San Antonio
Discussion in 'Texas' started by LostHusker, Feb 14, 2011.
  1. Aug 11, 2020 at 5:43 AM
    TxToyotaOutlaw15
    TxToyotaOutlaw15 TTC #0242 "REAPER"
    San Antonio TX
    2k15 DCLB
    35in BFGKo2s, 17inch TSS wheels, and 5% limo tint, 4"maxtrac spindles, bilstein 5100s front/5125s on the rear, projector headlights, 8pod rock lights, 2.5 gal on board air systems also connected to a train horn ;). Roof rack
    Ouch! Dang.
    Only reason I ask is because I had the similar situation once with a PVC pipe fitting that fell off a truck a couple months back, and I thought it broke my fog light, turns out I just needed to pop it back into place, hopefully thats the same story for you, it may have just been knocked out of the clips holding it behind the bumper
  2. Aug 11, 2020 at 6:10 AM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    :wave: Morning Mark
    :wave: Morning Kevin - sorry to hear that the Bird is the Word!
    :wave: Morning Mike
    :wave::wave: Good Morning SATX folks!
  3. Aug 11, 2020 at 6:11 AM
    Creepin’ 19
    Creepin’ 19 That guy
    Cav Blue 2019 Tacoma Double Cab Off-Road
    Stock
    I’ve taken it to Corpus twice. Headwind both times and same 3k for the last hour of the drive about 65mph. I’m no Motörhead but from everything I read I’m not worried about it and will gladly do it again and again
  4. Aug 11, 2020 at 6:17 AM
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
    Bird hit
  5. Aug 11, 2020 at 6:35 AM
    Oldie2007
    Kurt
    Lockhart, TX
  6. Aug 11, 2020 at 6:46 AM
    DanishTaco
    DanishTaco Well-Known Member
    2019 TRD-Offroad
    Gotcha. Makes sense then. What does toyota recommend on how often we change out our ATF?
  7. Aug 11, 2020 at 6:50 AM
    Oldie2007
    Kurt
    Lockhart, TX
  8. Aug 11, 2020 at 6:57 AM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Kurt
  9. Aug 11, 2020 at 7:22 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    I believe every 30k for a drain and fill using WS fluid. I went with valvoline.
  10. Aug 11, 2020 at 7:26 AM
    LostHusker
    LostHusker [OP] Just one day at a time
    Mark
    South, TX
    2021 F150, 2015 T4R
    Sup Kurt
    Ya it was nerve racking as I was towing. Filled up in Pleasanton and as soon as I crossed the last bridge I had to fuel up again.
    3rd gens don’t have the same schedule.
  11. Aug 11, 2020 at 7:28 AM
    LostHusker
    Mark
    South, TX
    2021 F150, 2015 T4R
    Here is some more information
    MattCowsmasher likes this.
  12. Aug 11, 2020 at 7:30 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    I had no clue fwiw this was the first one since I’ve own the truck it was done at 148k. While it was old fluid but wasn’t burnt, dirty, and I had no shifting issues but it’s shifting a little smoother however.
  13. Aug 11, 2020 at 7:32 AM
    LostHusker
    Mark
    South, TX
    2021 F150, 2015 T4R
    Ya I have not done mine yet either, I’m at 95k now so like mentioned before just something I am looking into.
  14. Aug 11, 2020 at 7:55 AM
    DanishTaco
    2019 TRD-Offroad
    Seems like a have quite awhile before i need to do this then. I'm only at 9k miles and just pulled up on 1 year of ownership.
  15. Aug 11, 2020 at 7:58 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Nice
    LostHusker[OP] likes this.
  16. Aug 11, 2020 at 7:58 AM
    DanishTaco
    2019 TRD-Offroad
    But its funny yall are mentioning it tranmy fluid. Last week i ordered all the stuff to flush my wife's volvo xc90 tranny. Its recommended every 40k and i plan on doing it a little sooner. The volvo is a little easier since there is a drain plug where u can drop it. Just a repetitive process since u drain and fill twice. But its better than paying 600 dollars at the dealer to do it...
  17. Aug 11, 2020 at 8:00 AM
    Creepin’ 19
    Stock
    Same thing here. Just under 9k with little over a year. But I just added it up and 1800 of them are pulling my camper
    DanishTaco and LostHusker[OP] like this.
  18. Aug 11, 2020 at 8:16 AM
    LostHusker
    Mark
    South, TX
    2021 F150, 2015 T4R
  19. Aug 11, 2020 at 8:28 AM
    Oldie2007
    Kurt
    Lockhart, TX
    Blood work, man. Nice quick trip.
    ATF sounds like blood work, doesn't it. Second gen 1.0 manual:
    AUTOMATIC TRANSMISSION (5−speed)
    Fluid capacity (drain and refill),
    L (qt., Imp. qt.):
    Up to 3.0 (3.2, 2.6)
    Fluid type:
    Toyota Genuine ATF WS
    Change automatic transmission fluid only
    as necessary.
    Generally, it is necessary to change
    automatic transmission fluid only if your
    vehicle is driven under one of the Special
    Operating Conditions listed in your
    “Scheduled Maintenance Guide” or
    “Owner’s Manual Supplement”. When
    changing the automatic transmission fluid,
    use only “Toyota Genuine ATF WS” (ATF
    JWS3324 or NWS9638) to aid in assuring
    optimum transmission performance.
    Notice: Using automatic transmission
    fluid other than “Toyota Genuine ATF
    WS” may cause deterioration in shift
    quality, locking up of your transmission
    accompanied by vibration, and ultimately
    damage the automatic transmission
    of your vehicle.
    Maintenance guide suggests inspection of fluid at 30K intervals. Doesn't mention replacement up to 120K, which is as far as it goes. That said, I have no service record indicating mine has been anything but inspected. Coolant first, that was done at 162K. Then, I will get to the trans.
  20. Aug 11, 2020 at 8:47 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Good Morning Fellas
