San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. May 26, 2016 at 11:53 AM
    Sdtrueblue
    Sdtrueblue Well-Known Member
    Markie B
    San Diego, CA
    3G Tundra Limited (always black)
    King 2.5's RSI Smartcap
    You mean, they frown upon that stuff? WTH?
    :facepalm:
  2. May 26, 2016 at 11:59 AM
    Shennanigans
    Shennanigans Well-Known Member
    Eric
    2001 TRD prerunner sr5 rwd
    none.... yet
    I think its just cause I'm relatively new, my coworkers do it all the time
  3. May 26, 2016 at 2:45 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Post pics of the frays? As long as the mantle is in tact it should be fine. If you get any core shots its time to retire
  4. May 26, 2016 at 3:15 PM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Yeah it's a pretty popular place to hike from the poway side and climb from the ramona side. Hoping to get out there early to avoid crowds...
    Huh, not familiar with Bonita. Might have to check it out once I get better.
    Yeah Tech 9 and the one to the right of it, borderline, are my favorite single-pitch climbs so far. I think we messed up on tech 9 and ended up doing street sweeper, the 11d right next to it...but it also kinda looks like there's a missing flake that would've made the climb a lot easier so maybe it was tech 9 and the rating is from when the flake was there. Tech 9 was harder than borderline, but borderline was longer.
    This. I've got a few little frays as well but nothing through the sheath. My rope is just old (like 6 or 7 years now) and it's had a couple good falls on it so it's about time even though it's only been seeing use about 6-7 days a year.
  5. May 26, 2016 at 4:26 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Anyone know of a person or shop in SD that can do a smog for my tacoma with an intake? :spy:
  6. May 26, 2016 at 5:11 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Or if anyone has a factory intake laying around that I could borrow or rent for the day, that would be awesome!
  7. May 26, 2016 at 5:44 PM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Option #2 is your best bet...but I dont have one unfortunately.
    eccracer104[QUOTED] likes this.
  8. May 26, 2016 at 5:55 PM
    Shennanigans
    Eric
    none.... yet
    will tundra 5100s bolt in? I found some, and need to do something about my blown struts but I'm hoping to be able to afford long travel within a few months
  9. May 26, 2016 at 5:57 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Yeah, that'll be only solution so I don't have to worry about it next smog haha
  10. May 26, 2016 at 6:01 PM
    Speed Freek
    I know the top hats are different, I doubt it..
  11. May 26, 2016 at 6:05 PM
    Shennanigans
    Eric
    none.... yet
    I've seen threads where people talk about it, as if they have it, but not how they did it.
    its just the shocks, I'd be using everything else off my tacoma
    this is all first gen stuff, by the way
  12. May 26, 2016 at 7:17 PM
    bcbailey25
    bcbailey25 Well-Known Member
    Ian
    Oceanside
    08 PreRunner Sport
    5100s, 4" spindles, 2" AAL, 285/75/16 KO2s, Level 8 MK6s
    I need mine done. Just waiting on parts the lady said. Does anyone know if i have to take my AAL out first?
  13. May 26, 2016 at 7:26 PM
    Speed Freek
    Maybe it does then I might have a set of both to compare but the Tacoma uses a 3 bolt hat and the Tundra a 4 bolt they look similar other than that I will look and see if I have some to compare. I've never tried to swap between the two.
  14. May 26, 2016 at 7:37 PM
    Shennanigans
    Eric
    none.... yet
    not at home anymore but i had a comparison picture. struts are the same other than the bottom mounting thing (whos name i cant think of right now) being bigger and therefore stronger on the tundra
  15. May 26, 2016 at 8:00 PM
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    I want to learn how to climb like you pros...what's up Kevin!
    Byb127 likes this.
  16. May 27, 2016 at 12:19 AM
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    There have been a few, they pretty much fell flat immediately. Maybe thatll change now though!
    Byb127 likes this.
  17. May 27, 2016 at 9:08 AM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    Any drive cam guys here? I need 3 of them. Looking for first had experience.
  18. May 27, 2016 at 11:51 AM
    jeffz0rz
    san diego
    Anyone know someone with a plasma table ? I need a few plates cut and mine is down.
  19. May 27, 2016 at 8:01 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Nope, he'll swap it out for you. Just tell them to take note of it.
    bcbailey25[QUOTED] likes this.
  20. May 27, 2016 at 8:42 PM
    Shennanigans
    Eric
    none.... yet
    i bought and installed them today. worked fine no modifications needed. Supposedly a stiffer ride but im used to my slammed 300zx on stiff coilovers so i hope its super stiff lol
