San Antonio
Discussion in 'Texas' started by LostHusker, Feb 14, 2011.
  1. Feb 19, 2021 at 8:29 AM
    SCOTT'S TACO LOCO
    SCOTT'S TACO LOCO Orange It.
    Scott
    San Antonio, Tx
    08 Toy-yo-duh TACO TRD
    Thanks.
    Keep it going guys.
  2. Feb 19, 2021 at 8:59 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Pex tubing in attic needs insulated better. Also more insulation in attic.
    Hot water tank & surge tank needs insulated cabinet around them. There just exposed in garage.
    Need to fill all propane bottles
    Fill all vehicles with fuel
    Safe and proper way to hook up portable generator
    Check all smoke alarms as I had one fail
    Prep fireplace, sweep chimney
    Stage battery lanterns
    More firewood staged at house.
    Need ice cleats
  3. Feb 19, 2021 at 9:10 AM
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
    But you live in Texas maner or so you thought :rofl:
  4. Feb 19, 2021 at 9:13 AM
    LostHusker
    LostHusker [OP] Just one day at a time
    Mark
    South, TX
    2021 F150, 2015 T4R
    And mother nature came and did this...
    :smack:
    Bigdaddy4760 likes this.
  5. Feb 19, 2021 at 9:22 AM
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    Thanks!
  6. Feb 19, 2021 at 9:31 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I live in Indiana, so we see some moderately cold weather. Not extreme like some ares of the US, but for example the current cold spell, we haven't been above 25 degrees for 10 days.
    Just wanted to say, those are really good lists. I would add consider installing either natural gas or LP space heater(s). You can get ones which don't need electricity, or that come with blowers. The units are pretty inexpensive at $2-300. I got mine at Lowes, but of course Amazon has them.
    I use 2 natural gas ones for cheap zone heating, even when the power is on. Keeps my furnace from running so much and lowers gas bill. If power goes out, they keep me plenty warm.
    https://homeairadvisor.com/best-non-electric-heaters/
  7. Feb 19, 2021 at 9:36 AM
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    Thanks!
    Yeah most houses and utilities down here are not built IMO for these extended low temps, or to handle the snow/ice load we had this week.
  8. Feb 19, 2021 at 9:38 AM
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    Thanks
  9. Feb 19, 2021 at 9:51 AM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    My mom said I whole semi full of Ginny showed up to tractor supply here in Fredericksburg if anybody needs one she pulled the first one off that truck for herself :rofl:
  10. Feb 19, 2021 at 9:52 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Dayum what’s the world coming to when they put a limit on chitterlings. :rofl::rofl:
  11. Feb 19, 2021 at 9:55 AM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    I see grass I hope it isn't freezer burnt16137573599222370064191467692964.jpg
  12. Feb 19, 2021 at 10:37 AM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    Well, that took a little while, but most of it was in line at the first stop. Lockhart got bottled water from the State, and was distributing at the Jr. High, so I went and got in line. It was long, and I got to watch a Dodge 4x4 rescue a stock F150 from the side of the road while waiting. On the way in, West side of the road I was on was fine. East side was glare smoothed ice and slush. On the way out, East was 90% cleared off!
    Onward to the egg farm - got 7 /12 dozen for less than $10, so the wife could give some to the neighbors. That was a no problem drive at all!
    So, drop off and head to a packed Walmart - they'd had power failures and water lines broken (as well as the no water situation); all perishable foods were long gone, and freezers and coolers in the process of being cleaned. Veggies gone to; looked like they had cleaned that. One 12 pack of Shiner Blondes was saved for me in the front cooler that wasn't cool anymore! Got everything I needed except for distilled water for my CPAP, but I will use bottled if I run out.
    Went by HEB, and that lot was full, but I doubt they had much in yet - no semis in back, and their freezers/coolers had lost power as well. Turns out, we are apparently one small section of town that never lost power! Back home again, and headed outside to clean up some stuff to prep for tonight.
    We're on gas lines for heat, stove, and hot water - so really can't protect that, but a whole house generator back up is definitely a consideration for this summer. Ideally, a gas fired/gasoline option, as I can have gas piped outside, and would not have to worry about gasoline.
    Always have filled up vehicles when I see storms coming, so that is just memory.
    Even though my drips on the outdoor faucets got me though with no issues, I have some plans to do better prep that can be easily put in place.
    Going to hardwire up a box up on the solar, run de-ice cables across the panels themselves to prevent the snow and ice build up. Drop down a WP cable I can plug in when needed. (Oddly enough, the North roof melted off and didn't have as much faster than the South with all the black solar!)
    The greenhouse is a different story, and I won't know until I open it up how things did. It's primary job is to house the pool plants, and the Palram definitely made me trade "pretty" for warmer and ugly. I used way more power out there than I'd like.
    I think I am going to rig up a secondary hose based system for watering in the greenhouse, so I can use the hose, and not have to try and heat the shed. Should not be that hard.
    Remember to fill the grill propane tanks, even though I never used them during this.
    RockHed and LostHusker[OP] like this.
  13. Feb 19, 2021 at 10:38 AM
    Oldie2007
    Kurt
    Lockhart, TX
    It'll be just fine.
  14. Feb 19, 2021 at 11:26 AM
    Phoosa
    Phoosa I never saw nothing.
    Truck
    Things to obtain:
    Extra blankets for covering windows & doors.
    Torch to help thaw things out. (Jetboil works in a pinch)
    Glad I had:
    Windshield cover for truck.
    -never needed to worry about chipping ice/snow off windows or mirrors
  15. Feb 19, 2021 at 11:38 AM
    LostHusker
    Mark
    South, TX
    2021 F150, 2015 T4R
    You have a garage to park it in...:boink:
    07taco, RockHed, Oldie2007 and 3 others like this.
  16. Feb 19, 2021 at 12:03 PM
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
  17. Feb 19, 2021 at 12:12 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Well I think it wasn't to bad now if say this lasted a month in below freezing temps with no power or water then I would be stressing a little more
  18. Feb 19, 2021 at 12:42 PM
    Phoosa
    Truck
    Mine dont fit.
    Besides, keeps it wild and mean.
    Don't want it getting soft and spineless.
    Next your gonna tell me it needs heated seats.
  19. Feb 19, 2021 at 1:11 PM
    LostHusker
    Mark
    South, TX
    2021 F150, 2015 T4R
    Lol nah no need for heated seats, though mine has it I think I have used them once since owning the truck. It was a used truck so didn’t pick it’s features.
    07taco, Oldie2007 and Bigdaddy4760 like this.
  20. Feb 19, 2021 at 1:13 PM
    Phoosa
    Truck
    Heated seats.
    Garage kept.
    Damn 3rd gens.
    :boink:
    07taco, RockHed, hoverlover and 3 others like this.
