San Antonio
Discussion in 'Texas' started by LostHusker, Feb 14, 2011.
  1. Mar 5, 2019 at 6:14 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Deka/Braille. One for light weight and two is for dat agm goodness.
  2. Mar 5, 2019 at 6:15 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    I find this offensive....
  3. Mar 5, 2019 at 6:15 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    I did too
  4. Mar 5, 2019 at 6:22 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Which model # you running in your T4R? may get one of these next time around
  5. Mar 5, 2019 at 6:26 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Oem for now came with the truck last 2 days been struggling to crank. Getting a optima on Friday, had one in a Silverado sat unhooked for 1 year while in Korea came back hooked up an truck fired right up an lasted 5 more years. Optima in a Titan lasted 6 years is why.
  6. Mar 5, 2019 at 6:37 AM
    Phoosa
    Phoosa I never saw nothing.
    Truck
    Odyssey 34R.
    Got a good deal through work.
    Recommended by many.
    Optimas are not what they once were, something to do with change in manufacturing process/location.
    @Tsumara has two in his rig and is currently having issues with one.
  7. Mar 5, 2019 at 6:38 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    20 pounder.
  8. Mar 5, 2019 at 6:58 AM
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    Ummmm... Duralast?
    Whatever auto zone had that was cheap and had enough juice to run my winch.
    See! Global warming is a conspiracy concocted by the shadow government to sell more cigarettes to children so they can push out privatized healthcare and replace it with government healthcare!
    I knew it.
    :rofl:
    I used to run nothing but optima in my Jeep. The last two I bought wouldn't hold a charge at all. I thought I had some sort of parasite drawing power so I started disconnecting the battery when I parked it for more than a couple days. Same thing. Dead batteries. Switched to a cheap auto zone battery just so I could run it occasionally, no problems, starts every time. I never disconnect it.
    :notsure:
    Edit: spelling
    TxFireman, RockHed, Oldie2007 and 5 others like this.
  9. Mar 5, 2019 at 8:51 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
  10. Mar 5, 2019 at 9:21 AM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    Good morning SATX. The weather station said 25* was our low. Got up to use the bathroom, saw that, and promptly got back under the covers! Gonna try to get the car inspected again - yesterday the state computer was "frozen" at our ONLY Inspection station!
    RockHed, hoverlover, DiamondW and 2 others like this.
  11. Mar 5, 2019 at 9:39 AM
    LostHusker
    LostHusker [OP] Just one day at a time
    Mark
    South, TX
    2021 F150, 2015 T4R
    I appreciate the responses for the batteries
  12. Mar 5, 2019 at 10:01 AM
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
    Im running yellow top optima cause of the stereo system
    RockHed and Oldie2007 like this.
  13. Mar 5, 2019 at 10:23 AM
    Oldie2007
    Kurt
    Lockhart, TX
    I was late, but I have an OEM that was put in the during Spring while it was sitting on dealer lots, before I bought it. So, it had like 100 miles of use!
  14. Mar 5, 2019 at 10:57 AM
    BassAckwards
    Thank you very much Robert! :hattip:
  15. Mar 5, 2019 at 11:19 AM
    4sky
    4sky Well-Known Member
    Kevin Levu
    2018 White Tacoma PRO
    Just got my MBRP exhaust in, I need to cut 13inches of pipeing off the exhuast to fit my short bed and I don’t have a saw, anyone recommend a place I can go ?
  16. Mar 5, 2019 at 11:24 AM
    LostHusker
    Mark
    South, TX
    2021 F150, 2015 T4R
    Harbor freight and get you a cheap saw all so you can use it for that and future projects
  17. Mar 5, 2019 at 11:25 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    You will need sae terminals, just fyi
  18. Mar 5, 2019 at 11:25 AM
    LostHusker
    Mark
    South, TX
    2021 F150, 2015 T4R
    Cars and Coffee™ San Antonio
    -2nd Saturday of each Month-
    *******0800-1000 hrs!*******
    19595 IH10 W
    Oak Hills Church Lot F
    March 9th
    Parking is more available if you arrive by 0700 - 0730, picture shows where to park. I have annotated on the map but we park near the trees on the other side. Hope to see you all out there.
    We’ll we have done this a few times and it seems to work well for the group, since we only have a two hour window for the SA Cars n Coffee each one of us brings a few things for the group. Typically we see some taco’s, donuts and someone usually brings coffee. We ask though if you bring something that you need to take it with you as we need to make sure we keep the area clean as the Church has service after the show.
    Tag me if you gonna make it and I will add you to the list.
    Going
    @LostHusker
    @BassAckwards
    @Oldie2007
    @hoverlover
    @05prerun82
    @Kolunatic
    @TacoDude 72
    @RockHed
    @hatted huey
    @SA4runner
    Possible
    @ChadsPride
    07taco, RockHed, Oldie2007 and 5 others like this.
  19. Mar 5, 2019 at 11:36 AM
    BassAckwards
    Thanks, good tip. Do you ever have any issues cranking up the runner when it's cold? just curious how the 4.0 does with a 400CCA battery. Seems like it should be enough, but just curious
  20. Mar 5, 2019 at 11:46 AM
    LostHusker
    Mark
    South, TX
    2021 F150, 2015 T4R
    :popcorn:
