Sagging Suspension
Discussion in 'Suspension' started by CamShaft033, Apr 17, 2017.
  1. Apr 17, 2017 at 5:14 AM
    CamShaft033
    CamShaft033 [OP] Well-Known Member
    Cameron
    Chattanooga TN
    2012 DCSB TRD Sport
    OME 887s, JBA uca, Dakars, Fox Shocks, 285/70/17 Nittos, Dual Flowmaster, ARE Camper Shell w Yakima Rack, CVT Tent, AVID Rear Bumper Guard w LED Pods, 52" Lightbar, Sportsman Seat Covers, WeatherTech Floor mats
    I have a 3" toytec lift with an add a leaf in the rear with stock bilstien shocks on a 2012 DCSB. The truck set and rode great, but now that I have added a camper top and a rtt it sags just a bit and if I haul anything it sags bad! My question is could I just replace the stock shocks in the rear with 2" lift 5100's or should I address my leafs? Thanks.
    ChadsPride likes this.
  2. Apr 17, 2017 at 5:15 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Replacing the shocks will do nothing for the sag. If you are carrying that much weight a full leafpack like dakars might be a good option.
  3. Apr 17, 2017 at 5:17 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Agreed man, you need springs that can handle more load. Dakars would be great...the stock suspension is not designed to have that much load on a consistent basis. Not that I think you would damage it in the interim or anything, but the sag wont go away until the RTT does, or you get a new leaf pack.
  4. Apr 17, 2017 at 5:22 AM
    CamShaft033
    Cameron
    Chattanooga TN
    2012 DCSB TRD Sport
    Ok thanks guys, that was my initial response as well until i started getting mixed reviews about replacing the stock shocks. I would have already done both, but I bought the truck the way it sits today. Would you recommend the OME shocks with the dakars or 5100s?
  5. Apr 17, 2017 at 5:24 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I think many go with 5100s, but Im sure others will chime in with more experience with these. I unfortunately don't have any personal experience with dakars.
  6. Apr 17, 2017 at 5:31 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I was in the same boat as you. Installed the 2" AAL then hooked up out family's toon once and the sag started right away. The AAL lasted about 3k and rode terrible. Now, I have the full Dakar leaf pack with the D29XL AAL.
    I would go OME with Dakars as they are designed to work with the Dakar leaf packs. I had OME but then got 12" Billies
  7. Apr 17, 2017 at 5:31 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    I specifically went with the extended travel 5100s with my dakars because the dakars give you a ton of lift in back and with the extended travel bilsteins you can get much more flex. The OME shocks will severely limit the flex you will get.
    Of course you have alot more weight back there anyway pushing down on the springs, so it might not be an issue.
  8. Apr 17, 2017 at 7:37 AM
    CamShaft033
    Cameron
    Chattanooga TN
    2012 DCSB TRD Sport
    Will my factory bumpstops mount up with the dakars or will I have to order new ones to mount in the frame?
  9. Apr 17, 2017 at 7:50 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Your factory bumpstops WILL mount up just fine, but they probably won't be high enough to prevent damage to your shocks when they are fully compressed.
  10. Apr 17, 2017 at 7:52 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Add a leaf is only as good as it's foundation. If you're still using the original Toyota leaf springs then you have to willingly accept the sag. Toyota leaf springs are NOTORIOUS for sagging as they age (especially with weight on them).
    You either need to put a full set of Dakar leaf springs or some other brand that's better quality than the OEM Toyota ones.
    Dakar leaf springs: Snugtop Topper + 300-400lbs of shit in the rear. It doesn't droop any.
  11. Apr 17, 2017 at 8:04 AM
    CamShaft033
    Cameron
    Chattanooga TN
    2012 DCSB TRD Sport
    That's awesome! That's what I'm going to go with. What shocks are you running?
  12. Apr 17, 2017 at 8:15 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Just OME Nitro Sport.
    Springs hold the weight. Not shocks.
  13. Apr 17, 2017 at 8:22 AM
    rooster32
    rooster32 Well-Known Member
    Utah
    2017 Magnetic Grey TRD OR DC LB
    5.29 gears 6112/5160 w/Dakar Hvy SPC UCA's 255/80/17 Wildpeak AT3 Nitro
    What do you have up front? I have a 2017 DC LB that is getting a cap this week and will be hauling camping/hunting stuff often. I'm thinking Dakars, but I'm really not looking to lift the truck much at all to avoid vibration issues and such BUT with adding the Dakars, I'd have to lift the front (OME Springs & shocks) to get it close to level right?
  14. Apr 17, 2017 at 12:21 PM
    CamShaft033
    Cameron
    Chattanooga TN
    2012 DCSB TRD Sport
    Anyone know where the best place to buy dakar springs and OME shocks is? Im looking at @ToyTec Lifts but shipping is killer.
  15. Apr 17, 2017 at 1:06 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    @HeadStrong Off-Road or none.
  16. Apr 18, 2017 at 11:06 AM
    CamShaft033
    Cameron
    Chattanooga TN
    2012 DCSB TRD Sport
    I just got the Dakar shocks with the OME nitro sport shocks as well as the u-bolts and bushing and a rear drive shaft carrier bearing kit all for 600$ from a local dealer. Do I need to use the rear drive shaft carrier drop?
  17. Apr 18, 2017 at 11:29 AM
    geekhouse23
    I did from the start. No vibrations or anything.
  18. Apr 18, 2017 at 11:30 AM
    CamShaft033
    Cameron
    Chattanooga TN
    2012 DCSB TRD Sport
    Is there any difficulty to the drop?
  19. Apr 18, 2017 at 11:34 AM
    geekhouse23
    None whatsoever.
  20. Apr 18, 2017 at 11:43 AM
    kimb8550
    kimb8550 Well-Known Member
    Denver
    2005 DCSB Off-Road
    Just a little personal experience, I added the D29XL AAL to my Dakars for extra support. I was worried about the harsh ride with only a topper and prinsu toprac on it most of the time. 3 months now and I am really impressed by the ride quality, it a little stiffer than normal but still a great ride. I would recommend adding it before installing your dakars.
