Salvage old diesel fuel (heating oil) that has been seating for many years.
Discussion in 'Garage / Workshop' started by egres, Nov 15, 2018.
  1. Nov 15, 2018 at 1:58 PM
    egres
    egres [OP] Well-Known Member
    DELCO PA
    13 singel cab - 2WD - manual - 17K before tax:)
    Bench-seat covers $180 (Can't believe its not leather),Bed Liner $375 (Bed rug), Roof rack $180 (Rhino-rack 2500 Series, plus DK clamps and pads), Modified Bed extender $85 (Extend-A-Truck 944 Truck Bed Extender), Hood lift assist $80 (RedlineTuning), Hood light $53 (tacomaworld.com âtacodaneâ), Hitch receiver $120 (Curt Manufacturing 13323 Class III Receiver), T connector for trailer $43 (CURT Manufacturing 55513 T-Connector), Manuel tailgate lock $30 (gatekeeper tailgate lock), Tailgate assist $28 (Sachs SG329900EZ Lift Support), Tailgate lock $67 (Pop & Lock Tailgate Lock Tailgate Lock PL5301), Spare tire lock $12 (Trimax ST30 Trimaflex Spare Tire Cable Lock), Hardwired battery float charger $20 (Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps) , Vin # Glass etching $33 (vinguard.org), Easy oil drain plug $30 (Fumoto Engine Oil Drain Valve), Floor mats $80 (Husky Liners 2-Piece Front Liner 2-Piece Front Liner), out of space :)
    My bud has about 100 gallons of heating oil that been his basement for many years.
    I want tank that diesel is in and he wants to get rid of the old diesel. Does not look like it has a growth in it, and its probably old school sulfur stuff.
    Is there chemical (diesel restorer) that I can use to rejuvenate it?
    Plan is to use it in forced air heater: Dyna-Glo Forced air Heater, 135,000 BTUs
    Thank you
  2. Nov 15, 2018 at 6:34 PM
    dofartshavelumps
    dofartshavelumps Well-Known Member
    NH
    2015 SR DCSB 4x4 4.0 MT
    Honestly I would use Kerosene in the heater, the diesel will work but will smell/smoke a little more - if you are heating a barn then I wouldn't care too much, but something attached to a house I wouldn't bother - just my opinion. I put power service brand? I think that's what it is when I fill my diesel for the tractor. There is also stuff called sludge solve or something similar that will thin it out if need be, I put that in my home heating oil tank right before a fill up and it has helped out. I get it at Home Depot. Possibly find someone with an old 7.3 power stroke or 6.2 chevy diesel or older diesel farm equipment and do some horse trading as I think they love that older fuel.
  3. Nov 15, 2018 at 6:38 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Burn that shit!
  4. Nov 24, 2018 at 9:28 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If it is dyed diesel the dye in your space heater will run you out of the shop your eyes will water your throat burns.
    If you don`t mind that by all means fire it up
  5. Dec 3, 2018 at 1:11 PM
    egres
    DELCO PA
    So I tested it in the garage and it burns good.
    You right about eyes burning, but it's only when you right upon heater exhaust.
    All that talk that fuel goes bad, but this stuff is like 20 years old and it burns.
    Let's see if it's clogs up the heater.
    Thank you all.
  6. Dec 3, 2018 at 1:16 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Diesel and Kerosene are a lot more stable than Gasoline, especially the older stuff from before the Ultra-low sulphur era.
  7. Dec 4, 2018 at 2:16 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    '06 RC, 4X4, 5 speed
    It probably helps immensely that it was stored in a basement and not outside. Make sure you have some good ventilation wherever you're using the heater. And when you're offloading it from your friend's tank, pull off the top as much as possible to avoid phase separated water and sludge at the bottom.
    #2 is very stable, which is why it persists in people's underground tanks even after they switch to another heating source. Tanks finally develop a leak and rainwater/groundwater displaces the fuel into their's and their neighbors' backyards. Messy and stinky. Glad you found a good use for it.
  8. Dec 4, 2018 at 6:18 AM
    ecoterragaia
    Central Virginia
    Edit:. Whoops, I had a long response because I thought the question above was from the OP regarding the old fuel.
    @06Tacooo
    You can try it if the heater is rated for indoor use. I would buy some CO and CO2 detectors if I were you. They're relatively inexpebsive.. Also make sure the wick is fresh and installed and aligned correctly or you won't get a good hot burn to get rid of the fumes from unburned hydrocarbons.
