SafetyDang DC Build/4wd Swap/Manual Trans Swap Thread
Discussion in '1st Gen. Builds (1995-2004)' started by SafetyDang, Nov 4, 2012.
  1. Nov 20, 2012 at 3:05 PM
    SafetyDang
    SafetyDang [OP] get your facts straight
    Dang
    Anaheim, CA
    DC with 4x4 & MT Conversion
    Swapped to Manual Trans & 4x4
    Pictures from the past 2 weeks of work. Sorry been busy.. DRIVING IT! :D
    So last week. I put my throw out bearing on, fork, and torqued everything to specs per fsm.
    Loctite
    Grease
    More grease...
    Little bit more..
    I got my friend.. to help me out... Toyota Tech Eric!! (hes basically a Master Tech) just to assure things don't go wrong.
    Then I forgot about the shift tunnel and short shifter..
    Bam.. :saw:
    Then again!
    Cross member almost didn't go in but then I found a way to make it fit.. Esp if you have the Heavy Duty mount...
    Cross member first! Not bolted but in the "grove" or "slot" and note not all the way up as well. Then slide the mount in. Once you get that far push cross member up and and bolt that down. Finally bolt the MOUNT to the Cross member. And the hardest part was bolting the mount to the transmission.. Careful not to strip anything! Take your time.. Use pry bars or even the tranny jack to line everything up.
    Put the starter back..
    Then the exhaust.. OH BOY the exhaust... Everything came out ok but going in.. one nut striped my stud.. Some how got the nut off and cleaned up the threads enough to get a new nut on. If I ever have to take it off I will replace it...
    Cleaning drive shafts..
    Getting some air leaks in the shift tunnel.. The plate is about 1 inch or 1/2 inch short.. Duct tape was used as a temporary fix.
    Twin stick boot helped limit the air coming in.
    Replaced the plastic "cover" that was near the manifold with this clip.. Which bolts on to the clutch slave line to flex line bracket.
    Then started marking what the hecks what..
    VSS Pig Tail
    Reverse Sensor on Passenger side of transmission. (Use Tacoma4Life Diagram. (I didn't wire that yet)
    O2 sensor Plug
    O2 sensor pig tail
    Taped up the rest for now..
    Remove Auto transmission bracket
    Looking through the wheel wheel you can see the bracket it clips on to.. And how close it would be to the manifold. Looked on SuperChiem's truck and he has a heat shield type from factory..
    Well then..
    Donor..
    Boom!
    Learned how to solder correctly in Basic Automotive Electrical.. Using J hooks on each end then twist gives you the best connection.. I've been crimping everything before I learned this..
    Solder
    Wrap
    Other end needs the same thing.
    and wraped!!!
    What! No more following slow drivers to prevent getting speeding tickets for me! :cool:
  2. Dec 9, 2012 at 7:16 PM
    SafetyDang
    Dang
    Anaheim, CA
    This came other other day...
    Having trouble locating reverse and clutch pig tails. Gotta hit up the local yards again see what I can come up with.
  3. Dec 26, 2012 at 11:14 AM
    extrmsob293
    extrmsob293 Well-Known Member
    dude i love your truck
  4. Dec 26, 2012 at 11:59 AM
    SafetyDang
    Dang
    Anaheim, CA
    Thanks. More to come on how to wire it.
  5. Dec 30, 2012 at 8:19 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Any diagrams to wire an add with push button up for my pre runner, couldnt find manual hubs but found someone with all the ADD parts I need
  6. Dec 31, 2012 at 12:53 AM
    SafetyDang
    Dang
    Anaheim, CA
    PM sent
  7. Jan 27, 2013 at 3:33 PM
    SafetyDang
    Dang
    Anaheim, CA
    Forgot I had a thread over here.
    Also Update On Swapping ECU. Myth was if you could or couldn't plug and play with out deleting wiring. [​IMG]
  8. Mar 10, 2013 at 8:47 PM
    SafetyDang
    Dang
    Anaheim, CA
    Code were cleared till I got a p1132.. which is the A/F front sensor. >.< Always something... Though I do have an exhaust leak that I haven't tended to. Other than that the swap took 30mins, Cutting not unpining. Unpin if your not lazy.
  9. Apr 29, 2013 at 5:03 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Can you do some more explaining on post #28? Im concerned about the ECU/Wiring/CEL. Can I make the swap (mechanical) drive the truck while I work on the ECU/Wiring?
    So pretty much its just unpinning or cutting wires off the plug going to the ECU?
    Ive found a parts truck and found a 4cyl man trans and J shift Tcase...ughhh
  10. Apr 29, 2013 at 5:26 PM
    oldblue1968chevy
    Spokane WA/Viola TN
    Stock
    Im ASSUMING the ECU is different between 6 and 4 cyl? Do you need the exact same year as model your swapping into? This is making more and more sense with every time I read it (lol).
    Thanks again sorry for the ?'s
  11. Apr 29, 2013 at 5:30 PM
    SafetyDang
    Dang
    Anaheim, CA
    Yes best bet same year and model with manual tranmission. Good luck.
  12. Oct 29, 2013 at 12:06 AM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    Damn that's awesome! I think I may want a double cab in the future, but only if I can swap to the 5 speed. subbed and saved :thumbsup:
  13. Oct 29, 2013 at 12:54 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Nice truck dude I gotta give you props for the work you did
  14. Oct 29, 2013 at 2:57 AM
    SafetyDang
    Dang
    Anaheim, CA
    Thanks guys. If you have any questions just ask. I could write a 20 page paper on all the things I learned. I tried to make a faq on ttora and it become 4 peoples build thread. Loads of info though.
  15. Oct 29, 2013 at 6:32 PM
    #35
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    What would I need to do a 5 speed swap.....I tried searching but most are 2wd adding 4wd. I have an 04 dbl cab 4x4.
  16. Oct 29, 2013 at 7:42 PM
    #36
    SafetyDang
    Dang
    Anaheim, CA
    Refer to first post. I am pretty sure that I covered it there. I posted links to all threads regarding 4x4 or 5 speed swaps.
    What do I need to swap to a 5 speed transmission?
    R150 or R150F (4x4), Clutch, Clutch Cover, Flywheel, Transmission or T-case mount, Slave Cyl, Master Cyl, Clutch Lines, Shift Boot, Shift Cover and a few other little bolts and nuts
  17. Oct 29, 2013 at 8:01 PM
    #37
    TripleThreat
    TripleThreat Vance@freevancewriting.com
    They keep callin me cowboy but its not my name...
    Socal but I am still a southern Florida guy
    Toyota Tacoma 4x4 slightly modified
    nothing special.... wanna race?
    Got this from: minameismud
    But this swap is inspirational! nice job 5 stars!
  18. Oct 29, 2013 at 8:13 PM
    #38
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
  19. Oct 30, 2013 at 10:14 AM
    #39
    nigglewiggle60
    nigglewiggle60 Well-Known Member
    Nigel
    Oakhurst, CA
    2004 DC 4x4 TRD
    Rubber mats, Bluetooth.
    couldn't a person wanting to do a 5 speed swap buy an ext. cab. Tacoma with a 5 speed and just swap the body over from the double cab? Then sell the new extended cab auto and outside of a few minor parts break even?
    Take 5 speed ext. cab Tacoma + auto Double cab Tacoma =, swap bodys roughly, = 5 speed double + auto ext. cab?
    BigBadJohn likes this.
  20. Oct 30, 2013 at 11:35 AM
    #40
    SafetyDang
    Dang
    Anaheim, CA
    It has been done. He was the first.
