Sags 1 inch when Trailer is on- Should I be worried?
Discussion in 'Towing' started by JonnyA, Apr 13, 2010.
  1. Apr 13, 2010 at 7:27 PM
    JonnyA
    JonnyA [OP] Member
    Jonny
    Utah
    2010 Tacoma DC Longbed
    5100's front set at 1.75, TSB, Weather tec's, Leer XR shell, carpet kit
    Any input would be greatly appreciated. I have a 2010 dc longbed with 5100's set at 1.75 in front, TSB in rear-(when just sitting there, it is a about a 1/4 inch nose high) when I hook up my tent trailer, it sags one inch. Is this something to be worried about or par for the course? Or should I look into getting some air bags or some Tibren's. Hitch weight is only around 300lbs, and the GVW is 3k-
  2. Apr 13, 2010 at 7:33 PM
    tuckr2
    tuckr2 Well-Known Member
    Western Washington State
    2010 Silver dbl cab LB 4x4 It's Purdy too!
    LT265/70/17 BFG A/T's, Disabled Seat Belt Buzzer, Black and Gray Covercraft Seat Covers front and rear, Matching SnugTop Supersport Canopy, undercoat, bed mat, window vent shades. Black Weathertech Liners. Trans TSB, Rear Spring TSB Installed.
    Won't hurt a thing. Trucks are designed to carry loads. That load will weigh down the back of the truck. If you put 300 or more pounds in the back it's gonna sag while the load is on. Once you take the load off the rig will return to it's original height.
    take care Ken
  3. Apr 13, 2010 at 7:40 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    It will piss off the cars in front of you @ night, but shouldn't hurt the truck. May want to consider lowering billies to 0.85.
    :worthless:
  4. Apr 13, 2010 at 7:51 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Your rear is lower than the front without a load on it?
    You need to either lower the 5100's closer to stock level or get an AAL for the rear.
    What's the total weight of the tent trailer?
    When you say, *hitch weight* - do you mean TONGUE WEIGHT?
    If your rear-end is sagging that badly...you're pitching the front end of the truck upwards which is BAD for steering. That's why proper tonque weight is soooo important for the best steering/safety/handling while towing. Having a poorly equipped suspension - reduces the amount of tonque weight the truck can effectively handle.
  5. Apr 13, 2010 at 8:24 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    Not OEM.
    When your trailer is hooked up, look at the bump stops on level ground and see how much clearance you have. Mine has only 1 inch clearance when fully loaded. I ordered the Firestone Ride Rites after reading all the info. on TW. If your trailer has only 300 lbs tongue weight and it's not huge, I'm thinking you'll be ok.
  6. Apr 14, 2010 at 6:12 AM
    SCOTT'S TACO LOCO
    SCOTT'S TACO LOCO Cherry
    Scott
    TEXAS
    08 TACO TRD 4x$
    Rain-X, Blue Coral Wax, After-market cigarette lighter and a Texas Tacoma sticker! and few recalls here and there. Full Throttle gas pedal mod with bulky floor mats.
    Same problem, but the tonge weight on my trailer 5X10ft. is less than 200lbs.
    thinking about adding an aftermarket leaf pack
  7. Apr 14, 2010 at 6:16 AM
    branct06
    branct06 Well-Known Member
    Thomas
    norcross Ga. and High Point Nc.
    05 4x4 black sr5 long bed trd sport
    super 40 flowmaster turned down before rear axle, k&n intake, ipod interface, 20% 3m tint all the way around, grill craft mx series grill with 2 hella 500 behind the grill, 2 55 watt halogens mounted on uws black low profile toolbox, 3'' toytec ultimate lift kit sitting on black xd monsters and 285/65/18 BFG A/T, HID headlight kit
    you should be fine
  8. Apr 14, 2010 at 7:20 AM
    JonnyA
    JonnyA [OP] Member
    Jonny
    Utah
    Yes, it is barely nose high, perhaps 1/4inch higher in the front. Yes, I do mean Tongue weight- total weight of the trailer dry is about 2200lbs..and probably close to 3000lb once wet and loaded- Is once inch of sag that bad? I towed it from where I store it back to my house a couple of days ago and it seems to be fine- I just wanted to see if it is common for such a load to sag the rear 1 inch...and if that was a big deal. thanks for input!
  9. Apr 14, 2010 at 7:29 AM
    Janster
    Jandy
    Lancaster, PA
    For some reason, I missed the 'one inch' part. :rolleyes:
    You'll be fine.
  10. Apr 14, 2010 at 7:32 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    North DFW
    07 DCSB Sport 2wd
    5100s @ 0.85, Grom iPod/Bluetooth adapter, mud flaps removed, clear turn signal bulbs, two extra D-rings, debadged, fog light anytime, OEM bed mat, Undercover classic, Falken Wildpeak A/T3W, Fumoto valve
    No.
  11. Apr 14, 2010 at 7:50 AM
    JonnyA
    JonnyA [OP] Member
    Jonny
    Utah
    THANKS GUYS!
    JonnyA
  12. Apr 14, 2010 at 10:28 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    my TT is about the same weight as yours. All I have in the back is the AALs (for now). It does the trick
