San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Dec 11, 2015 at 10:23 AM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    4WD and 2WD 2nd gen spindles are the same except the hubs
    jeffz0rz[QUOTED] and 14489 like this.
  2. Dec 11, 2015 at 10:49 AM
    zeekevin
    zeekevin Well-Known Member
    San Diego
    Yep, I was going to have some tc gussets welded on.... But in this case maybe not anymore, hit me up
  3. Dec 11, 2015 at 3:15 PM
    boopie
    boopie 05trdoffroad
    Ramon
    San Diego
    05trdoffroad
    Toytec/Eibach Bilstein set at .85, URD TCAI , TRD catback exhaust,1.5" AAL
    2nd in line for some spindle gussets made by JTA
  4. Dec 11, 2015 at 3:28 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    I can make you some spindle gussets, but I'm looking to make a fully fabricated spindle to be used as a stock replacement spindle retaining stock geometry and parameters since guys are bending their spindles even with the gussets.
  5. Dec 11, 2015 at 3:34 PM
    zeekevin
    San Diego
    sign me up lol
    jeffz0rz[QUOTED] likes this.
  6. Dec 12, 2015 at 4:49 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Says the "suburban offroader!" Those water mains and fence stakes just pop up out of nowhere right?
    I kid I kid.
  7. Dec 13, 2015 at 4:08 PM
    zeekevin
    San Diego
    lol dont want to bend a spindle plowing thru speed bumps, dips and curbs
  8. Dec 13, 2015 at 7:27 PM
    jeffz0rz
    san diego
    Speaking of spindles, you mentioned you have a set lying around ?
  9. Dec 13, 2015 at 7:30 PM
    zeekevin
    San Diego
    yep
  10. Dec 13, 2015 at 7:44 PM
    jeffz0rz
    san diego
    Cool deal. Are they drilled for uniball uppers by any chance ?
  11. Dec 13, 2015 at 7:46 PM
    zeekevin
    San Diego
    they are bone stock 2nd gen spindles i picked off a east county bro that did a 6in drop bracket lift and a 3in body lift lol.
  12. Dec 13, 2015 at 7:50 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    On a second gen all of the uniball uppers utilize a lower mis alignment spacer that has the same taper of the OE spindle BJ hole. Same with the second gen lower control arms with uni balls they also use a mis alignment spacer with taper to fit the OE BJ adapter hole. image.jpg
    nfs257 likes this.
  13. Dec 14, 2015 at 8:17 AM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    They dont need to be drilled, they come with a taper adapter like shown above, just slides right into the uniball and bolts up. You can use a ream and a checker in order to get the taper right when you make them. Funny you are doing that I was just thinking about making something too after all the gussets I have been doing lately, and even like you said the gusseted ones will still bend.
  14. Dec 14, 2015 at 9:06 AM
    jeffz0rz
    san diego
    Still bending. I'm having some bungs machined as well as blocks that will retain the wheel speed sensor. Hopefully by the end of this week I'll be putting together a set. Double shear steering as well, because why not? That way you have the option of upgrading to heimed steering.
  15. Dec 14, 2015 at 10:17 AM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    How are you going to double shear the steering using the stock ball joint?
  16. Dec 14, 2015 at 10:54 AM
    jeffz0rz
    san diego
    I am actually only going to make these for double shear to use a heimed outer. If you're going to spend the money on a fully fabricated spindle, you can spend literally a few dollars extra and get rid of your stock tie rod ends.
    nfs257 likes this.
  17. Dec 16, 2015 at 7:47 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Poor taco
  18. Dec 16, 2015 at 7:59 AM
    jeffz0rz
    san diego
    Probably was going to put tow mirrors on it, 3" spacers and 60" light bars over the windshield. This was at least an honorable death.
  19. Dec 16, 2015 at 10:50 AM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Anybody want a beer fridge? I have a full size fridge covered in stickers that needs to go this weekend. Located in Carlsbad.
  20. Dec 16, 2015 at 10:52 AM
    nfs257
    DFW
    She gone
    When you want to grab the tool box?
