San Antonio
Discussion in 'Texas' started by LostHusker, Feb 14, 2011.
  1. Jan 21, 2019 at 9:21 AM
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
    Yea you get what you pay for when you buy cheap
  2. Jan 21, 2019 at 9:21 AM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    LostHusker[OP] and Wixo[QUOTED] like this.
  3. Jan 21, 2019 at 9:22 AM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    So maybe its just their 3" spacer lift kits that arent so good?
  4. Jan 21, 2019 at 9:23 AM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    If you plan to go off-road I'd stay away from a spacer lift and go.with a coilover
  5. Jan 21, 2019 at 9:24 AM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    But if your building a mall crawler then go right ahead with spacer lift
    LostHusker[OP] and Wixo like this.
  6. Jan 21, 2019 at 9:25 AM
    Wixo
    Hank
    Tint, LED interior
    I am, I got 5100s all around, OME 888's and a 1.5-2" AAL. Its just that when shopping around I saw comments like "Tuff country should come with a sticker that says 'Im poor'"
  7. Jan 21, 2019 at 9:26 AM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    You can get Bilstien 5100 front and rear new on eBay for 330 you can get ome springs for 150 assemble them yourself and get up to a 2.5" lift upfront
  8. Jan 21, 2019 at 9:27 AM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    If you plan to drive work and home and not hit any trails then a spacer lift works fine
    LostHusker[OP] likes this.
  9. Jan 21, 2019 at 9:27 AM
    Wixo
    Hank
    Tint, LED interior
    Im building a "dont need it, dont use, but it feels good to have there" truck.
  10. Jan 21, 2019 at 9:29 AM
    Wixo
    Hank
    Tint, LED interior
    A stock truck is suppossed to get 3" with the 888s I got, but I have that SOS slim bumper that will probably bring it down a bit.
  11. Jan 21, 2019 at 9:29 AM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    I'm doing Bilstien 6112 and 5160 I'm.just in no hurry working on other things first
  12. Jan 21, 2019 at 9:30 AM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    You don't need a high lift just enough to clear your tires 2.5 Is enough
  13. Jan 21, 2019 at 9:31 AM
    Wixo
    Hank
    Tint, LED interior
    I already bought everything...but the UCAs.
  14. Jan 21, 2019 at 9:31 AM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    All them.guys in Jeep's with 6" lift is overkill
  15. Jan 21, 2019 at 9:32 AM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Save your money get spc for 549 good uca
  16. Jan 21, 2019 at 9:36 AM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Watch the post for discount codes on wheelers or any the major distributors they have 10 or 15% off every once in a while
  17. Jan 21, 2019 at 9:36 AM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Most of the time if you say your on tacomaworld fourms they will give you a little discount
  18. Jan 21, 2019 at 9:37 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I personally wouldn't try to cheap out on UCAs. They are a load-bearing component of the front suspension, so if you cheap out and there is a component failure somewhere, it is going to be a very serious issue that will likely tear other things up. Buy once and cry once imo
  19. Jan 21, 2019 at 9:38 AM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
  20. Jan 21, 2019 at 9:50 AM
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    Depends. With a good long arm lift and that solid able out front you can comfortably run 37's with a regear. 37's get you great ground clearance and they glide right over rocks and holes that easily swallow 33's.
    https://www.tacomaworld.com/threads/another-front-end-clunk-thread.450697/
