San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Mar 13, 2014 at 10:03 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Must have someone without common sense in here. They are an offroad only light. If that doesn't give you an answer then I don't know what to tell you.
    If you don't care about getting fix-it-tickets or paying fines then go right ahead and slap them in there and turn them on while driving around. You will just be that guy.
  2. Mar 13, 2014 at 10:14 AM
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    The duallys are brighter than hid headlights. All led pods and light bars must be covered when on highway in California, regardless of location or height relationship to factory headlights. The duallies in the fog light position will typically get a free pass because of the location. Using them on highway if aimed properly is doable but just be considerate and know that in Ca it could be ticket-able.
    For everyone with cheap Chinese led's that don't have covers available the tickets are on the way. At least that's what the cop that wrote me two separate tickets for two separate led bars that were not covered. Covers were on floorboard on way back from desert, got a ticket anyway.
  3. Mar 13, 2014 at 10:17 AM
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    2012 Tacoma TRD T|X Baja
    Pelfreybilt IFS Skid, Mid Skid and Plate Bumper, Rigid Industries Dually's, ARB CKMA12 On Board Air, Kenwood TM-281A Radio, Rear view mirror relocation bracket, Wheelers SuperBumps, Toytec Baja Spacer
    That's why I was asking, no need for the sarcasm :) :D
    Thanks Tyler, perfect answer and exactly what I was looking for.
  4. Mar 13, 2014 at 10:50 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    It's not a case of DOT, more CVC approval, more intensity and height in relation to headlights are a no go, lower to headlights and below 600Lumens are allowable non LED type light. And do not need to be covered.
    the latest CVC
    V C Section 24403 Foglamps
    Foglamps
    24403. (a) A motor vehicle may be equipped with not more than two foglamps that may be used with, but may not be used in substitution of, headlamps.
    (b) On a motor vehicle other than a motorcycle, the foglamps authorized under this section shall be mounted on the front at a height of not less than 12 inches nor more than 30 inches and aimed so that when the vehicle is not loaded none of the high-intensity portion of the light to the left of the center of the vehicle projects higher than a level of four inches below the level of the center of the lamp from which it comes, for a distance of 25 feet in front of the vehicle.
    (c) On a motorcycle, the foglamps authorized under this section shall be mounted on the front at a height of not less than 12 inches nor more than 40 inches and aimed so that when the vehicle is not loaded none of the high-intensity portion of the light to the left of the center of the vehicle projects higher than a level of four inches below the level of the center of the lamp from which it comes, for a distance of 25 feet in front of the vehicle.
    And
    V C Section 24602 Fog Taillamps
    Fog Taillamps
    24602. (a) A vehicle may be equipped with not more than two red fog taillamps mounted on the rear which may be lighted, in addition to the required taillamps, only when atmospheric conditions, such as fog, rain, snow, smoke, or dust, reduce the daytime or nighttime visibility of other vehicles to less than 500 feet.
    (b) The lamps authorized under subdivision (a) shall be installed as follows:
    (1) When two lamps are installed, one shall be mounted at the left side and one at the right side at the same level and as close as practical to the sides. When one lamp is installed, it shall be mounted as close as practical to the left side or on the center of the vehicle.
    (2) The lamps shall be mounted not lower than 12 inches nor higher than 60 inches.
    (3) The edge of the lens of the lamp shall be no closer than four inches from the edge of the lens of any stoplamp.
    (4) The lamps shall be wired so they can be turned on only when the headlamps are on and shall have a switch that allows them to be turned off when the headlamps are on.
    (5) A nonflashing amber pilot light that is lighted when the lamps are turned on shall be mounted in a location readily visible to the driver.
  5. Mar 13, 2014 at 11:06 AM
    SoCaltaco65
    tell me about it, my drive up 5 north in the early AM I see the same F-150 with massive bro-lean , dually's and an 8 inch bar lit while on hwy 5 nearly everyday.
  6. Mar 13, 2014 at 11:14 AM
    dad32509
    dad32509 Thinking of something clever
    Dave
    San Diego
    Blacked out 05
    5100's front and back, OME 885x's, LR UCA's, OMD rear springs, Pioneer AVH-P2300DVD, HVAC Green led's MOD, Blacked out bumper, Plastidip emblems, custom front tube bumper, 32" combo led bar, rigid duallys, otrattw switches, my own Satoshi grille, shorty antenna, Spyder LED halo headlights. csjumper2003 map/dome, 3rd brake, DTRL white/amber and parking LED's. Pelfreybilt IFS skid, Cab mount chop, sliders and rear light bar w/blitzpro 5LR dust light. Uniden CB, Magnaflow 18" exhaust, Rear tire carrier, sway bar removed, spidertrax 1.25" spacers, Wheelers 16" Alloys w/265/75r16 Goodyear DuraTracs
    so long story short.....ok to use offroad, cover when not offroading and your ok?
  7. Mar 13, 2014 at 11:25 AM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    once in a blue moon ill drive up the street to the greek sombrero for a beer in the toyota. no headlights, only a 30 inch bar. shits aimed LOW and i still turn it off when i see a car coming lol. got funny looks going to the liquor store for beer last week.
    I also smashed my light bar. Woops
  8. Mar 13, 2014 at 11:35 AM
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    Thanks guys, All the info I needed, run my dully's all the time, point em high and use with my 20" bar too :p jk jk appreciate all the responses.
    Alex
  9. Mar 13, 2014 at 11:39 AM
    mercurymullet
    mercurymullet Well-Known Member
    gary
    el cajon/lakeside
    can't afford a toyota
    bronco frame under a mountaineer
    Those ramps look sexy.
  10. Mar 13, 2014 at 12:01 PM
    SoCaltaco65
    Heading to Alex's with cut shrubbery......whos in?
  11. Mar 13, 2014 at 12:40 PM
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    HAHA Good thing im hiding at work.... :)
    LMFAO!
  12. Mar 13, 2014 at 12:47 PM
    mercurymullet
    gary
    el cajon/lakeside
    Thanks for reminding me I need to trim my lane now that I can pull my trailer to the dump.
  13. Mar 13, 2014 at 1:20 PM
    669sprink
    669sprink Crazy Cracker
    Bobby
    San Diego
    08 pre runner tacoma
    1.5" Wheel spacers all around, 2.0 fox coil over with foxes in the back to match it up, add a leaf. 285/70/r16 general grabbers. my magnaflow exhaust k&n intake just threw in some maxtrac spindles. Total chaos UPA. Bunch of other little things
    Who's all heading to super this weekend. I was thinking about taking mine and my wife's truck out I just don't wanna be the Lone Ranger. I was told a few people were going out I just wanna know who so I'm not guessing who people are when I get out there.
  14. Mar 13, 2014 at 1:46 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Ill be at plaster city around noon to go play in Oco.
  15. Mar 13, 2014 at 1:51 PM
    mercurymullet
    gary
    el cajon/lakeside
    true dat
  16. Mar 13, 2014 at 2:08 PM
    jeffz0rz
    san diego
    going to t-mec saturday to pic up more tires. upgrayd
  17. Mar 13, 2014 at 2:27 PM
    669sprink
    Bobby
    San Diego
    Plaster sounds good I'll keep an eye out. What day?
  18. Mar 13, 2014 at 3:24 PM
    nfs257
    DFW
    She gone
    saturday. I cut from there to oco and play around, then head to ramona and back to sd...
  19. Mar 13, 2014 at 3:33 PM
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    I'll be down in Algodones on the All-American canal, beer in one hand and fishin rod in the other.
  20. Mar 13, 2014 at 3:47 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    What the fuck!? Why didn't you tell me?
