Saggy Rear End. Best option for it?
Discussion in '1st Gen. Tacomas (1995-2004)' started by PITS4LIFE, Dec 31, 2011.
  1. Dec 31, 2011 at 9:37 PM
    PITS4LIFE
    PITS4LIFE [OP] Member
    CANADA
    02 SR5 TRD
    Hey, this is my first post. Just want to say "what up." I have a 2002 Double Cab 4x4 TRD. I really love this truck. Have had it now for 2 years, and plan on keeping it for many more.
    The previous owner installed the 3" spacer lift up front. When I purchased the truck it looked pretty level. 2 years later (as a work truck, carrying tools and such, probably 100 lbs. max.), I have noticed considerable amount of sag at the rear end, about 2". I need a fix. So far I'm thinking OME/Dakar leaf pack is the answer. Can I install just the leaf packs and I'm good to go? Or do I need new shocks too? If I need new shocks, what are your recommendations? Or if there is another option?
    I'm not looking to dump a pile of dough into this, but I do use it as a work truck and put alot of miles on. I would like to keep the spacer lift up front. I want to get the rear back to level or a little higher. I'm no mechanic, but I had a look under the truck and the leafs seem to be very flattened out, and there's maybe 50 lbs worth of stuff in the box. From some research, blocks, AAL's, and shackles don't sound like the answer for this problem.
    I appreciate your help. Thank you.
  2. Dec 31, 2011 at 9:48 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    depends on how much you want to spend, OP- new leaf packs would require longer shocks and an extended brake line
    the cheaper side of the spectrum would be extended length 5100s, all the way up to top of the line resi shocks from brands like King, Icon and Fox (they'd give the best ride too, though)
  3. Dec 31, 2011 at 10:08 PM
    PITS4LIFE
    CANADA
    02 SR5 TRD
  4. Dec 31, 2011 at 10:12 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
  5. Dec 31, 2011 at 10:14 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
  6. Dec 31, 2011 at 10:50 PM
    PITS4LIFE
    CANADA
    02 SR5 TRD
    Thanks for all your help. I'm pricing everything out on Toytec.com right now.
    5100's and Eibach coils up front would be the coilover kit. Too much $ for me right now. So I think I will just stick with the rear 5100's and leaf pack.
    What do the rear 5100's need to be set at? I won't be installing these myself but want to make sure the mechanic gets a heads up.
    I think I will be buying the front 5100's for my FJ this spring.
  7. Dec 31, 2011 at 11:01 PM
    PITS4LIFE
    CANADA
    02 SR5 TRD
    Am I going to need new U-bolts, Diff Drop kit (not sure if the previous owner installed), Tailpipe relocation kit?
  8. Dec 31, 2011 at 11:04 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    the rear shocks don't provide lift on our trucks, since the back is leaf sprung- the fronts are "adjustable" because the lower coil perch for the coil can be moved. (Adding compressing the stock coil to lift the front of the truck)
    so you don't have to worry about that.
    How bad are your CV angles? Diff drops cant hurt.
    Try giving toytec a call, i'm not too sure if they include new u-bolts with the new pack
    (shouldn't need the tailpipe relocation IIRC either)
    if you order from toytec, make sure you use their TW discount as well!
  9. Dec 31, 2011 at 11:44 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
