Salt water in drum brakes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jacobp393, Aug 29, 2020.
  1. Aug 29, 2020 at 6:25 PM
    Jacobp393
    Jacobp393 [OP] New Member
    Jacob
    2020 Tacoma TRD Off-Road
    Hi all,
    I had to launch my jet ski in saltwater the other day. Truck went in water half way up the wheels and sat in the water for about 5 minutes or less while unloading. Drove home and set the parking brake like usual. Next morning my back tire was locked up so bad I had to use 4Lo and the Diff locker to get free. (Only driver rear was locked up passenger rear spun on pavement which is why I used diff lock) Finally the brake broke loose and made a terrible sound while doing so. I was able to drive like normal. My question is, does anybody else drive in saltwater, does anybody else have this problem, and how do I prevent it? Should I not set parking brake until I drive truck around enough to heat brakes? Thanks any advice appreciated!
  2. Aug 29, 2020 at 6:32 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Never been in Saltwater.
    But I did have my E-brake freeze on me.
    We have a a place where we can back into a creek to fill up water tanks. (Cattle)
    Only fix is to not use the brake and chock the tires.
    If it happens again try going back and forth and see if it frees up easier.
  3. Aug 29, 2020 at 6:40 PM
    s4nsc
    s4nsc The chicken stays…
    St. Augustine, FL
    2024 GMC Sierra AT4X
    Did you rinse the saltwater off when you got home? Saltwater will corrode even low grade stainless, imagine what it does to regular steel.
    I rinse every time I drive on the beach.
  4. Aug 29, 2020 at 6:42 PM
    AntMan408
    AntMan408 Well-Known Member
    Bay Area, CA
    2021 Toyota 4Runner off-road, 2022 Tacoma Offroad
    4runner: King Shocks Front/Rear SPC UCA’s SPC rear control arms Icon Rear Springs 52700 Icon Panhard Bar SCS 10’s RCI Skids and Sliders CBI Baja Bumper w/Diode dynamic lightbar RCI Roof Rack Tacoma: King Shocks Front/Rear Camburg UCA’s Deaver Expedition Stage 1 Leaf Pack SCS Gen 5 RCI Skids RCI Sliders BAMF Hybrid Bumper RCI Roof Rack
    Next time do the same exact thing. However when you get home take a hose and rinse off everything that made contact with the salt water and you’ll be fine.
    Chew and s4nsc like this.
  5. Aug 29, 2020 at 6:46 PM
    TnShooter
    Deogee
    STOCK
    Serious question.
    How are you getting water inside to drum assembly to rinse the e-brake lever and springs?
    I live in the South, we don’t have much rust issues here.
    I haven’t ever really rinsed anything.
  6. Aug 29, 2020 at 6:55 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    I would avoid driving a vehicle into salt water. It is very corrosive and difficult to clean from all the nooks and crannies.
    Chew likes this.
  7. Aug 29, 2020 at 8:14 PM
    Jacobp393
    Jacob
    I rinsed off entire undercarriage with pressure washer (at a decent distance as to not hurt anything) however it doesn’t seem like any fresh water got into the drum to clean it out. Thanks for the replies
  8. Aug 29, 2020 at 8:15 PM
    Jacobp393
    Jacob
    I also have heard a lot of good things about “salt away“ so I have that on the way as well. Might focus a little more on spraying the drums down next time around. Could take drum apart and clean inside but that sounds like quite a bit of work!
  9. Aug 29, 2020 at 8:33 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    dont set the parking brake as ' usual '
    what happens is very close to the tongue on the frozen road side pole
    in winter its worse
    many first response vehicles DONT set parking brakes overbite............. Company Policy !!
    on call outs cant ahve hobbled vehicles or the time to take to remedy
    Jacobp393[QUOTED][OP] likes this.
  10. Aug 30, 2020 at 5:28 AM
    CTF
    CTF Well-Known Member
    2017 TRD OR
    Find a freshwater lake. Back in for 5 minutes. Problem solved.
    :crapstorm:
  11. Aug 30, 2020 at 5:35 AM
    Clearwater Bill
    Billy
    Largo Florida
    Do not submerge your drums in salt water.
    If you do, disassemble them, hose out and lubricate the points that are normally lubed, wash the drums (they are just cast iron) inside and out.
    Hopefully your trailer has Buddy Bearings that you keep lubed.
    s4nsc and Jacobp393[OP] like this.
  12. Aug 30, 2020 at 5:45 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    They're not 100% water tight, especially if they're sitting submerged. They'll keep the bulk of mud and stuff out and splashes of water, but submerging them is the difference here.
  13. Aug 30, 2020 at 5:48 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Bingo!
    Yes salt water is corrosive, but you bought your truck to use it like a truck. Just hose down the rear axle/suspension frequently and lubricate the drum brakes every couple of years.
  14. Aug 30, 2020 at 6:29 AM
    Clearwater Bill
    Billy
    Largo Florida
    Hosing down after submersion does nothing for the drum internals, the wheel studs/inside lugnuts or the drum where the wheel mates.
    Not to mention if submerged above the axle vent and a reroute has not been done.
    Truck or not, folks who live and boat in salt water and care for their vehicle rarely even get the edge of the wheel wet, using just the tire in the water.
  15. Aug 30, 2020 at 8:11 AM
    Raeburn
    Raeburn Well-Known Member
    2017 ORDCSB
    Wonder how much salt spray gets into the drums during regular winter driving on salted roads. No way to fully rinse out without disassembling. Would hope the brakes are designed to handle some salt exposure.
    The sticking parking brake is a common thing, fresh water or salt water. I've had the same problem after launching my boat at the lake. Truck sat for three days with parking brake on. Had to use 4-lo to break free and made a loud clunk. Runs fine now. No longer set the brake after launching...
  16. Aug 30, 2020 at 9:36 AM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    I’ve launched in saltwater hundreds of times. Been boating in Florida since the mid 70’s. I always take and “dunk” boat and trailer in the freshwater lake boat ramp on the way home. My trailers still look new. Rinsing will help but only slightly. When hubs are submerged in water it gets into places hose rinsing doesn’t get to. I definitely will not drive a vehicle I own in saltwater, even rinsing. I like my truck.
    Bleep100 likes this.
  17. Aug 30, 2020 at 12:45 PM
    FLA_Hoosier
    FLA_Hoosier Well-Known Member
    Rick
    Space Coast
    2017 White TRD Sport AC
    There are posts of this happening after a simple car wash; not just a salt water or submerging thing.
  18. Aug 30, 2020 at 6:51 PM
    ROAD DOG
    FEW
    never set the hand brake............allows a clearance between drum & shoe
    rinsing helps
    dunking helps
    yet when U put cast iron directly against ' metallic ' shoes + salt
    U have 6th grade chemistry success
    Raeburn likes this.
