San Antonio
Discussion in 'Texas' started by LostHusker, Feb 14, 2011.
  1. Feb 17, 2019 at 6:27 AM
    Phoosa
    Phoosa I never saw nothing.
    Truck
  2. Feb 17, 2019 at 6:27 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Good morning Maner! You heading back home tomorrow right?
  3. Feb 17, 2019 at 6:28 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Matt what lake is that.
  4. Feb 17, 2019 at 6:38 AM
    Phoosa
    Truck
    Sam Rayburn.
  5. Feb 17, 2019 at 6:42 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Lived on that lake for 20 years in Etoile off 103
  6. Feb 17, 2019 at 6:43 AM
    Phoosa
    Truck
    It's nice out here.
  7. Feb 17, 2019 at 6:44 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    What part of the lake you on.
  8. Feb 17, 2019 at 6:54 AM
    LostHusker
    LostHusker [OP] Just one day at a time
    Mark
    South, TX
    2021 F150, 2015 T4R
  9. Feb 17, 2019 at 7:00 AM
    Phoosa
    Truck
    East side mear Broaddus.
    Not his fault.
    Thanks.
    Ditto.
  10. Feb 17, 2019 at 7:51 AM
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    For now, yes. Although I did watch a video last night of the beast crawling in 480:1. Made 4.7:1 look like Formula 1.
  11. Feb 17, 2019 at 7:51 AM
    hoverlover
    Mostly Zip-Ties
  12. Feb 17, 2019 at 7:52 AM
    Bigdaddy4760
    Maner
    Poolville Texas
  13. Feb 17, 2019 at 8:00 AM
    hoverlover
    Mostly Zip-Ties
    I never knew that kit even existed. It'll fit Tacoma or FJ cases and it's a straight forward swap for your low range that changes your low range from 2.56;1 to 4.7:1, that's cutting your crawl speed in half.
    With enough gear reduction...
    https://youtu.be/kYWyJoV2o6U
    https://youtu.be/ihfzApHtH0Y
    ... you can creep through anything with insane torque. +6,000 ft/lbs at idle.
  14. Feb 17, 2019 at 8:09 AM
    BassAckwards
    Sweet! I've seen videos of big mike's truck and that thing really crawls along, its crazy. You've got me starting to get the itch to put an FJ case in mine now too. There are a couple in new braunfels for around 250 with less than 100k on them. Might move up on my priority list as well..I think im gonna stick with the auto trans t-case since it is pretty straight forward. Will probably convert the truck to AWD later on, but for now i think this would be a nice cheap-ish upgrade to get rid of some of the electronic stuff on the truck.
    Do you know how much you have to shorten the driveshaft if you're just swapping in the FJ case? i dont remember reading anything about this..
  15. Feb 17, 2019 at 8:17 AM
    hoverlover
    Mostly Zip-Ties
    Dang I wish I'd seen them for $250 so close, I'd have just made the drive. Waiting for my case to ship out like
    For 4wd Tacomas swapping in the (auto) FJ case, it's not required. Everything I've read says swap the input shaft, mount it, figure out what to do with the ADD, and you're done. Tacos and FJ's are basically the same vehicle mechanically.
  16. Feb 17, 2019 at 8:23 AM
    hoverlover
    Mostly Zip-Ties
    They're so close, you can get the case from the automatic FJ and the shift boot from the manual FJ and make it look like this.
    No further mods to make it look that good.
    I dig that simple, factory look so much I'm considering skipping the twin sucks until I do the crawl box. I like a certain amount of subtlety.
    By using a switch for the ADD you still have 2 Low as well.
  17. Feb 17, 2019 at 8:28 AM
    hoverlover
    Mostly Zip-Ties
    Yep. I just sold myself on that idea. Small change of plans.
  18. Feb 17, 2019 at 8:29 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    I got to take time and catch up on all this. Im behind.
  19. Feb 17, 2019 at 8:41 AM
    hoverlover
    Mostly Zip-Ties
    All my useful links are on post #4 of my build. I only save the good stuff.
    Here
    Check out Kees and SuthrnTaco07's swaps.
  20. Feb 17, 2019 at 8:59 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Will do, I will save all of them and read on the plane
