SAI issue
Discussion in 'Suspension' started by field76, Sep 11, 2013.
  1. Sep 11, 2013 at 10:16 AM
    field76
    field76 [OP] Well-Known Member
    Bozeman
    2012 PM TRD OR DCAB
    Debadged, audio upgrade, silex organizers, AVS in channel window vents, 5100s on all corners with Wheelers 3 leaf HD AAL
    Hey guys,
    got my alignment done after putting on 5100's on all corners, setting the front at 2.5 and adding a wheeler's 3 leaf progressive HD AAL. Truck drives pretty much the same way it did before the lift, that is to say it likes to pull left a bit, due to the SAI on the left wheel I guess.
    Left
    Camber 1.0
    Caster 1.3
    Toe 0.08
    SAI 10.7 this is out of spec
    Inc Angl 11.8
    Right
    Camber 0.9
    Caster 1.4
    Toe 0.10
    SAI 11.6
    Inc Angl 12.6
    Cross camber 0.1
    Cross caster -0.1
    Cross SAI -0.9
    Total Toe 0.18
    Any thoughts on what to do for that out of spec SAI on the front left? I think I will be getting new UCAs in the future because i am not thrilled with the space between the UCA and the coil at full droop, its pretty tight in there.
    thanks,
    -m
  2. Sep 11, 2013 at 10:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Camber needs to be .4* and Caster needs to be over 2*
  3. Sep 11, 2013 at 10:51 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    SAI and Included angle generally only apply if something is bent. Otherwise they shouldn't deviate from their range of specs.
  4. Sep 11, 2013 at 1:41 PM
    field76
    Bozeman
    2012 PM TRD OR DCAB
    thanks fellas, appreciate the info
