San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Dec 26, 2014 at 12:11 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    No invite?
  2. Dec 26, 2014 at 12:45 PM
    TripleThreat
    TripleThreat Vance@freevancewriting.com
    They keep callin me cowboy but its not my name...
    Socal but I am still a southern Florida guy
    Toyota Tacoma 4x4 slightly modified
    nothing special.... wanna race?
    Ok let me know if you deceide to go we are doing to runs the main run is 11am cause people don't like to get up early and that meet is at the ranger station then we head out to fish creek, gas domes, elephant tree and other stuff.
    If you hav'nt gone through plaster city then join us we are getting breakfast at 7am at the antique row cafe then headed out to plaster ctiy to run to ocotillo wells but I made it separate cause people can't get up early haha
    Got you down on the list we got two mystery prerunners coming im excited :D
  3. Dec 26, 2014 at 2:27 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Yeah you will fail if all your sensors aren't checked in. That will reset the computer when the battery dies out. That sucks. Get a battery that holds a charge. When I got my truck I had to go to the smog shop 3 times before I passed.
  4. Dec 26, 2014 at 5:43 PM
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    2012 Tacoma TRD T|X Baja
    Pelfreybilt IFS Skid, Mid Skid and Plate Bumper, Rigid Industries Dually's, ARB CKMA12 On Board Air, Kenwood TM-281A Radio, Rear view mirror relocation bracket, Wheelers SuperBumps, Toytec Baja Spacer
    Had anyone wired in duallys or other aftermarket lights into the factory fog light switch? I'd like to install like that if possible. Not so good with electrical :)
  5. Dec 26, 2014 at 5:59 PM
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    I should have clarified I'm running Tyler's front bumper so no fog lights installed at the moment. Just need to wire up the duallys but want to use the factory switch. I found a thread on here a while ago but can't seem to find it again.
  6. Dec 26, 2014 at 6:03 PM
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Cut the factory fog light connector off. Turn on the fogs and test the two wires with a meter, test light or your tongue, whatever you got. Solder the hot one to the red and the other to the black. Done.
    Led fogs draw less amperage than factory so no need for additional relays or higher rate fuses etc. Just wire em up and yer good to go
  7. Dec 26, 2014 at 6:13 PM
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    LMFAO looks like I'm installing some lights then haha. Hope my tongue doesn't hate me. Thanks guys!
  8. Dec 26, 2014 at 7:18 PM
    zeekevin
    zeekevin Well-Known Member
    San Diego
    Maybe buy the plug adapter to make the lights plug n play.
    http://m.ebay.com/itm/111346402379
  9. Dec 26, 2014 at 7:21 PM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
  10. Dec 26, 2014 at 7:26 PM
    Speed Freek
    Looks like you about covered both, haha!
    After that check your scanner to make sure your ECU has enough data to test!
    Sometimes it can take even more mileage.
  11. Dec 26, 2014 at 8:17 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Wasn't too bad at all. Perfect weather.
    Last minute decision. Breakfast turned into a offroad trip lol
  12. Dec 26, 2014 at 9:29 PM
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    So got wiring and what not all taken care of and tested woo!! So bow I'm either super dumb or does the bumper have to come off for the lights to be installed?
  13. Dec 26, 2014 at 10:29 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
  14. Dec 26, 2014 at 10:32 PM
    David K
    Matt, I saw you drive into the complex this morning as I was leaving... Your truck looks like a Baja racer or pre-runner! Very cool... I only saw it from some distance (by mail boxes)... :cool:
  15. Dec 26, 2014 at 11:03 PM
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    Don't cut the connector. Get an h11 connector so you can always change them or remove them if you ever go back to stock for any reason. But yes the oem fog switch can handle duallys or d2s
  16. Dec 27, 2014 at 12:03 AM
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    Ya I snipped 1side but I can get the connector for the other aside otheotherside if you think it's worth it.
  17. Dec 27, 2014 at 12:12 AM
    csjumper2003
    Savannah, GA
    You can do it either way, but oem connectors are not cheap so snipping ain't cheap to fix if needed
  18. Dec 27, 2014 at 3:20 AM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Haha. I haven't seen you around in awhile Dave. Me and Nick are headed to Ocotillo Wells tomm and will becoming back early Sunday morning. You game?
  19. Dec 27, 2014 at 3:21 AM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    Will do Jason. Thanks
  20. Dec 27, 2014 at 11:13 AM
    Speed Freek
    I'll be there Sunday night thru the week but I assume you will be playing soldier. Pew, pew, pew!
    Lemme know if there is an extra .50 laying around that needs blowing out :rolleyes:
