San Antonio
Discussion in 'Texas' started by LostHusker, Feb 14, 2011.
  1. Jan 8, 2019 at 1:28 PM
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
    Hell no but the car I drive gets 56 mpg 20 dollars does all 3 days
  2. Jan 8, 2019 at 1:29 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    haha not much.. I have experience bleeding the clutch, but brakes, not so much.. could probably do it in a pinch if I had to..
    When bleeding, did you start with the passenger rear drum? You should go in this order:
    Passenger rear, driver rear, passenger front, driver front. The idea is to start furthest away from the master and then work forward
  3. Jan 8, 2019 at 1:30 PM
    BassAckwards
    haha prius?
    LostHusker[OP] likes this.
  4. Jan 8, 2019 at 1:31 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Yes I've tried it I read the how to.bleed brakes fourm on here I think the problem is I'm not paying somebody to do it
  5. Jan 8, 2019 at 1:31 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    I used to make my own brake lines
    Still have double flare kit
    Somewhere
    In a toteo_O
  6. Jan 8, 2019 at 1:32 PM
    BassAckwards
    Haha the problem I encounter is that I refuse to pay someone to work on my truck.. I will struggle and curse for hours before I let the dealership work on it
  7. Jan 8, 2019 at 1:33 PM
    BassAckwards
    You make stainless lines with PTFE inners?
  8. Jan 8, 2019 at 1:36 PM
    BassAckwards
    Can you do your best to describe the noises when it's in vs out? is it chirping?
  9. Jan 8, 2019 at 1:37 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    No only did old school
    If the double flare kits haven’t changed in a lifetime ago it should
  10. Jan 8, 2019 at 1:37 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    You are correct
  11. Jan 8, 2019 at 1:39 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Yea I use an old Gatorade bottle with fresh fluid in it and hose down into fluid so no air enters
  12. Jan 8, 2019 at 1:39 PM
    BassAckwards
    That is about the extent of my brake bleeding knowledge lol. Only know this because I helped Texoma when he changed my front brakes and needed to bleed the system
  13. Jan 8, 2019 at 1:40 PM
    BassAckwards
    Speaking of brakes.. Did you ever get that leaking bleeder fixed on your truck?
  14. Jan 8, 2019 at 1:40 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    The secret is ream and chamfer
  15. Jan 8, 2019 at 1:41 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    It’s my rear seal looks like and no haven’t done anything but try and get house finished
  16. Jan 8, 2019 at 1:41 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Sounds like throwout bearing unless these tacos don't have them mustang had one it churped when I rest my foot on the clutch
  17. Jan 8, 2019 at 1:42 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    I put a center force clutch in my old one
    Never had a problem after that
  18. Jan 8, 2019 at 1:44 PM
    BassAckwards
    TOB is weird on these. Likes to chirp in neutral w/o the clutch pedal depressed
  19. Jan 8, 2019 at 1:44 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    I did this still spongey but I'm use to it now lol I just dont tailgate people
    LostHusker[OP] and Kolunatic like this.
  20. Jan 8, 2019 at 1:45 PM
    BassAckwards
    ahhh I see.. If you ever end up needing a hand with this let me know bruddah
