Salted roads... frame prep?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ThunderOne, Jan 19, 2016.
  1. Jan 19, 2016 at 8:13 PM
    #41
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Oh man...I avoid used oil like the plague. It's toxic both to the environment and handler. You only need a couple of quarts and G-oil is cheap. Plus, used oil contains moisture and does not work as well. Oil works because it is an insulator to keep rust from occurring. Used oil works, but not as well because of the non insulating contaminants in it.
  2. Jan 19, 2016 at 9:28 PM
    #42
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    I juuuust moved here a couple of weeks ago, so I don't know any good trails. I've heard about the Land between the lakes sounds fun. My grandpa owns a few hundred acres of land that he hunts on and there's pretty knargly unkept trails there. But I got to fix my 4WD first. Once I do that, I'm down to do some trail ridding.
  3. Jan 19, 2016 at 9:54 PM
    #43
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I'm sure what ya did will work just fine. :thumbsup:
  4. Jan 19, 2016 at 10:15 PM
    #44
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Yep, I do this too and haven't had any problems. Cleaned oil and grease off of 50 year old frames and the metal looks perfect underneath while the rest of the vehicle leaves lots to be desired in many cases. I've injected oil inside my frame twice now and feel pretty confident she'll last a long time. The outside I just keep clean, it has that undercoating crap on it from Toyota so there's not much point in applying oil there.
  5. Jan 19, 2016 at 10:48 PM
    #45
    ThunderOne
    ThunderOne [OP] Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I've been here about 6 months. But haven't found much in the way of wheeling spots. Most of the OHV parks are at least two hours away. I'm guessing there's closer "locals" spots somewhere around here!
    DustStorm4x4[QUOTED] likes this.
  6. Jan 19, 2016 at 10:49 PM
    #46
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Well if it's ever pitch black outside, I'll be able to find my truck simply by the smell it radiates LOL
  7. Jan 19, 2016 at 11:05 PM
    #47
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    I live in WI and we use lots of salt for 4-6 months of the year...
    I wire wheel the rust spots and touch it up with paint a few times over the summer....
    This fall after my last touch up I sprayed the whole frame with fluid film....
    It's a little bit of work but it's worth it..
    My 2010 frame looks like new and most used trucks, runner FJs have rust everywhere and look like crap....
  8. Jan 20, 2016 at 7:13 AM
    #48
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Welp, time for product testing!
    096C1511-6472-4D98-8674-AD172FA88D1D_zps_358ec0c63c462c704d733448a4ad8f699c5c287e.jpg
    DustStorm4x4 and Assforkr like this.
  9. Jan 20, 2016 at 7:16 AM
    #49
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Yeah itl stink for a couple weeks
  10. Jan 20, 2016 at 7:20 AM
    #50
    amalik
    amalik Well-Known Member
    Denver
    Amazon has that 3M rust fighter at $36 for a 30oz bottle!
    Are you suggesting hundreds of dollars on just the 3m product? Not saying it isn't the best out there, but sheesh!
  11. Jan 20, 2016 at 7:22 AM
    #51
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    How do the other makes and models hold up in your experience?
  12. Jan 26, 2016 at 1:28 PM
    #52
    Tjsingle26
    Tjsingle26 Well-Known Member
    Tom
    PA
    03 Tacoma xtra cab 4x4
    Sorry to bring up a 6 day old thread, but I have a question about fluid film. Does fluid film trap road salts?
    I coated my frame with KBS Rust Seal on the outside and Cavity Coater wax on the inside of the boxed frame section. I accidentally missed a small spot and I wanted to protect it against rust!
  13. Jan 26, 2016 at 2:56 PM
    #53
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    http://www.linexofmv.com/fluid_film_undercoating.php
    I would say clean off the exposed, untreated area of salt before applying.
  14. Jan 15, 2018 at 7:22 AM
    #54
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    coming back to this, any tips for coating the TOP of the frame with fluid film? I've used the little 360 degree attachment nozzle to do the inside of the frame rails, but not sure how to do this top. Maybe get the kind in a gallon bucket and use a brush? :notsure:
    FYI, here's the little 360 degree dude. Puts out a LOT of pressure. Also, a bitch to keep it on the can while using. Very messy.
    https://www.amazon.com/Fluid-Film-Spray-Extension-Wand/dp/B00CLUGXFI
  15. Jan 15, 2018 at 7:35 AM
    #55
    tony2018
    tony2018 Well-Known Member
    lift cab on 4x4 wood, paint away.
  16. Jan 15, 2018 at 7:35 AM
    #56
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    when I do oil I'm using a standard spray nozzle from an air sprayer. not rattle can, but air compressor type. the fan pattern works and I even hit the underside of the body and that drips a little back to the frame.
  17. Jan 15, 2018 at 7:43 AM
    #57
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I used 4 cans last night and probably could have used 2 more. But really all I need to focus on at this point is the tops. Maybe I should spray some on a towel and wipe the top of the frame?
  18. Jan 15, 2018 at 7:50 AM
    #58
    vettehigh
    vettehigh Tacoma Tank
    Jon
    Upstate, NY
    Krown...had it done 2 months ago
  19. Jan 15, 2018 at 8:45 AM
    #59
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    If you have more than one vehicle, and access to air compressor, I recommend the Fluid Film sprayer, and either a gallon or even 5 gallon bucket of fluid film. After getting my replacement frame last summer, I did just this. It is a bit of an up front investment ($270), but the equipment works great, especially the 360 degree spray head on the end of a 3 foot extension. You can cover all of the boxed areas of the frame, and lots of other almost inaccessible areas too. I did a total of five vehicles, and used less than a gallon of fluid film (and I was not stingy with it). It is very clean to apply, compared to oil, wd40, or other more liquid coatings; no dripping. New York State is now testing it. Was out driving last evening, and they were spreading salt on a perfectly dry road, and no snow predicted for days. My tax dollars at work!!
  20. Jan 15, 2018 at 9:13 AM
    #60
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    www.weather.com
    there's been snow/ice predicted for days ;p
    actually it's snowing here right now and that band looks like it should be hitting you soon
    Seagull233[QUOTED] likes this.
