sagging Bilstein shock
Discussion in 'Suspension' started by buhrito, May 27, 2009.
  1. May 27, 2009 at 1:21 PM
    buhrito
    buhrito [OP] New Member
    Duluth, MN
    lifted Tacoma
    3.5" lift Detroit Lockers
    '98 Tacoma Reg cab
    2.7L, 5spd, 4wd
    I have Bilstein shocks (10" 5150 Series with 255/70 valving). They came on the truck and I don't know much about them.
    The rear left shock always sags a little. At best, about an inch and at worst, maybe 2-1/2 inches, or so.
    Anyone know if these can be adjusted in some way?
    thanks
  2. May 27, 2009 at 1:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The springs are going to dictate ride height.....Sounds like you may have worn springs?
  3. May 27, 2009 at 1:40 PM
    buhrito
    Duluth, MN
    lifted Tacoma
    yeah, now that you mention it, thats probably it. I added a leaf spring on an S-10 before so, hopefully I can fix this problem too.
    I suppose I'm best off replacing all of them? I have to look how many there even are...3 on each side, I think?
  4. May 27, 2009 at 1:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah. 2 plus an Over load. Depending on the miles, you may want to consider a new leaf pack.
