San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Oct 30, 2013 at 5:24 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Happy birthday Tyler, have a good one
  2. Oct 30, 2013 at 7:55 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    Whats up with your truck alex ?
    And jason, any computer mods needed for a small turbo set up ? Im assuming an inner cooler is recommended.
  3. Oct 30, 2013 at 8:18 PM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    I was planning on it but it's not looking like the driveshaft will be done.
  4. Oct 30, 2013 at 9:27 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Truck is past registration and it needs to be smogged, plus I really don't feel like driving.
    If you're going to be running 6psi I doubt you would need to run an intercooler, but a meth injection would be nice.
  5. Oct 30, 2013 at 10:20 PM
    zeekevin
    zeekevin Well-Known Member
    San Diego
    side job eh? lonely customer needs her pipes cleaned?
  6. Oct 31, 2013 at 5:30 AM
    zeekevin
    San Diego
    Try mr tint in escondido
  7. Oct 31, 2013 at 9:21 AM
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    That 3m shit is kind of expensive. If you get it let me.know the differences, and why its pricier
  8. Oct 31, 2013 at 9:34 AM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Yeah no kidding, especially knowing your motor needs pretty much EVERYTHING! But gonna be like a new motor after that (at least most of it anyway)
    He is riding a 2004 CRF250R, or I should say WAS.
    IC is a good idea, if your doing a lot of low speed stuff an air to water IC would be best, but complex, if you drive fast which it looks like you probably will an air to air would be fine, but I would recommend an IC regardless. Meth inj is nice but requires filling and maint.
  9. Oct 31, 2013 at 10:16 AM
    jeffz0rz
    san diego
    seems like i could be under 2g's for a simple turbo set up seeing as our oil pans are already tapped for such a thing... interesting.
  10. Oct 31, 2013 at 10:39 AM
    mercurymullet
    mercurymullet Well-Known Member
    gary
    el cajon/lakeside
    can't afford a toyota
    bronco frame under a mountaineer
    Jeff either idles or runs on the chip.
  11. Oct 31, 2013 at 10:44 AM
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Jeff, when you want then spidertrax?
  12. Oct 31, 2013 at 11:01 AM
    jeffz0rz
    san diego
    possibly this weekend ? what part of town are you going to be in saturday or sunday ?
  13. Oct 31, 2013 at 11:02 AM
    jeffz0rz
    san diego
    bought seats, too narrow for me. fuck me.
  14. Oct 31, 2013 at 11:11 AM
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Poway, La Mesa, Spring Valley, Otay Mountain, Santee
  15. Oct 31, 2013 at 11:12 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Yes but will be wall-mart crawling in the des...
  16. Oct 31, 2013 at 11:41 AM
    jeffz0rz
    san diego
    Thats too many places for me to search. Ill never find you.
  17. Oct 31, 2013 at 3:01 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Just a quick note to say how appreciative I am of Jason (Speed Freek) to make quick on-the-spot diagnosis and repairs to perhaps any thing that drives on wheels! :cool:
    Last night, my son's Geo Metro headlights would not work to get home to Lakeside... so an emergency over-nighter here in San Marcos. However, since his regular job ends at 5 (Fri-Tue) and daylight savings also ends in a couple of days, he needs the headlights to work. :eek:
    A drive to Jason's Vista, CA 'shop' was made and the problem was soon discovered (a melted wire connection to fuse block, under the dash). A quick Internet search showed this is a common problem in the mid 90's Geos. At Jason's suggestion, we searched auto wrecking yards and found the (almost) same fuse block and wire harness at Ecology Auto in Oceanside (along Hwy. 76, near the airport).
    Returning to Speed Freek's in Vista we find he had just did a differential replacement on a Toyota Camry in the time we were away... Hearing the praises from the Camry customer did not surprise us. Jason had done a differential and transfer case oil replacement for me a year ago, and I have had positive opinion of him since. Jason knew how to make the small modification between the bad and replacement parts for it to work like new.
    In a very short time, Jason exchanged the fuse block and melted wire connection leading to the headlights and the old Geo was once again 'gold'... for very little coinage.
    Thank you Speed Freek, once again! :)
    PS My son wants to be a Tacoma owner, like his dad! :D
  18. Oct 31, 2013 at 3:18 PM
    zeekevin
    San Diego
    Does anybody have a tow hitch and ball I can borrow? Somebody stole mine and I need to move a trailer in a little bit
  19. Oct 31, 2013 at 3:42 PM
    mercurymullet
    gary
    el cajon/lakeside
    Just the receiver
  20. Oct 31, 2013 at 3:55 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    2" or 2 5/16"? I have both.
