San Antonio
Discussion in 'Texas' started by LostHusker, Feb 14, 2011.
  1. Jan 8, 2019 at 1:03 PM
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
    You know it
  2. Jan 8, 2019 at 1:04 PM
    DJ KRAZY K
    DJ KRAZY K Well-Known Member
    NM
    '15 TRD OFF ROAD 4X4 V6 Manual
    OME 886+Dakars, ARE Shell, ARB Front Bumper+Winch
    Hey head up to SA tomorrow. Need to take the truck to a dealership for them to check out my clutch, any recommendations on which one?
  3. Jan 8, 2019 at 1:06 PM
    LostHusker
    LostHusker [OP] Just one day at a time
    Mark
    South, TX
    2021 F150, 2015 T4R
    I’ll take your days and you can work for me at my job?
  4. Jan 8, 2019 at 1:07 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Whats wrong with the stock one? I recommend a URD stage 2 if you don't ever plan on going forced induction. Or stage 3 (like I have) if you ever plan to supercharge. Both should hold the power, but the stage 3 gives you a bit more head room.. If you need help changing it, I can help, I have tools. Just put one in my 6spd about two months ago
    Also recommend the URD/PDM stainless steel sleeve for the quill that goes around the trans input shaft. The chirping of the TOB is often caused by the TOB being side loaded and then it riding on the quill sideways, causing it to chew grooves into the quill
  5. Jan 8, 2019 at 1:07 PM
    LostHusker
    Mark
    South, TX
    2021 F150, 2015 T4R
    I would choose north park, but that’s just due to knowing a couple of the techs there
  6. Jan 8, 2019 at 1:08 PM
    BassAckwards
    I would personally avoid the dealer at all costs! (unless the truck is under warranty still, but they will likely say a clutch is a wear item if it's slipping, and wont cover it)
  7. Jan 8, 2019 at 1:15 PM
    DJ KRAZY K
    NM
    Yeah, it’s still under warranty... and I have asked a couple dealers about it before so I am hoping that the history of that will account for something. The clutch just doesn’t seem to catch very well and I can hear a significant change in noise when the clutch is in versus out. One dealership said the throw out bearing and others said they don’t hear shit so... idk wtf it is.
  8. Jan 8, 2019 at 1:17 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Don't tempt me I honestly don't like the short hours I'm use to slave work
  9. Jan 8, 2019 at 1:20 PM
    BassAckwards
    When you are cruising along at a lower speed, say 35-40mph, shift into 6th and floor it. If it lugs down, your pressure plate is still good. If the RPMs sky rocket and the truck doesn't accelerate, then the pressure plate needs replacing. I am thinking once you do this test, if the pressure plate is good, then the problem is likely the TOB. I have heard about the TOB being replaced under TSB's, so if a dealer thinks that's the issue and they want to fix it (under warranty/TSB), I say let em go for it. If it ends up being the pressure plate, its best to replace the TOB at the same time while you've got the tranny out. Either way, it's a relatively straight forward fix, just extremely labor intensive. But, if it does end up being the pressure plate and you want to try and tackle it yourself, I am down to help. Not a difficult job by any stretch just a lot of work
    Here's a thread I made recently that shows everything that has to be done for a clutch and TOB replacement. It took me 23-25hrs total from start to finish..
    https://www.tacomaworld.com/threads...lightweight-flywheel-install-write-up.577836/
  10. Jan 8, 2019 at 1:21 PM
    BassAckwards
    What kinda work did you do before picking up the little fawkers?
  11. Jan 8, 2019 at 1:21 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Dem fawker wanted to charge me 650 to change the brake booster out I'm like yea I'll pass I got one at autozone for 160 and did it myself only problem is I can't get all the air out of the system I tryed 4 times already I gave up
  12. Jan 8, 2019 at 1:21 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Deliver medicine 3 days a week 7:30 to 1am
  13. Jan 8, 2019 at 1:21 PM
    BassAckwards
    Are your brakes spongy? I have a vaccum bleeder hand pump if you want to borrow it and try again
    LostHusker[OP] likes this.
  14. Jan 8, 2019 at 1:22 PM
    BassAckwards
    Ahhh, yes, I remember you telling me this
  15. Jan 8, 2019 at 1:22 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Yes they are I got use to it already I get in somebody car abd I think something wrong lol
  16. Jan 8, 2019 at 1:23 PM
    BassAckwards
    Ha well damn, that doesn't seem safe. Let me know if you ever want to borrow my bleeder.. If I had more experience bleeding brakes, id offer to help, but I don't wanna screw that up lol
  17. Jan 8, 2019 at 1:24 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    I bet you have more experience then I do lol
  18. Jan 8, 2019 at 1:26 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Sunday Monday Tuesday after my bus run I take off to Austin and drive around everywhere till 1am
  19. Jan 8, 2019 at 1:27 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    It's 450 a week to just drive around so I'm not bitchin
  20. Jan 8, 2019 at 1:27 PM
    BassAckwards
    Do they cover your gas
