San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Mar 17, 2016 at 9:18 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    JTA can probably build a set for you, if not I'm sure I can.
  2. Mar 18, 2016 at 2:48 AM
    gman2530
    gman2530 Well-Known Member
    San Diego, Ca.
    04 PreRunner
    I pulled the trigger on the ones from Ebay..
    Thank you for getting back to me...
  3. Mar 18, 2016 at 3:00 AM
    gman2530
    San Diego, Ca.
    04 PreRunner
  4. Mar 18, 2016 at 7:18 AM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    Free bedliner 1st gen 6' bed. I'm cutting it up if nobody wants it.
  5. Mar 18, 2016 at 10:08 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Curious do those off the self steering clevis bolt up to the 5 lug rack or you gotta make them?
  6. Mar 18, 2016 at 12:53 PM
    noSKills858
    Alex
    Poway, CA
    They use a 12mm allen bolt which threads into the rack.
    Do you still have a header for your 2rz? I'm getting rid of the turbo setup and going back to stock.
  7. Mar 18, 2016 at 8:25 PM
    MadTaco461
    CA
    Kinda stock
    Thanks for the specs on the rack. I can't sell my headers. I like to keep all my emissions stuff in case I ever stock out.
  8. Mar 18, 2016 at 8:35 PM
    noSKills858
    Alex
    Poway, CA
    Damn, guess I'll just build some then.
  9. Mar 20, 2016 at 7:36 PM
    zeekevin
    zeekevin Well-Known Member
    San Diego
    anybody else need their seat belt chime disabled or key programmed? hit me up, I just did @bconrey the other day and he is a happy camper
  10. Mar 20, 2016 at 10:33 PM
    wsurunner
    wsurunner Well-Known Member
    2015 Pyrite Mica DCSB
    Yes - great guy and I appreciate the help. Props to @zeekevin!
  11. Mar 21, 2016 at 8:11 AM
    MadTaco461
    CA
    Kinda stock
    Base model ftmfw
  12. Mar 21, 2016 at 1:52 PM
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    Hey guys :wave: checking to see if anyone is traveling to az anytime and willing to bring a rim with them. Appreciate it. Thanks
  13. Mar 21, 2016 at 3:18 PM
    noSKills858
    Alex
    Poway, CA
    Dammit. Can't find a used 2RZ header.
  14. Mar 22, 2016 at 8:58 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Hey guys, what is the name of the north county alignment shop that some folks have had good luck with ? I think @David K used them recently after @Speed Freek installed his lift ?
  15. Mar 22, 2016 at 7:39 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I know a great alignment tech in El cajon, if it helps you.
  16. Mar 22, 2016 at 8:25 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    I've used True Line twice and not had much luck with driving away with a straight steering wheel...
  17. Mar 22, 2016 at 8:28 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Any of you guys want 12 open ended Lugnuts for the stock Tacoma lugs?
  18. Mar 22, 2016 at 9:36 PM
    Crom
    Nick
    San Diego, CA
    Millions
    I have lifetime alignment from Firestone. I've been to the La Mesa, Santee and El Cajon locations. The best tech I've encountered is a young man named Zach in El Cajon. He is meticulous and very detailed oriented.
    I tell him the numbers I want and he'll dial it in, come to me and verify, then torque everything to spec. I've always been very happy with his work and I let the manager there know every time.
    At the Santee location there is another young tech who was also very good, but don't recall his name.
    nfs257 likes this.
  19. Mar 22, 2016 at 10:49 PM
    zeekevin
    San Diego
    What numbers are you requesting for your alignment specs?
  20. Mar 23, 2016 at 6:25 AM
    Crom
    Nick
    San Diego, CA
    Millions
    0 toe
    0 camber
    2.5-3 caster
    I also want the numbers to be nearly identical on both sides and SAI to match.
    That's what makes a good tech.
    The techs who see green and torque shit are the ones that give your truck back in spec, but with a pull, or steering wheel not centered etc.
    Drainbung likes this.
