SafetyDang DC Build/4wd Swap/Manual Trans Swap Thread
Discussion in '1st Gen. Builds (1995-2004)' started by SafetyDang, Nov 4, 2012.
  1. Nov 18, 2019 at 4:12 PM
    #181
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    The wiring harness is different, so if you can, steal that from the donor as well.
    There is an additional sensor on the "2-4 Select" Transfer Case that sends a signal to the ECU of whether it is in High or Low range, which will enable/disable the ability to use the rear locker as well as some other logic.
    Personally, unless you want to have twin sticks, I'd just use the 2-4 select transfer case.
    Ccrowe323[QUOTED] likes this.
  2. Nov 18, 2019 at 4:57 PM
    #182
    Ccrowe323
    Ccrowe323 Well-Known Member
    Cory
    Florida
    2001 Tacoma 3.4 DC 5speed TRD OR
    I’ll be buying the entire truck so I will have access to every part of the truck that I would need.
    I would prefer to use my J shifter, not to have to swap the donor Tcase with the push button and deal with extra electrical just for a push button. Not going to be putting in a marlin crawler twin stick, would be sic but not in the budget right now.
    By 2-4 shifter do you mean the push button or the J shift?
  3. Nov 18, 2019 at 7:10 PM
    #183
    JasonLee
    15 TRD OffRoad
    Yes, the service manual calls it that. Probably best to know the Toyota terminology before starting the project so it’s easier to parse the service manual which will become your new bible.
  4. Mar 22, 2020 at 3:42 PM
    #184
    SafetyDang
    SafetyDang [OP] get your facts straight
    Dang
    Anaheim, CA
    DC with 4x4 & MT Conversion
    Swapped to Manual Trans & 4x4
  5. Mar 25, 2020 at 3:56 PM
    #185
    Thunderchicken58
    Thunderchicken58 New Member
    Will
    2001 Tacoma
    2wd to 4wd conversion Head
    Safety.. do I need to change my wiring harness from my prerunner or keep the oem one and just leave the plugs hanging that went to the auto trans?
  6. Mar 26, 2020 at 3:39 PM
    #186
    SafetyDang
    Dang
    Anaheim, CA
    No need to change the wiring harness. Just unpin the things you don't need from the ECU. I knew I would not convert back to an Auto-Transmission so I just cut the ones I didn't need.
    In regards to the wires by the transmission, I wrapped in tape and left it tucked away on the manual transmission. The harness going down to the transmission still has the wires for the park neutral safety switch, O2 sensors, 4x4 position sensors, and reverse light. You'll need to rewire them accordingly to get your truck running.
  7. Mar 27, 2020 at 11:04 AM
    #187
    Thunderchicken58
    Will
    2001 Tacoma
    Thanks! Will it run if I put the computer in that came from the truck with the manual transmission ?
  8. Oct 5, 2020 at 4:56 PM
    #188
    Gnarlyshredder
    Gnarlyshredder Well-Known Member
    Jacob
    SoCal
    1999 Prerunner
    Suspension: Bilstein front/rear 5100's (set at 3" lift) Eibach front coil springs 620lb Toytec 2" add-a-leafs Wheels/Tires: Pro Comp 7069 Series Alloy Wheels 285/75/15r General Grabber AT2s
    @SafetyDang Hey man, I referenced your writeup quite a few times when doing my swap a few years ago, so thanks for that! I never got around to finishing the speedometer part of the swap, so I've been driving without a speedometer for quite some time lol.
    The transmission I used for the swap is from a 96 Tacoma, so it has a mechanical VSS, but my truck is a 99 Prerunner, so it has an electrical VSS. So from my understanding an eletrical VSS is interchangeable for the mechanical VSS, and then after I switch them out I just need to extend the female end of the plug on my truck to reach the VSS, and then I'm good to go? Thanks!
  9. Oct 8, 2020 at 10:05 PM
    #189
    SafetyDang
    Dang
    Anaheim, CA
    If I remember correctly, yes. DM me on IG if you have any issues. I don't log on to TW often.
    Bandido likes this.
  10. Oct 9, 2020 at 7:06 PM
    #190
    Gnarlyshredder
    Jacob
    SoCal
    1999 Prerunner
    Thanks dude, don't have an IG but I will take your word for it!
  11. Dec 18, 2020 at 4:37 PM
    #191
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Man... how has it been 8 year? Hows the Tacoma?
    In the quote above, how did you mount the twin stick boot to the stock reboot ring?
    defythemall likes this.
  12. Aug 10, 2021 at 8:35 AM
    #192
    Franktaco81
    Franktaco81 New Member
    Frank
    04 Tacoma
    Sweet safetydang you are located here in Anaheim ca. Cause I am in Los Angeles. Ca
    Would like to know more and get some help from you if you ok??
  13. Aug 13, 2021 at 11:43 AM
    #193
    Ccrowe323
    Cory
    Florida
    Honestly it’s really easy swap if you’re only doing the transmission. I can’t speak on swapping to 4x4. Check out @osterhagen’s build thread on his swap. There are a couple good one on here. Also for the basics watch @Timmah! videos on removing and auto trans and removing a manual trans.
    https://www.tacomaworld.com/threads/crowe’s-auto-to-manual-01-1st-gen-swap.651201/
    Here’s my thread I didn’t finish yet, but it has the videos attached and some other helpful links that helped me. How much experience do you have working on your truck?
  14. Aug 15, 2021 at 5:13 PM
    #194
    SafetyDang
    Dang
    Anaheim, CA
    Longer bolts through the boot plate and sandwiched the twinstick boot in between.
    Sold the truck.
    What is your question? Physical help?
  15. Aug 16, 2021 at 6:19 AM
    #195
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Wat
    You a LandCruiser elite-est now? lol
    How much for if you don't mind my asking? I always wonder what my (very similarly modified) rig might go for
  16. Aug 17, 2021 at 5:13 PM
    #196
    SafetyDang
    Dang
    Anaheim, CA
    Sold it to a friend for low. I didn't ask for the current market value. I asked for what I thought it was worth. If I didn't sell to a friend I would have asked for more.
    COMAtized99 and Bandido[QUOTED] like this.
