San Antonio
Discussion in 'Texas' started by LostHusker, Feb 14, 2011.
  1. Oct 19, 2022 at 3:17 PM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    If I hadn't been so careful to lube it all up as I worked it, and used a Jewlers' screwdriver shaft to prevent twist as I worked it on, I would think I screwed it up. Now, the replacement was just a tiny bit smaller (diameter and circumference) than the 15 year old original, but there's really no way to compare. I had to assume they sent me the right thing. I did the same thing putting the old one back on, and slid it on and off three times - no issue.
    Could have been me, might just not have been the size it should of been.
    Tomorrow, the rest of the stuff goes back on, and we'll see! Trying to get a replacement fan clutch out of AutoZone - might work, but noisy as all get out!!
    RockHed and Slimwood Shady like this.
  2. Oct 19, 2022 at 5:40 PM
    RockHed
    RockHed TTC #051
    Danny
    San Antonio TX
    2016 Black TRD Sport OnRoad 4x2
    Evening gents :hattip:
    Been a minute, been busy with work and had my uncle from Laredo pass, he had battling dementia the past 10+ years, so he's finally resting in peace.
    Hope everyone's been doing well, definitely been enjoying this cooler weather.
  3. Oct 19, 2022 at 5:43 PM
    Oldie2007
    Kurt
    Lockhart, TX
    :hattip:
    RockHed[QUOTED] likes this.
  4. Oct 19, 2022 at 5:52 PM
    Oldie2007
    Kurt
    Lockhart, TX
    Sorry to hear that Danny. That is a tough battle I'd wish on no one.
    Did "enjoy" mowing and working on LBR in the cool weather! Local weather guy said tonight, ONE more day of 90*+ will break the all time Austin record (2011 of course) of 166 days in the year. Yeah, pool season did last longer.....
  5. Oct 19, 2022 at 6:17 PM
    RockHed
    RockHed TTC #051
    Danny
    San Antonio TX
    Thanks Kurt, yes definitely is hard. My aunt stuck by his side through it all, she was definitely strong.
    Pool weather lasted too long for those without :rolleyes::p
  6. Oct 20, 2022 at 2:17 AM
    Tacotsubo
    Tacotsubo Mediocre at best
    Kevin
    San Antonio
    2019 MGM DCSB TRD OffRoad
    Good Morning y'all...
    RockHed, Oldie2007 and Dan 77 like this.
  7. Oct 20, 2022 at 3:36 AM
    Dan 77
    Dan 77 I leave my bikes outside
    Dan
    San Antonio
    06 DCSB TRD Sport 4X4
    Kings and TC UCAS 01 DCSB 4X4 Totaled All-Pro bumper, mile marker winch
    Morning SA
    RockHed and Oldie2007 like this.
  8. Oct 20, 2022 at 6:07 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    My condolences mate.
    RockHed[QUOTED] and Oldie2007 like this.
  9. Oct 20, 2022 at 6:36 AM
    Oldie2007
    Kurt
    Lockhart, TX
    :pccoffee: Good Morning SA! Find out in a while if I fixed my problem! That's todays agenda.
    RockHed likes this.
  10. Oct 20, 2022 at 7:48 AM
    RockHed
    RockHed TTC #051
    Danny
    San Antonio TX
    Morning crew :hattip:
    Thank you
    Oldie2007 likes this.
  11. Oct 20, 2022 at 10:08 AM
    Oldie2007
    Kurt
    Lockhart, TX
    No leaks! :fingerscrossed:
    Cooling down to be put together again. Then burp filled again.
    Of course, my paranoid self reminds me I drove nearly 500 miles after the pump replace before these problems started :rolleyes:
    RockHed likes this.
  12. Oct 20, 2022 at 3:10 PM
    Oldie2007
    Kurt
    Lockhart, TX
    OK, results!
    Put LBR at the end of the drive so it's got the radiator as elevated as possible
    Put the funnel and coolant in, and let it rip, heat to max
    Once it hit 180*, started my timer for 20 minutes - blipping throttle once in a while. Steady at 186*, and blowing 140* out the vents (heater works!)
    Switched over to max AC, reset timer for 20 more - more blips. Solid at 194* and blowing 45* out the vents (AC works)
    Only a few bubble burps during this whole time. Shut it off, started 30 minute timer with the funnel and coolant still in place.
    Burped the top hose several times before removing the funnel. Put the new cap on.
    Ran the truck with the heat on, once hit 180* (tstat temp), let it run pressurized 10 minutes.
    Switched to AC, and let it run another 10 minutes. Off
    NO DANG DRIPS anywhere. Stable temps.
    Around the block, then a short country loop with AC on - 194*-197*. Home and parked.
    NO DANG DRIPS.
    I think I have it!
  13. Oct 20, 2022 at 4:39 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    Way to go Kurt! Danny, I am terribly sorry for your loss. You and your family will be in my prayers.
    Good evening folks!
  14. Oct 20, 2022 at 5:19 PM
    RockHed
    RockHed TTC #051
    Danny
    San Antonio TX
    Thank you, we greatly appreciate it.
  15. Oct 20, 2022 at 5:20 PM
    RockHed
    RockHed TTC #051
    Danny
    San Antonio TX
    Great to hear you got it all figured out Kurt :thumbsup:
    Oldie2007[QUOTED] likes this.
  16. Oct 20, 2022 at 5:21 PM
    Oldie2007
    Kurt
    Lockhart, TX
    I am certainly hoping so! :D
  17. Oct 21, 2022 at 2:24 AM
    Tacotsubo
    Kevin
    San Antonio
    Good Morning Gents :hattip:
    Oldie2007, Dan 77 and Slimwood Shady like this.
  18. Oct 21, 2022 at 2:30 AM
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Good morning
    Oldie2007, Dan 77 and Tacotsubo like this.
  19. Oct 21, 2022 at 2:50 AM
    Dan 77
    Dan
    San Antonio
    Good morning....
  20. Oct 21, 2022 at 6:04 AM
    Oldie2007
    Kurt
    Lockhart, TX
    :pccoffee: Good Morning SA! Going to take the dog on a celebratory trip to the cardboard recycle and car wash today - that's it!
    Slimwood Shady likes this.
