Salt Gone Any reviews
Discussion in 'Product Reviews' started by p_chinnici, Dec 23, 2019.
  1. Dec 23, 2019 at 6:20 AM
    p_chinnici
    p_chinnici [OP] Well-Known Member
    Pete
    South Nj
    2015 Trd Pro Access Cab, 2.5 Kings, Dakars
    2.5 Kings all around, HD Dakars -1 OL, Camburg Moog BJ UCA, Leer 100r topper, Prinsu rack
    GQ7227 likes this.
  2. Dec 23, 2019 at 6:38 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Sounds like a load of shit. Specialty formula it's probably just a wash and wax. Just read up on detailing and paint protection/waxing.
    Salt is water soluble, any wash will take care of it. You don't need a special chemical to remove it.
  3. Dec 23, 2019 at 7:16 AM
    cjmartin
    cjmartin Anytime, Baby!
    CJ
    Southern Maryland
    2020 White Tacoma TRD Pro
    DuraTracs 265/70R16 / BaKflip MX4 / Spiker hood struts / Gecko underhood LED lights / Various MESO Customs mods (interior chrome delete /TRD pro stealth shift knob kit / ultimate turn signals / stage 1 tail lights / puddle lights & switch / more)
    I use Salt Away (http://www.saltawayproducts.com/) on my boat, which is kept in brackish water (mid-Chesapeake bay). It's about $40/gallon, but that gets diluted quite a bit. I spray it on the boat using a cheap garden sprayer and then rinse it off. You don't need to rinse it, but it will dry streaky if you don't. Does it work? Absolutely. I didn't realize frame rust was still such a concern with the 3Rd gen, crawling around under mine to run the tallgate lock harness everything seemed painted. First Tacoma, but long time truck owner (all Chevys), never had frame issues. What am I missing? Thinking I may need to get my sprayer out of the dockbox and bring it home for the winter.
    Mayak1957, GQ7227 and p_chinnici[OP] like this.
  4. Jan 3, 2020 at 11:44 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    cannot use that when its a chilly 10 degrees F out
    never give up!
  5. Jan 8, 2020 at 3:25 AM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    I've used Salt Away for years, and I believe it works. There is a compound in Salt away (and probably Saltsgone) that strips the chlorine off of the parts being cleaned and replaces it with some more stable compounding element.
  6. Jan 8, 2020 at 6:49 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    does the Salt Away product leave any noticeable 'streaks' on the paint if you do not rinse it off before it dries with a normal spot-free rinse?
  7. Jan 8, 2020 at 6:15 PM
    Tacorific
    NE Iowa
    Can't say that I have noticed any streaks. Although I probably haven't let it dry on the paint. I don't use it on the painted outer-body. I use it on the under-side mostly. but I do squirt it down inside the doors past the window seals.
    GQ7227[QUOTED] likes this.
  8. Jan 11, 2020 at 6:09 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    salts gone looks like it worked well on the bumper
    passenger side is just a spot-free rinse at the wand wash
    driver side is salts gone spray + spot-free rinse and nothing else
    in the back...
    driver side salts gone + spot-free rinse
    passenger side spot-free rinse only
    how it looked before hitting the wand wash
    on the rear side
    before
    after salts gone + spot-free rinse
    passenger side
    drivers side
    p_chinnici[OP] likes this.
  9. Jan 11, 2020 at 7:22 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    apparently 'any wash' will not take care of it, at least not on my black paint!
    the same results i have gotten for over 2 decades, without employing the wash mit/sponge and some soapy car wash concentrate 'N elbow wrist workout
    salt may be water soluble but there is still some NASTY left behind after just a simple rinse
    Tacorific likes this.
  10. Jan 11, 2020 at 7:35 PM
    Tacorific
    NE Iowa
    I don't have experience with SaltGone but Salt Away isn't the best cleaner for dirt either.
    GQ7227 likes this.
  11. Jan 11, 2020 at 7:44 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    so the haze that is left with nothing but a rinse is just the dirt from the road spray slop :notsure:
    i have always gotten the haze with first using the soapy wand, rinse, spot-free rinse routine
    my truck was relatively clean before this wheeling adventure out into the neighborhood yesterday and today picked it up real bad on the city streets
  12. Jan 24, 2020 at 10:29 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    how do you clean your exterior paint? no sloppy taco!
    for decades the only way to get my truck back to black is to hand sponge in freezing temps, the spot free and soapy wand just has never cut it :(
  13. Jan 24, 2020 at 10:31 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    word of note, the salts gone is not best stored outside when its 0 degrees F for many days
    it was frozen sitting out in the garage in the 2 gallon plastic gas container (undiluted) i used to have a transportable supply, 5 gallon pail was heavy lol
  14. Jan 24, 2020 at 12:02 PM
    Tacorific
    NE Iowa
    During the winter, if it's above freezing, and I know the truck isn't going to freeze overnight in my attached garage, I'll stop at the "wand car wash" (where you spray the vehicle yourself) down the block. I'll rinse off the outside, and spray the underside without putting too much direct pressure on the FF. I don't use any soap, brush, or sponge, just water, and I'll finish with the spot free rinse setting, if it's available, and there is time felt on my eight quarters. I won't hose off, (or let my wife wash her car), any of my vehicles if it's going to freeze with the water still in the nooks and crannies. The most I have ever sprayed off a vehicle during the winter is maybe, four times. No, the truck won't be pristinely clean.
    I only use Salt Away once a year, in the spring, on the underside of my truck and some of the inner pan. Currently I'm using Meguir's Gold Class soap on the painted panels. But, I'll only do this if the truck has at least a day to sit in the sun to dry, so that I can touch up the FF after that.
    Now, I always put a fresh coat of good wax on my vehicles in the fall. I've used Nu-Finish for years, but there are several good ones out there.
    I also touch up the FF in the fall, but I don't put it on too thick.
    My wife and kids say that I'm anal retentive LOL, but I guess I'm not quite as anal as you are, (no disrespect meant), but my truck isn't black either.
  15. Feb 2, 2020 at 9:20 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    a Salts Gone product result will be coming soon!
    have a bright red 2nd gen full of Iowa salt spray to clean
    it was also sprayed with CF 3000 around the tailgate area that looks to be interesting as well
  16. Dec 19, 2020 at 5:00 AM
    SilverSkyTRD
    SilverSkyTRD Well-Known Member
    Anyone have any updates on how this product works?
  17. Feb 19, 2021 at 1:18 AM
    sixdoubleseven
    sixdoubleseven Well-Known Member
    Dave
    Boston
    14 DC 4x4
    Bumping this to see if any other members are using this stuff and how the results have been.
  18. Mar 21, 2021 at 7:07 PM
    Tacorific
    NE Iowa
    Just an update: I'm still using Salt Away and still happy with the results. I plan on using my relatively new borescope to take some pictures of the insides of the frame cavities and door cavities. I'll try to remember to post some if the photos here.
  19. Mar 21, 2021 at 7:08 PM
    Quality Taco
    Quality Taco Es tu Papi Papi
    Oscar
    Minnie Sota
    03 DCCB trd
    Big brake tundra upgrade, Carhartt seat cover.
    I probably need this since I live in Minneapolis
