San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. May 17, 2015 at 4:46 PM
    mercurymullet
    mercurymullet Well-Known Member
    gary
    el cajon/lakeside
    can't afford a toyota
    bronco frame under a mountaineer
    It seems to be firmer in the turns than the old setup. Might test it tomorrow. High of 83 in the des and it my bday!!
    Speed Freek[OP] likes this.
  2. May 17, 2015 at 7:05 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    We were just out there yesterday. Amazing weather. Happy Birthday!
  3. May 17, 2015 at 7:44 PM
    mercurymullet
    gary
    el cajon/lakeside
    Not much of a solo guy but think I'm gonna hit it super.
  4. May 17, 2015 at 8:17 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    Was a piece of cake. All 3/16 PNO plate, it's not going anywhere lol.
  5. May 18, 2015 at 9:07 AM
    Cali19k
    Cali19k Active Member
    SoCal/CO
    08 trd sport
    King RR front and rear, TC UCA, OME Dakar leafs, 33 General Grabber AT2
    Ya man I just looked at it, the front of the tires rub the fender in full turn. I'll contact you to see if we can plan some trimming.
  6. May 18, 2015 at 10:09 AM
    Sdtrueblue
    Sdtrueblue Well-Known Member
    Markie B
    San Diego, CA
    3G Tundra Limited (nothin’ but black)
    King 2.5's RSI Smartcap
    Hey guys, can any off-roaders who've done Split Mountain trail tell me if I can make it down the trail in a stock TRD Sport 2WD? I want to drive out to the wind caves and all the pics and vid's I've seen look like I can get down the trail to the caves without 4WD, but just wanted to ask someone's opinion before I tried it. I can certainly lower the tire pressure, but being stock - I only have street treds on.
    Thanks a lot!
  7. May 18, 2015 at 10:12 AM
    Seantoobs
    Seantoobs Well-Known Member
    2011 4x4 Tundra and 1985 Toyota Extra cab
    5100's on Tundra and the Whole enchilada with extra guac on the 85
    I've seen mini vans go to the wind caves. And ive taken my buddy in his 2wd tacoma out there. I think we did the whole split mountain trail.
    Wait im thinking of the mud caves
  8. May 18, 2015 at 10:40 AM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    No problem!
    You should be fine, just air down to 15psi and take it slow and it will be easy. Nothing terribly hard on that trail.
  9. May 18, 2015 at 11:27 AM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Check your inbox Sally.
  10. May 18, 2015 at 2:24 PM
    Sdtrueblue
    Markie B
    San Diego, CA
    As I hoped...great to know!!
    Thanks again.
  11. May 18, 2015 at 2:30 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Jason, I am sending you a couple questions to the new PM In-BOX here (hope it works!).
  12. May 18, 2015 at 8:44 PM
    iseeredandyellow
    iseeredandyellow I wanna go fast!
    Jeff
    San Diego
    10 DCSB 4wd OR Speedway Blue
    Anyone interested in going to the desert on Sunday if the weather doesn't suck?
  13. May 18, 2015 at 9:32 PM
    Speed Freek
    Got it! Replied, need to check a couple things to give a bid, may have to remove front subframe on that one.
  14. May 18, 2015 at 9:33 PM
    Speed Freek
    Roger that got it, I got you covered!
  15. May 19, 2015 at 11:17 AM
    jeffz0rz
    san diego
    You want the weather to suck lol. Little rain keeps the dust down, just stay out of the washes.
  16. May 19, 2015 at 2:08 PM
    Speed Freek
    Is there such thing as shitty desert weather under 90 degrees??
    Answer : ABSOLUTELY NOT!
  17. May 19, 2015 at 2:09 PM
    Speed Freek
    High flotation tires, problem solved, turns any rig into an Amphibitruck!
  18. May 19, 2015 at 3:53 PM
    iseeredandyellow
    Jeff
    San Diego
    I just don't want it to be hot!
  19. May 19, 2015 at 5:50 PM
    Speed Freek
    Should be under 90, I think you'll survive.
  20. May 19, 2015 at 6:19 PM
    iseeredandyellow
    Jeff
    San Diego
    Perfect weather! Anybody else interested?
