same ole lift question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by reece13, Jul 25, 2011.
  1. Jul 25, 2011 at 7:47 PM
    reece13
    reece13 [OP] Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    hey guys, i know the whol bilstien lift questions have been beat to a pulp but i got a ?. I was wanting to do a small lift without messing with the uca's or diff. drop so i was thinkin about putting bilstiens up front @ 1.75 and getting a 1.5 aal for the rear ( i dont have tsb) and keepin the stock 17" sport rims with bfg's on for now...havnt seen many people with this setup, so wouldnt it set pretty level after the rear settles??? anyone else running this setup?
  2. Jul 25, 2011 at 7:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You could probably run the fronts at that height, and no lift in the rear for a level ride. Measure the rear height, then the front, and see what the diff. is. That will tell you how high to go up front, and how much lift in the rear for a level ride.
  3. Jul 25, 2011 at 7:56 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Yea that 1.75" up front will get you pretty darn level with a stock rear. If you like the raked look(i do) then do the rear lift too.
  4. Jul 25, 2011 at 8:00 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    i have this setup and my rear looks higher then the front .
    i doesn't bother me and its not extremely higher just a little
    i also have stock uca's and no tsb
  5. Jul 25, 2011 at 8:04 PM
    reece13
    North Carolina
    ok thanks for the input
  6. Jul 25, 2011 at 8:18 PM
    reece13
    North Carolina
    if anyone else has pics of this setup or wants to put in their .02, be my guest...i just measured the diff. between front and rear of my truck and it seems that 1.75 set at front would level it out pretty good..(then again i have 100k on my stock suspension since its 2005
