Salt water in fuel system
Discussion in 'Technical Chat' started by welderdustin, Aug 14, 2020.
  1. Aug 14, 2020 at 7:45 PM
    welderdustin
    welderdustin [OP] Member
    2014 4.0 Tacoma 270000km
    Went out fishing with a friend for a few hours. When we returned to shore and loaded our trucks I noticed my fuel tank door was open but cap was still in place. Thinking nothing of it, I closed the filler door an started to drive home. I only made it about a kilometer and the truck quit. It was like a fuse blew. It wouldn't restart. It just wound over with no sign of kicking. I listened for the fuel pump and there was nothing. First I checked the relays, all good. So I just figured it quit and would need to be replaced. The next day I checked to see if there was power going to the pump and it was. So, I dropped the fuel tank and had my local mechanic bench test the pump. It was toast. I drained the tank completely and made sure it was very clean. Put in the new pump and filled with new 91 octane gas. Tried to start the truck multiple times but no dice. Same as before. It just turned over with no sign of a kick. Mechanic came to my house and hooked up code reader. No codes. He suggested pulling a plug to check for spark. Did that and there was a spark, but it was orange not blue. He said must be bad fuel and plugs could be fouled. That's when I remembered the fuel tank door being open at the harbour. Someone must have put something in my tank when we were out on the boat. it was likly salt water. So the fuel lines were full of bad fuel that would have cycled through the fuel system and back into the fresh gas I just put in the tank. I pulled the return line at the tank and cycled the pump using the ignition to drain the remaining fuel in the tank. I put in 1 liter of methol hydrate and about 10 liters of gas. I cycled the fuel pump again multiple times to get the good gas to the motor. Now it will kick a bit and shows some sign of life. I am going to put new plugs in tomorrow. Hopefully they will help get the truck started.
    I am pretty discussed in what took place and I have no idea why (or who) would have done this to my truck. But now I need advice on how to proceed in fixing my truck. What should I do if the plugs don't solve my problem. From what I understand there is no fuel filter to change. What else should I look into?
    Dustin
  2. Aug 16, 2020 at 5:56 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Injectors !! The Saltwater will cause the steel fuel lines to rust past the fuel filter.
    Moving fuel pushes rust to injectors causing interesting spray or clogs them completely .
  3. Aug 16, 2020 at 7:10 AM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    I’d remove the fuel flush, twice as long as you think you should, with R.O./DI water. This will remove all of the salt.
    Throughly dry by flushing with methanol. The after you have removed as much methanol as you can refill with fresh fuel.
    It’s a lot of work, but as the saying goes. “You pays me now or you pays me later”. Later usually costs a lot more.
  4. Aug 17, 2020 at 10:39 AM
    welderdustin
    Thanks, I flushed the lines a couple times and cleaned the tank. Filled up with premium gas and added a can of sea foam and some Lucas Injector cleaner. I drove it for a day then changed the oil. Its running better now.
    SR-71A likes this.
  5. Aug 17, 2020 at 12:51 PM
    JEEPNIK
    Have you bought a locking cap?
  6. Aug 17, 2020 at 12:56 PM
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    yellowdogpaddler likes this.
  7. Aug 17, 2020 at 1:27 PM
    welderdustin
    Seriously considering it.
  8. Aug 17, 2020 at 1:29 PM
    welderdustin
    Thanks, I didn't see this when searching. I guess I was being too vehicle specific even though they basically operate the same.
  9. Aug 17, 2020 at 4:14 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Pissed off former Love Interest??
    Someone jealous of you or your truck??
  10. Aug 17, 2020 at 4:20 PM
    verynearlypure
    verynearlypure Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
    Mistaken identity? Locking gas caps only keep honest folk out imo. Sorry OP I’d be pissed. Any luck on camera surveillance in the area?
    SR-71A likes this.
  11. Aug 17, 2020 at 4:44 PM
    JEEPNIK
    All locks from a dime combo to a time locked vault only keep honest people out. They just make it harder and more time consuming so hopefully the miscreant will loose interest and find another targe.
    doublethebass likes this.
  12. Aug 17, 2020 at 5:14 PM
    verynearlypure
    Ernest
    The Buckeye State
    Look at Dad on the lock synopsis. It goes back to my original statement, but thank you for the elaboration. @OP any luck on video?
  13. Aug 17, 2020 at 5:54 PM
    welderdustin
    I have no idea who messed with it, but I'm a firm believer in the saying: What goes around... comes around.
    From the video I learned that sugar doesn't dissolve in gas. Which surprised me. Also learned a method to clean injectors.
  14. Aug 17, 2020 at 6:00 PM
    welderdustin
    Your right about the locks. If I lock the fuel cap they might damage the windows, tires, paint, etc. Hopefully they have moved on. I contacted my insurance company, i may be able to recoup some of the cash I had to dish out.
  15. Aug 17, 2020 at 6:03 PM
    welderdustin
    I'm not aware of any bad blood. I figure it was random or like you suggested, a jealous act. I may never know.
  16. Aug 17, 2020 at 8:22 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    water at the injectors is like pissing sand
    start at 1 end & clean back towards tank
    some say filter............... some say not
    im not familiar with every model..................i would have engineered a filter somewhere
    good luck
  17. Aug 17, 2020 at 8:35 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  18. Aug 18, 2020 at 10:33 AM
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    Nah man, I had "sand" lmao
