San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Mar 27, 2014 at 9:02 AM
    mercurymullet
    mercurymullet Well-Known Member
    gary
    el cajon/lakeside
    can't afford a toyota
    bronco frame under a mountaineer
    No the 2x10s are more than the 2x6s, but the difference is around $50. And the hardware covers most of that. I was thinking for $10-$20 I don't wanna drill 15-20 more holes.lol
  2. Mar 27, 2014 at 9:18 AM
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    Does anybody have steelies or a super cheap set of rims and tires. Tires can be very used. Was gonna get a set but they fell through. Anything just laying around in the garage?
  3. Mar 27, 2014 at 9:18 AM
    mercurymullet
    gary
    el cajon/lakeside
    Damn$$$ poly would make my trailer so heavy I couldn't tow it.
  4. Mar 27, 2014 at 9:20 AM
    mercurymullet
    gary
    el cajon/lakeside
    Know a guy looking for wheels and tires and has stock steelies. I let you know if he gets tires.
  5. Mar 27, 2014 at 9:25 AM
    csjumper2003
    Savannah, GA
    Thanks I appreciate it
  6. Mar 27, 2014 at 9:26 AM
    669sprink
    669sprink Crazy Cracker
    Bobby
    San Diego
    08 pre runner tacoma
    1.5" Wheel spacers all around, 2.0 fox coil over with foxes in the back to match it up, add a leaf. 285/70/r16 general grabbers. my magnaflow exhaust k&n intake just threw in some maxtrac spindles. Total chaos UPA. Bunch of other little things
    Hey I was talking dad last night on a skid plate can you get a deal on a steel sheet or should I shop around and what gauge is needed or preferred?
  7. Mar 27, 2014 at 9:35 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Got 5 tires on 5 steelies , in the corner chris...
  8. Mar 27, 2014 at 10:14 AM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    i can only get a deal on bulk purchases, but im not buying 200' of tubing or 10 sheets of plate lol. id shop around. i dont have access to a water jet or plazma guy yet. you thinking of going steel, or aluminum ?
  9. Mar 27, 2014 at 10:19 AM
    mercurymullet
    gary
    el cajon/lakeside
    Thanks for the input, I just remembered wood isn't the actual size. I'll just do 14 2x6s. One bolt in each board per row. Should work good.
  10. Mar 27, 2014 at 10:27 AM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    I would consider 2 per board so they dont warp, just my .02c
  11. Mar 27, 2014 at 10:31 AM
    mercurymullet
    gary
    el cajon/lakeside
    I thought about doing 2 in the front row and one in the middle rows, the rear still has the steel lip. Haven't decided how many rows to do yet. Was thinking around every 4'
  12. Mar 27, 2014 at 10:39 AM
    669sprink
    Bobby
    San Diego
    Going steel and I'll get measurements and get it water jetted. What gauge is best?
  13. Mar 27, 2014 at 10:42 AM
    jeffz0rz
    san diego
    consider putting a lip on the front as well ? even though its a pain in the ass, id paint them before you put them on. paint the piss out of em. they wont rot as fast.
  14. Mar 27, 2014 at 11:09 AM
    mercurymullet
    gary
    el cajon/lakeside
    I've done the paint before it kinda sucks. I'll just oil them like I've done before and with my other trailer.
    I have a lip on the front now I have to cut out.
  15. Mar 27, 2014 at 11:19 AM
    jeffz0rz
    san diego
    2 person deal. cut the current boards out, then bend the new boards in without cutting the lip out.
  16. Mar 27, 2014 at 11:21 AM
    mercurymullet
    gary
    el cajon/lakeside
    Heard of that, never done it-you?
  17. Mar 27, 2014 at 11:32 AM
    jeffz0rz
    san diego
    yup. easy as shit. the longer the trailer, the easier. measure out the board on top of the lip, cut it so itll fit (as if there were no lips) stick one side under the lip, lay a piece of 4x4 in the middle across where the board will go and when you lay the board out, it will bow over the 4x4. its actually really simple. the wider the boards are, the tougher it is though.
  18. Mar 27, 2014 at 11:40 AM
    mercurymullet
    gary
    el cajon/lakeside
    2x6 x 20 should have some bend. I'll hollar at you when its time.
  19. Mar 27, 2014 at 11:50 AM
    jeffz0rz
    san diego
  20. Mar 27, 2014 at 12:35 PM
    mercurymullet
    gary
    el cajon/lakeside
    How bout a beer a board?
