Salted Roads in New Hampshire
Discussion in 'North East' started by 757 Taco, Jan 7, 2013.
  1. Jan 7, 2013 at 3:21 PM
    757 Taco
    757 Taco [OP] StormTrooper
    Tyler
    East Haven, CT
    2012 DCLB TRD Sport 4x4 Super White
    - Digital Fit WeatherTechs - Recovery Hitch Shackle - Tinted Windows 20% Front, 5% Rear Window - White 48-LED Dome Light - Two 12-LED Map Lights - Sylvania Silverstar Ultra Headlight Bulbs - LED License Plate Bulbs -20" LED Lightbar - 886 Reverse Light Mod - FogLight Anytime Mod - AFE ProDry S Drop-In Air Filter - OME 885x Coils w/ Bilstein 5100's @ 0" - Rear Bilstein 5100's - Wheeler 1.5" Progressive AAL - TRD License Plate Brackets - Front Recovery Shackle - Black LED Tail Lights - Toyota Bed Mat - LED Third Brake Lights - Sockmonkey Bedside Decals - 285/75/16 Goodyear Wrangler Duratracs - Procomp 7089's - Rear Diff Breather Mod - FlyzEye V1 - Grillcraft w/ FJ Emblem - Removed Sway Bar - TRD Auto Shift Knob - TRD Offroad Transmission Skid - Hose Clamp Mod
    I just graduated cg basic and got orders to the Coast Guard Cutter Reliance, a 210' cutter based out of Portsmouth, New Hampshire. Im born and raised in SE Virginia and not really used to the effects of salted roads in the NE. How worried should I be about it? Im pretty good about getting under the truck and spraying it down just not sure if thats gonna cut it up there. Any advice?
  2. Jan 7, 2013 at 3:32 PM
    snoope
    snoope Well-Known Member
    Ft.myers,FL
    2003 Lexus ES300/2004 Lexus 330 AWD
    I have lived here for more than 40+ years and if you "keep up" with them,any vehicle will last...Car washes are a-plenty and you have a few GREAT ones over off from Islington Street....near the malls...
    Yes , TOYOTA has been "Nailed" for frame rot BUT everything will turn to "Junk" if not protected...not just Yota's...ask my Jeep friends :p :D
    Hell ,man you "Live & work" on the salt water...you don't take care of that boat...where you going ??? ;)
    Welcome to TW and NH...just up the road in Dover...
    Thank you for serving and protecting US.A.
  3. Jan 7, 2013 at 6:42 PM
    757 Taco
    Tyler
    East Haven, CT
    Thanks for the advice. Anyone else have input
  4. Jan 7, 2013 at 6:47 PM
    bmpskir
    bmpskir Well-Known Member
    Dover, NH
    2010 TRD sport DCLB 4.0 auto
    just wash it regularly and you will be fine... been in NE snow country my whole life and none of my stuff rusts when I own it... it is all about maintenance... welcome to the area! if you can park in a garage all the better!
  5. Jan 7, 2013 at 7:43 PM
    757 Taco
    Tyler
    East Haven, CT
    good to know. doesnt seem as bad as i thought as long as you take care of it which im good at
  6. Jan 7, 2013 at 7:47 PM
    bmpskir
    Dover, NH
    yeah - I always try to run it thru a wash after a storm - after the roads are clear and dry... get the salt off vs let it sit there... same idea as bird poop to me...
  7. Jan 7, 2013 at 8:30 PM
    jdkilroy
    jdkilroy Well-Known Member
    Jon
    Southern NH
    '02 4x4 SR5 Access Cab
    Lived in NH all my life: The most important part of washing in the winter is the underbody wash. If automatic, pick the cheapest with the underbody wash but you will be better served to show up with a handful of quarters and do it yourself.
  8. Jan 8, 2013 at 10:08 AM
    757 Taco
    Tyler
    East Haven, CT
    Thanks for all the help guys. I'm not quite as worried about it anymore. I'm super picky when it comes to cleaning the truck so I should be alright
  9. Jan 8, 2013 at 10:12 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    If you can coat your frame with a protectant before the rust starts, you will be better off. Otherwise, just keep up with car washes and touch up the frame when you to see rust start to form and you'll be good to go. That being said, the road salt will also work it's way into everything else, like the rear drums, it will cause some exposed bolts to rust in place so you just need to be mindful of that.
  10. Jan 8, 2013 at 10:14 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    for under the truck washing in winter time use one of these
  11. Jan 8, 2013 at 11:44 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    yes underwash alone should do it, and if in 4 years you still have the rig, inspect
    for problem areas underneath (there should not be any flaking, just areas you
    know have more rust than other areas) and then attack with the cleaning and
    coating with por15 the rust-proofing goop for real....
    FWIW...I have a 1999 4runner LTD I have owned since new in 98, kept in Maine, NH, and Mass, >200,000 miles,
    and have absolutely -never washed it- and it's role was a snowbank smasher...so I have
    packed more rust causing crud up in there and let it fester than most peeps....
    and only now in 2013 do I worry about the pumpkin rust or frame rust. swaybar endlinks have come and gone,
    I am on my 4th set of 4...rear shock tops rusted off twice now (it is a design feature of 4runners, the shock top
    sits in a cup which holds water) My tow hitch bottom is rusted clean out, but the frame is OK, and axle and
    pumpkin...well...it shows flaking now...time is getting near the end for this thing...but i beat the hell out of it
    anyhow, this is with 14 years of abuse. you will be OK to simply hose it down...I never did :D
  12. Feb 2, 2013 at 3:19 PM
    NHGuy
    NHGuy Member
    Joe
    Nashua, NH
    2013 Limited w/Chrome Package
    First post...you've nothing to worry about if you take it through a car wash once a month or so. Once a month for my vehicles is the norm and I've lived in NH my whole life (I'm in my late 40s).
    For reference - I just bought a 2013 Tacoma and just got rid of a 1991 Toyota Pickup (no models then). 22 years old with 244,000 miles on it and never garaged. The frame was still in great shape. Sure it showed signs of rust but guess what? I donated that and another vehicle (2001 SAAB 95 with 209,000 miles + brand new tires) to NHPR and at auction the SAAB didn't sell but my truck did, for $1250. You'll be fine!
  13. Feb 2, 2013 at 5:54 PM
    757 Taco
    Tyler
    East Haven, CT
    Thanks for your help!
  14. Feb 2, 2013 at 6:40 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    Aim-ish country PA
    Make: Chevy Model: Pile
    Yes
    If you live in Jersey. :rolleyes:
