San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Mar 9, 2016 at 5:59 PM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Might be cheaper to get a used wheel.
    SKULLY likes this.
  2. Mar 9, 2016 at 6:07 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I had a friend have that happen to their car. They just got new rims. Depends on how expensive those wheels are and if they have much curb rash.
    SKULLY likes this.
  3. Mar 9, 2016 at 6:36 PM
    bobs619
    bobs619 Well-Known Member
    Bobs
    San Diego
    Trd sport 2016 dcsb bbp
    TE37, BFG KO2, Weather Tech Mats, Wet Okole Seat Covers
  4. Mar 9, 2016 at 9:10 PM
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    Here is what I will be going to. 2005 Chevy 2005 with a LLY Duramax, Allison trans, 4wd and the short bed that I wanted with 150k miles on it. It's got some brand of 3" lift with brand new bilstein 5100s, BFGs on ProComp wheels. I will be starting a new build so please follow along. Have some mods planned already but nothing too crazy.
    07f93602ca538dafe818b3cdaaec37e4_zpsqbwu_453c16cb65828f9b5891d165a214c35853bdd22a.jpg
    e622e9d1ae3a3557eb3579411bb3321a_zps4l7j_3f2e2e71a85d9cf26435c8490e5ae794767103d1.jpg
    0ccdcd203c4c305c6185178d3c369441_zpsp7bc_360b6a88b7b3a5c9122066bb80d729227497bf80.jpg
  5. Mar 10, 2016 at 8:46 AM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Just leave it alone!
  6. Mar 10, 2016 at 9:20 AM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Probably going to need a new wheel, Im assuming its an aluminum wheel thats been chromed, the electrolysis is horrible on those things. My neighbor repaired his multiple times without success, always came back and started leaking again...
    SKULLY[QUOTED] likes this.
  7. Mar 10, 2016 at 1:40 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    Free 1st gen toyota bed liner. Only a small cut out at the top on the passengerside. Still 100% good to go. El cajon. Come get it or im cutting it up.
  8. Mar 10, 2016 at 8:08 PM
    noSKills858
    Alex
    Poway, CA
    If you come up on a 2rz oil pan I'll take it.
  9. Mar 11, 2016 at 6:58 AM
    jeffz0rz
    san diego
    Just sold my motor, computer, and all accessories for 300 bucks. I still have my transmission I'm trying to get rid of
  10. Mar 11, 2016 at 9:15 AM
    noSKills858
    Alex
    Poway, CA
    I might need it when mine explodes haha.
  11. Mar 11, 2016 at 9:31 AM
    jeffz0rz
    san diego
    $100 and it's yours. It's just in the way. Have a clutch with it too that has hardly any miles on it.
  12. Mar 11, 2016 at 10:20 AM
    Mcdees84
    Mcdees84 Well-Known Member
    Tallahassee, FL
    2014 MGM DCSB-TRD O/R
    Hey guys,
    I recently installed a dash cam and I wired it with a fuse tap so it comes on with the ignition. Everything is working fine (turns on and shuts off when I turn truck on/off and records fine), but now my HD radio channels aren't coming in HD anymore. I imagine it's interference of some sort, but can't figure out why it would affect that or what to do to fix it.
    Originally I fuse tapped into the "ACC" fuse. Then tried the "IGN" fuse to see if it would make a difference. Then tried the "WSH" fuse also. All three caused the same interference. I even stepped the fuse down to 3amp thinking maybe less power draw would stop the interference. Didn't work. If I unplug the dash cam, HD radio signal comes back immediately.
    Any thoughts?
  13. Mar 11, 2016 at 1:49 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Maybe where the wires are ran? Is it close to the antenna wire behind the radio?
    MadTaco461 likes this.
  14. Mar 11, 2016 at 3:30 PM
    MadTaco461
    CA
    Kinda stock
    Emi? Try a ferrite ring or shield your wires. Radio rf is probably the issue. I doubt you are having a current draw issue.
  15. Mar 11, 2016 at 3:40 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    :tinfoilhat:
  16. Mar 12, 2016 at 1:19 PM
    Speed Freek
    I am willing to bet thats it as well. try rerouting the wire so that its not near other wiring if thats possible or for a short term test wrap some foil around the areas of wire that DO come close together.
  17. Mar 12, 2016 at 1:21 PM
    Speed Freek
    Hey, random question, does anyone know if Ryan (the Original OP of this thread) got banned?? All his posts are completely vaporized!!
  18. Mar 12, 2016 at 1:24 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
  19. Mar 12, 2016 at 1:35 PM
    Speed Freek
  20. Mar 12, 2016 at 2:00 PM
    noSKills858
    Alex
    Poway, CA
    I thought he was banned for a while but maybe I'm thinking of someone else.
