 29, 2019 at 7:51 AM
    ba_chamberlain
    Fair question. My work parking garage is underground and not well lit, we also had a few wet days last week. However, I remember coming out of work one day one day and seeing a wet spot and chalking it up to the rain. After this happened, I have my suspicions it was brake fluid.
  4. Jan 29, 2019 at 7:53 AM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    That makes sense. Some don’t pay attention or have valid reasons like you just stated. Mine hasn’t gone in yet and wanted to get some feed back.
    Thank you sir. You are a scholar and a gentlemen!
  5. Jan 29, 2019 at 9:43 AM
    1911tex
    1911tex Well-Known Member
    2018 Silver Metallic Limited
    No recalls (including Master Brake Cylinder) on my '18 Limited vin.....just checked.
  6. Jan 29, 2019 at 9:51 AM
    XRacer264
    XRacer264 Member
    Gerard
    2018 Sky Silver Tacoma TRD Off Road
    None yet
    Checked the Toyota Owners app also and there is no mention of a recall yet. I'll keep checking here and the app.
  7. Feb 5, 2019 at 5:15 AM
    My3rdGenSport
    My3rdGenSport Member
    B
    2018 Tacoma Sport 4x4 Double Cab
    Nerf Bars, Cold Air Intake, Vinyl Wrap, Car Audio Upgrade - 2 12"s, Hidden Bumper Light Bar, LED Bed Lights, LED Interior lights, 3 inch Exhaust upgrade
    Just came back from Dealership after getting TSB 0058-18 Transmission Re-flash, Dealership stated that The Master Cylinder has a Recall. I am assuming its on all the 3rd Gens, Just wanted to let ya know if you you haven't been to dealership lately (Which I hate going unless I have to).
    Dealership stated that has to order parts and will take a couple o hours to install.
    Hope this helps.
    Love this Truck!!
    KTJO 4x4 likes this.
  8. Feb 5, 2019 at 5:20 AM
    Pine State
    Pine State Well-Known Member
    Maine
    2018 Tacoma DCSB SR5 4x4
    Its not on all of the 3rd gens, at least not yet. Only some. Those impacted can go to the toyota owners portal and see or enter their VIN in the recall webpage.
    My3rdGenSport[QUOTED] likes this.
  9. Feb 5, 2019 at 5:25 AM
    My3rdGenSport
    B
    I understand, thank you for the help. I Believe that I remember the date of the TSB was July 2018. But have to look again at paperwork. Didn't know if it was for the latest 3rd Gen's or not.
    Thanks for your assistance.
  10. Feb 5, 2019 at 7:05 AM
    KTJO 4x4
    KTJO 4x4 Well-Known Member
    Katie
    Oregon
    2017 TRD OFF-ROAD 4x4 DCSB BARCELONA RED
    Nitro 4.88 Gears OVTune 1.05 91Oct DirtyDeeds Exhaust
    Yes. This is for 18-19. Get it done. Whether it’s an issue or not. Just get it done. I have the issue right now and I have a 17. Luckily corporate is covering mine but I’m lucky.
    MrBrooks likes this.
  11. Feb 5, 2019 at 7:26 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    It is a recall for a select number of VINs. You can check here: https://www.toyota.com/recall to find out if your truck is affected. My 18 delivered in June is not affected.
    TRDPro916, jaapsheep and TT005 like this.
  12. Feb 5, 2019 at 7:50 AM
    Tacoma1818
    Tacoma1818 Well-Known Member
    What are the symptoms?
    KTJO 4x4[QUOTED] likes this.
  13. Feb 5, 2019 at 7:54 AM
    Weedly
    Weedly Well-Known Member
    Doug
    Collingwood, On. CAN
    2022 DC TRD Sport in Lunar Rock, 1988 RX7 Convertible
    No symptoms as far as I know but they are being proactive to avoid future issues. I took delivery of my 18 in late December, got a phone call from my dealership about 2 weeks later, and an email about it from my sales guy, and had the new master installed a few days later...it took no time. I suspect it's a bit of a big deal for the affected trucks because they were very quick to get it dealt with
  14. Feb 5, 2019 at 8:08 AM
    KTJO 4x4
    Katie
    Oregon
    It first started with my brake pedal feeling different. Like usually I would only have to tap my brakes and I eventually was having to really press my pedal to the floor. So I thought it was just maybe rear brakes needing adjusted. Well that needed to be done. Did that. Felt a little better but didn’t last. Pedal still felt like nothing was there. Braking distance had to be increased and I thought ok maybe because I went from 33” to 35”. Then I was like no way. This is crazy. My cousin looked at it. He was like no it seems like it’s more like the master cylinder. That next day I actually drove it to work and in my way home my brakes went out. Pedal went to floor board with nothing behind it. You could use your hand and push the pedal down with one finger and have no problem whatsoever. This is something that happens over time. That’s why I say just because you don’t have the symptoms now get it done because over time you probably will. It’s like $5k to fix. So not cheap.
  15. Feb 5, 2019 at 8:17 AM
    #35
    TT005
    TT005 Well-Known Member
    NC
    2023 SR5 DCSB 4X4
    My ‘18 Tacoma is on the recall list.
  16. Feb 5, 2019 at 8:30 AM
    #36
    Tacoma1818
    DANG!
    Thanks for sharing. My ‘18 isn’t under the recall (yet?). I’ll keep an eye out for it. I drive like 3k - 3,500 miles per year TOPS so I may never see it if it takes some miles to show signs.
    Wonder what the VIN range is... bad problem to have!
    My3rdGenSport likes this.
  17. Feb 5, 2019 at 8:36 AM
    #37
    My3rdGenSport
    B
    TT005...I would call dealership so they can order the master cylinder and then schedule an appointment. My dealership didn't have any in stock and they said would need to schedule and it would take 2 hours or so to install. Hope that helps.
    Denteen and TT005 like this.
  18. Feb 5, 2019 at 8:45 AM
    #38
    TT005
    NC
    2023 SR5 DCSB 4X4
    Thanks for your advice. Possible brake failure is a serious concern!
    Tacoma1818 likes this.
  19. Feb 7, 2019 at 4:43 PM
    #39
    Big Spender
    Big Spender Member
    Ron
    2016 Silver Double Cab Tacoma TRD
    Bed mat
    Can the brake fluid be bled at the master cylinder or do the wheels have to be removed to bleed the air out?
    i received the recall notice in the mail today. Called Toyota dealer. They said they do not keep master cylinders
    in stock. Will order the master cylinder and call me when it arrives to schedule a service appointment.
  20. Feb 7, 2019 at 5:34 PM
    #40
    jaapsheep
    jaapsheep Well-Known Member
    Janice
    canada
    2023 Blue Crush TRD off road access cab
    went for the blackout package this time
    how did the issue show itself? I have a 17 and it has starting making a noise just after it starts, that comes from around the brake controller area... I did not receive any notice of a recall though
