San Antonio
Discussion in 'Texas' started by LostHusker, Feb 14, 2011.
  1. Mar 8, 2021 at 6:46 PM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    I've built 2 by myself in years past with a Chiltons and a pointer torque wrench! You can do it! (Except machine work!)
  2. Mar 8, 2021 at 6:50 PM
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
    I've always wanted to rebuild an engine but I never had the opportunity or time to do it
  3. Mar 8, 2021 at 6:51 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    I wanted to put a 302 out of my mustang and rebuild it and borrowed out and all that stuff but it was my daily and I couldn't have it sit
    LostHusker[OP] and BassAckwards like this.
  4. Mar 8, 2021 at 6:52 PM
    Oldie2007
    Kurt
    Lockhart, TX
    Once you get it blown apart, degreased (steam cleaning works great), and mounted on an engine stand, it's just an exercise in patience. And you just cover it up with plastic dry-clean bags when it's waiting for you!
  5. Mar 8, 2021 at 6:53 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    People say that ford 302 is really easy to rebuild so are chevy 350
  6. Mar 8, 2021 at 6:59 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    That's good to know it can be done, i am just a backyard mechanic so I'm a bit hesitant to give it a go, but i think it'll go together more quickly if i'm doing the work.. I am getting tired of having issues with the daily driver, so it's time to do something about it to fix it if possible:bananadead:
  7. Mar 8, 2021 at 7:01 PM
    Oldie2007
    Kurt
    Lockhart, TX
    I've seen your work - doing it is well within your wheelhouse!
  8. Mar 8, 2021 at 7:10 PM
    BassAckwards
    Thanks buddy, this is definitely encouraging. Gonna have to start doing my research
  9. Mar 8, 2021 at 7:12 PM
    Oldie2007
    Kurt
    Lockhart, TX
    1. While you read stuff, you can start your old tear down.
    2. When you have the block cleaned and inspected (I used Kalamazoo Speed Shop), THEN they can tell you if you need to build back to stock, .010 over, .020 over etc. (or however they metric it), then you know the ring and piston stuff to get.
    3. Get the best bearings and gasket sets you can.
    edit - and CLEAN everything till you can eat off it, and use lots of assembly lube!
  10. Mar 9, 2021 at 2:15 AM
    Tacotsubo
    Tacotsubo Mediocre at best
    Kevin
    San Antonio
    2019 MGM DCSB TRD OffRoad
    Good Morning Gents :hattip::hattip:
  11. Mar 9, 2021 at 4:02 AM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Morning everybody
    LostHusker[OP], Oldie2007 and RockHed like this.
  12. Mar 9, 2021 at 4:28 AM
    RockHed
    RockHed TTC #051
    Danny
    San Antonio TX
    2016 Black TRD Sport OnRoad 4x2
    Kevin , Brandon :hattip:
    Morning SA :hattip:
  13. Mar 9, 2021 at 5:55 AM
    Oldie2007
    Kurt
    Lockhart, TX
    Morning Kevin
    Morning Brandon
    Morning Danny
    :pccoffee: Good Morning SA! Let's hear it for NOT Monday! I'm not even supposed to have them!
  14. Mar 9, 2021 at 6:01 AM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Morning Danny
  15. Mar 9, 2021 at 6:02 AM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Morning Kurt
  16. Mar 9, 2021 at 6:25 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I mean unless you're paying for the fuel and vehicle yourself id rec a gas engine. Diesel is ok until you need to fix something. The parts can be super expensive. I'm not sure on the smaller diesels but at least for my f250 the prices rival exotic. But I also turned it into something racey so I guess theres that too. If I were doing the thing id prob look into a Chevy express or something. Just my opinion.
    RockHed, Oldie2007 and LostHusker[OP] like this.
  17. Mar 9, 2021 at 6:25 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
  18. Mar 9, 2021 at 6:26 AM
    LostHusker
    LostHusker [OP] Just one day at a time
    Mark
    South, TX
    2021 F150, 2015 T4R
    They run to them mileage and sell them off.
    Umm should of got that 4.0 that I tagged you on
  19. Mar 9, 2021 at 6:27 AM
    LostHusker
    Mark
    South, TX
    2021 F150, 2015 T4R
  20. Mar 9, 2021 at 6:27 AM
    BassAckwards
    It is tempting but i was worried about the 05-06 head gasket issue.. With my luck i'd swap that in and then need to do head gaskets haha :p
