San Antonio
Discussion in 'Texas' started by LostHusker, Feb 14, 2011.
  1. Jul 31, 2019 at 8:40 PM
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    I looked into self install. It's basically impossible. I'm not "trained" or "certified" or "insured" and even when I do it right (or better) my insurance will likely not cover it. A hail storm wouldn't be covered.
    Since I don't have $15k in my pocket I'd have to finance. It's about $110/month, my electric bill is exactly $164/month. But I plan on moving and seeing that house so I don't know if it's worth it.
  2. Jul 31, 2019 at 8:40 PM
    hoverlover
    Mostly Zip-Ties
    I'm supposed to be sleeping, I just got bitched at. I'll talk to y'all manana
  3. Jul 31, 2019 at 8:43 PM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    NO, it would not be = since you are likely to move. The ONLY ones that would be are the ones the offer 100% free solar (you don't pay, they install, they get the "profits", and you get left overs. BUT, that too, could lower the bill. Problem is, you have to deal with who OWNS it when you move, so that is the key to the negotiation up front. That would work for you two, but you have to be very careful!
    Once we decided we were just staying in a house with solar and a pool, it got simpler for me!
    hoverlover[QUOTED] likes this.
  4. Jul 31, 2019 at 8:44 PM
    Oldie2007
    Kurt
    Lockhart, TX
    Night bud!
  5. Jul 31, 2019 at 8:44 PM
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
    Oh snap an 18-wheeler went into the ditch and is on its side off of highway 71 in between Llano and 281 no police showed up but there is three people there I'm sure somebody called the cops
    Bigdaddy4760 and Oldie2007 like this.
  6. Jul 31, 2019 at 9:03 PM
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    Sleep studies suck, especially with ask the sensors, but it's with it if they find something. They found me to have obstructed sheep apnea.
    Me, too
  7. Jul 31, 2019 at 9:03 PM
    Oldie2007
    Kurt
    Lockhart, TX
    well, stuff marches on, doesn't it?
    hoverlover, 05prerun82 and Beretta4x4 like this.
  8. Jul 31, 2019 at 9:04 PM
    Beretta4x4
    Josh
    Temple, TX
    Night, again, Kurt
    Oldie2007[QUOTED] and 05prerun82 like this.
  9. Jul 31, 2019 at 9:06 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    So what are you do if you pass a grass fire in the middle of nowhere with no cell phone service and you drive to the next town a knock on the fire department door nobody answers:rofl:
    Oldie2007 and Beretta4x4 like this.
  10. Jul 31, 2019 at 9:07 PM
    Beretta4x4
    Josh
    Temple, TX
    Keep rolling
  11. Jul 31, 2019 at 9:08 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    But you live with that guilty conscience cuz that grass fire could probably burn somebody's house down if it wasn't taken care of
    Beretta4x4 likes this.
  12. Jul 31, 2019 at 9:09 PM
    Beretta4x4
    Josh
    Temple, TX
    Then notify other neighbors. It ain't hard.
    05prerun82[QUOTED] likes this.
  13. Jul 31, 2019 at 9:10 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Somebody would drive by and be like oh s*** and then go look for the authority
  14. Jul 31, 2019 at 9:11 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    It's like 3 years ago south of Fredericksburg on 87 there was a bad grass fire and it burn like 60 acres and when you drove through it at night it look like you're driving through hell
  15. Jul 31, 2019 at 10:34 PM
    07taco
    07taco Well-Known Member
    san antonio
    2017 taco trd dclb
    JL audio 13.5 slim box made by @Mrmarv
    4sky[QUOTED] and hoverlover like this.
  16. Jul 31, 2019 at 11:42 PM
    Chris311
    Chris311 Well-Known Member
    1999 White Tacoma SR5 V6 TRD OR 5 speed M/T
    3" OME lift, SPC UCAs, URD Crankshaft pulley (the red gives more HP)
    Ordered the Marlin Crawler clutch kit for my 1999 Tacoma SR5 V6 4x4 TRD OR.
    I couldn't get the clutch the disengage when trying to leave work, so towed it to a nearby transmission shop. At first I thought it was either the slave or master cylinder, so I picked up new Aisen ones and dropped them off at the transmission shop (Certified Transmissions off of Timberhill), but wanted them to doublecheck first since they were the experts.
    They were able to confirm that my master cylinder had a bad seal as some fluid was visible on the input shaft, and the slave was leaking a little as well. However, before they installed the new master and slave, they checked the clutch fork and found that it was very difficult to move. They use some sort of lever to test if a clutch is binding and said my clutch fork required a lot more force than it should. They explained that this is what most likely killed my master and slave cylinder, and that installing new ones would see them fail shortly after. And this is why I have the new clutch kit on the way (not a big deal as I was planning on replacing the clutch soon anyways as it has about 130k miles on it). They will diagnose what part is binding up when they take the clutch apart just to see what it is, but it wont really matter as they will be replacing everything anyways. They want $950 all in for all the work to replace the clutch, rear main seal, and the master/slave cylinder replacement and bleeding. I think it's a good price, even if its not including the cost of the clutch kit and new cylinders, as the Toyota dealership wants over $2200 to do the same work.
    Recently I had done the clutch pedal spring modification, and I was thinking my clutch pedal was getting much harder to push, but I chalked it up to the new spring being stronger. Looks like it was just coincidental that the clutch started to bind at the same time of installing the different spring.
  17. Aug 1, 2019 at 12:21 AM
    hoverlover
    Mostly Zip-Ties
    That sounds like a pretty fair price all things considered. I'm sure you're going to enjoy having a new clutch!
    BassAckwards likes this.
  18. Aug 1, 2019 at 2:46 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
  19. Aug 1, 2019 at 3:22 AM
    LostHusker
    LostHusker [OP] Just one day at a time
    Mark
    South, TX
    2021 F150, 2015 T4R
    Ughhh, its not Friday yet....
    Morning
  20. Aug 1, 2019 at 3:24 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Nope
    But at least I’m finished with shop
