San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Apr 2, 2014 at 9:51 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Ok gotya i was thinking it was a 2wd thing...
    Haha, hey your ideas are great man keep'em coming serious, bullshit, you haz skillz.....:cool:
  2. Apr 2, 2014 at 9:52 AM
    mercurymullet
    mercurymullet Well-Known Member
    gary
    el cajon/lakeside
    can't afford a toyota
    bronco frame under a mountaineer
    even an early bronco dana 30 would be stronger than what you have.
  3. Apr 2, 2014 at 9:53 AM
    mercurymullet
    gary
    el cajon/lakeside
    I have been told bullshitting is a skill that I have.
    https://sandiego.craigslist.org/nsd/pts/4395958882.html
    heres a start, stock bronco shafts and chevy outers. Has 4:10s
  4. Apr 2, 2014 at 10:03 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Yep, no doubt
    well its still a skill & i'll take it haha
  5. Apr 2, 2014 at 10:04 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Which is the JK Gabe ?? I'm not up on the jeep thing...
  6. Apr 2, 2014 at 10:07 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    haha, i mean is it the cherokee type or reg jeep ??
  7. Apr 2, 2014 at 10:09 AM
    mercurymullet
    gary
    el cajon/lakeside
    A jk is the new JEEP jeep. (wrangler). They can be four door or two door.
  8. Apr 2, 2014 at 10:13 AM
    mercurymullet
    gary
    el cajon/lakeside
    2 door rubicon is a pretty good out the box toy. The JKs are alot bigger than the TJs.Bubba 4 door lacked the ground clearence stock because of the length.
  9. Apr 2, 2014 at 10:13 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Think I'd get one like Connor had, is that a YJ ? a XJ or a BJ ??
  10. Apr 2, 2014 at 10:15 AM
    mercurymullet
    gary
    el cajon/lakeside
  11. Apr 2, 2014 at 10:18 AM
    mercurymullet
    gary
    el cajon/lakeside
    The only thing I don't like about XJs is that you end up installing frame stiffeners bc of uni body, the front axle is suspect, the rear axle is suspect, the engine over heats. By the time you fix all that.....
  12. Apr 2, 2014 at 10:18 AM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    My Jeep goes to places only Tacomas can look at with binoculars, or hiked to, or seen from space.
    But rarely leaves the driveway so you guys are safe.
  13. Apr 2, 2014 at 10:19 AM
    mercurymullet
    gary
    el cajon/lakeside
    You get a tj, your golden. or find a cheap yj and convert to coils.
  14. Apr 2, 2014 at 10:21 AM
    Speed Freek
    XJ is just a 4x4 station wagon....but can do some pretty amazing stuff for a wagon, lol
    The TJ is king of the jeeps!! JK got all heavy with the new less torque V6, plastic grill and tons of extra electronics.
    TJ all the way. Fuckers go anywhere! Now getting back out is another thing..
  15. Apr 2, 2014 at 10:32 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    And a jeep is just a Chrysler, so you'll be working on something after every trip.
  16. Apr 2, 2014 at 10:36 AM
    CorpsmanUp
    CorpsmanUp Well-Known Member
    Gibby
    Suffolk, VA
    2013 Taco DCLWB 6in lift 35s 4.56s, air lockers AP F&R bmpers warn 10k winch Rigid fogs & floods custom pro top shell
    6in procomp stage 2 lift with PC Coilovers, 35x12.50 Nitto MTs, Moto metal 18x10 with -44 offset HID and LED's everywhere, ladder bars, rear disk brake conversion, hood struts, K&N cold air intake, Flowmaster 40 series, pro comp skid plates, train horn, pa system, all silver trim inside painted black all pro apex front bumper with full hoops warn 10k winch, all pro high clearance rear bumper with custom door hinge tag holder, pro top custom windowless camper shell. ARB onboard air compressor, rear ARB air locker, 4.56 gears front and rear, waterport pressurized water system, pop and lock tailgate.
    NMCSD/ Balboa hospital currently. You?
  17. Apr 2, 2014 at 10:38 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    Which department do you work for/with?
  18. Apr 2, 2014 at 10:41 AM
    CorpsmanUp
    Gibby
    Suffolk, VA
    I'm in a MIND unit/ L&D but finally go to a dang clinic in 3 weeks.
  19. Apr 2, 2014 at 10:44 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    Clinics are both a blessing and hell depending on the leadership. Which clinic will you be assigned to?
  20. Apr 2, 2014 at 10:44 AM
    Speed Freek
    Negative, has been really good to me so far. Over 35 trips, no breakage. Think I am doing pretty good, better than most of the Taco guys actually in the trail run / breakage ratio.
    Now that I said that I better find a spare set of axles....
