Sagging hood
Discussion in '3rd Gen. Tacomas (2016-2023)' started by soggyBottom, Oct 7, 2018.
  1. Oct 7, 2018 at 7:30 PM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    A couple weeks ago i bough a 2018 trd pro. I just noticed the driver's side of the hood is lower by about 1/4 inch while the passenger side is ligned up perfectly with the fender. The sagging looks to be the same from the leading edge to the trailing edge of the driver's side of the hood. Is there a simple adjustment that can be done? I suspect it was like this when I bought it but I didn't notice it until now.
  2. Oct 7, 2018 at 7:31 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    There's two plastic mounts the hood sits on. Give it a little twist. Should line it right up.
    shakerhood and TacoBuffet like this.
  3. Oct 7, 2018 at 7:36 PM
    soggyBottom
    Twisted as far out as I could and it didn't fix it. The hood is also lower at the rear where the hinge is. I can't imagine the black rubbery twisty this g would help raise the rear of the hood. Am I missing something?
  4. Oct 7, 2018 at 7:37 PM
    toyotatacomaTRD
    Gotcha. I assumed the front of the hood. I would take it into the dealership to align. I understand they're a little tricky.
    TacoBuffet likes this.
  5. Oct 7, 2018 at 7:40 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    My 18 was delivered with exactly the same issue. Between this and the rear bumper alignment issue that many 18's have, it seems like a automation issue and a quality control issue. I could fix it but going to have the dealer do it on my first visit.
  6. Oct 7, 2018 at 7:41 PM
    soggyBottom
    I can only hope they don't charge me for it.
  7. Oct 7, 2018 at 7:44 PM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    They won't, covered under warranty, and if you throw some "this is unacceptable on a new truck" might get a discount on accessories, etc.
    shakerhood likes this.
