San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Nov 6, 2014 at 5:18 AM
    mercurymullet
    mercurymullet Well-Known Member
    gary
    el cajon/lakeside
    can't afford a toyota
    bronco frame under a mountaineer
    Since HP is just calculated from torque just rev that bitch up to 10k RPM like nascar. JK I know its not that simple.
  2. Nov 6, 2014 at 5:53 AM
    TripleThreat
    TripleThreat Vance@freevancewriting.com
    They keep callin me cowboy but its not my name...
    Socal but I am still a southern Florida guy
    Toyota Tacoma 4x4 slightly modified
    nothing special.... wanna race?
  3. Nov 6, 2014 at 9:10 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    6500 rpm is a bit more reasonable on the stock valves and a standalone ecu. Our stupid stock rev limiter is like 5700. I bounce off it all the time
  4. Nov 6, 2014 at 9:25 AM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    If you are running boost I would HIGHLY RECOMMEND going with dual valve springs, at 10+psi you can get valve float and hit your piston, thats not good. I ran mine to 6700 with upgraded valve springs and Ti retainers from LCE, and it was still pulling hart till rev limiter. I would keep it under 7K just to be safe once you have the new springs.
    In order for the 2RZ to make 300HP like said above you gonna be in the 15psi range depending on turbo choice more or less, Head studs so the gasket wont blow and head wont lift, MLS head gasket so once again the Gasket wont blow out. Bigger injectors and pump in order to keep up with fuel requirements.
    And before all that I would get a new 190 or larger Walbro Fuel pump, like I tell everyone its necessary to get a new fuel pump before boosting a motor to make sure you have enough head pressure, the boost actually counters fuel pressure since the engine is pressurized, and the stock pump isnt quite enough to do it, plus its just plain old and worn out!
    Also its very important to get your fuel pressure regulator signal from the manifold not the TB. The Toyota FPR is actually boost sensitive when hooked up to a port that sees vacuum!! So in that regard there is no reason to use a fancy Boost sensitive FPR. The stock one will allow a 1:1 increase in pressure per pound of boost.
    Piggybacks suck for the 2RZ, I have tried everything and the best way is to just go full standalone, but thats a big bite to take! But the Toyota ECU will eventually try and counter whatever you did with the piggyback.
    My last build ended up with a Haltech PS1000 ECU and was running at 28psi, wastegate failure was the end of the road, then the LS1 swap.
    Still collecting parts for the turbo system, I have most of the motor stuff (Studs, MLS Gaskets, Timing chain and sprockets, oil pump, upgraded my Rocker trunions)
    Been racing motorcycles so much I dont have much money to put into the truck for the past year or so..but one of these days..
  5. Nov 6, 2014 at 9:31 AM
    mercurymullet
    gary
    el cajon/lakeside
    I was just making a joke toward hp and RPMs. How much drivetrain loss is there with a LT truck on 35s? 300 RWHP would be like 375-400 HP at the crank right? Thats one bad ass 4 banger.
  6. Nov 6, 2014 at 10:12 AM
    Speed Freek
    Kinda depends on that particular trucks parasitic load, if ya have a 9" that is a power soaker!! Probably 10%+ right off the top for that alone. Then trans, an auto sucks a ton of power too.
  7. Nov 6, 2014 at 1:17 PM
    MadTaco461
    CA
    Kinda stock
    Thanks for all the good info Jason. I have a new 190 already in the tank. I'll move that fpr line to the mani. Looks like I'm keeping her under 10 for the time being. I might do 440 or 550 injectors when I start running out of room on the pinks. So far the mapecu3 is being nice to me. It is really easy to work with. I'll let you say I told you so if I do blow the motor cuz of it. But if I do go over 10 I'm going to get away from the eBay turbo first. I don't trust it much over spring pressure. Prolly a 50 trim t3 t4 turbonetics.
  8. Nov 6, 2014 at 1:28 PM
    MadTaco461
    CA
    Kinda stock
    I caught your drift earlier. But I'm just putting lipstick on a pig for the time being. All I know is my setup is already eating plenty of power. Right now I'm happy I can do 5th up a hill. I should do a dyno pull one day for kicks show you how low my numbers are.
  9. Nov 6, 2014 at 1:54 PM
    mercurymullet
    gary
    el cajon/lakeside
    Sorry about that, I deal with my sisters boyfriend all the time that sees 400hp in an article and dogs my v8 numbers not realizing the 400hp is at 8k+ and the motor only makes 300 ft lbs. I was asking about the loss because I saw Alex say he wanted 300 RWHP and was wondering what it would take.
    I bet you put out close to what I put out, you guys make me miss my 4 banger.
  10. Nov 6, 2014 at 7:50 PM
    mercurymullet
    gary
    el cajon/lakeside
    Have one they can borrow. Goes in the reciever
  11. Nov 6, 2014 at 8:16 PM
    LilManny
    LilManny socaltaco
    Manny
    San Diego, CALIFORNIA. (Rancho del Rey/ otay ranch
    06 Black Crew Cab TRD SPORT 33' KM2
    DR coils, camburg UCA's, procomp AAL, 285' BfG km2 Mud Terrains, Double Din touchscreen stereo, Kicker 12' sub behind seat with 800watt amp and custom box,Flowmaster Exhaust, cb radio, race/ 2m radio, crossfab lightbar, 3 9' procomp motorsport halogens. Intake coming soon. Also have custom 6 foot flagpole to represent my charger flag on!
  12. Nov 6, 2014 at 9:51 PM
    Trigo
    Trigo Because fuck you that's why...
    Rodrigo
    San Diego
    1st gen
    Here's some pics, as you guys already know pics don't do justice and there's a drop/ditch off the passenger side. Hopefully gonna be picking up that winch off Gary tomorrow! Thanks again!
  13. Nov 7, 2014 at 6:32 AM
    mercurymullet
    gary
    el cajon/lakeside
  14. Nov 7, 2014 at 8:59 AM
    Seantoobs
    Seantoobs Well-Known Member
    2011 4x4 Tundra and 1985 Toyota Extra cab
    5100's on Tundra and the Whole enchilada with extra guac on the 85
    Oh shit!! Good luck on the recovery
  15. Nov 7, 2014 at 3:17 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Cameron Steele and the Desert Assassins presents...
    4 showings on CBS Sports Network (Direct TV Ch. 221 in California, check your cable or satellite TV service for your channel):
    SUN. NOV. 9 @ 4 PM PST
    SUN. NOV. 9 @ 11 PM PST
    TUE. NOV. 11 @ 1 AM PST
    SUN. NOV. 16 @ 12 PM (NOON)
    Enjoy Baja on TV: scenery, supporting the orphanages, off road travel, the old Spanish missions and more!
    I have no idea how much I am in this, but Cameron said I made the cut. As you recall from last June, when I was invited to come along for 3 days of their week + tour of the missions and off road trails, Cameron Steele had me provide some history of the missions in person at two of the missions (Santo Domingo and El Rosario).
    There were about 50 people on the tour driving Ford Raptors, Toyota Tundra, Jeep Wrangler, Ford, and Dodge trucks... plus the chow trailer and helicopter.
    It was a fun 3 days for me with a bunch of great people.
    Me when the cameras were rolling at Mission Santo Domingo...
  16. Nov 7, 2014 at 3:34 PM
    MadTaco461
    CA
    Kinda stock
    That is pretty awesome. I remember you talking about doing that trip
  17. Nov 7, 2014 at 3:46 PM
    David K
    Let's see how silly I sound or look on national TV! LOL :D:rolleyes:
  18. Nov 7, 2014 at 4:51 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Just looked it up, if you have Time Warner its channel 315 at 4pm on the 9th. Recorded
  19. Nov 7, 2014 at 7:02 PM
    David K
    Thank you!
    If any COX or DISH TV people could check the correct channel, I will tell my friends!
  20. Nov 8, 2014 at 10:40 AM
    David K
    Do you call me that? LOL... What about Mr. Baja or Señor Baja ?? LOL
    You can just call me Dave or David, that is fine... On Baja Nomad (where everyone loves Baja) they sometimes call me DK (if not worse things, lol).
