Sagging Doors?
Discussion in '1st Gen. Tacomas (1995-2004)' started by steve o 77, Mar 11, 2010.
  1. Mar 11, 2010 at 2:15 PM
    steve o 77
    steve o 77 [OP] braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    My drivers side door is sagging to the point where it is rubbing the top of the latch on the cab. It's starting to get annoying and I want to fix it. Do I need to get new hinges at the dealer or can I get them cheaper somewhere else?
    Thanks
  2. Mar 11, 2010 at 2:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you are mechanically inclined, and have the right tools, you can replace the bushing in the hinge pins.
  3. Mar 11, 2010 at 2:27 PM
    ryhar85
    ryhar85 Well-Known Member
    W. WA
    05 TRD 3" lift
    3" Trailmaster lift, 18" rockstars blacked out, 275/65/18 sxt mud terrains, more to come.
    New hinges are absolutely not necessary. Just make sure the hinge bolts are tight, which I'm sure they will be, then simply lift up on the door to adjust it to where it needs to be. You can even use a 2x4 in the door jam with the door open, and pry up on it as a lever. Just use a rag between the door and wood if you use this route. Trust me, you will not hurt your door by doing this. I have used this method MANY times on many different vehicles. It is a common problem, with an easy fix.
    beaverdamland likes this.
  4. Mar 11, 2010 at 2:34 PM
    steve o 77
    Steven
    In a corn field, OH
    Thank you. I'll see what its going to take to do that.
    Thanks. My mom's suburban had this problem bad and replacing the hinges fixed it. Maybe it wasn't necessary though?
  5. Mar 11, 2010 at 5:26 PM
    Worm
    Worm Well-Known Member
    Scott
    Southern Maryland
    x2
