San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Jun 19, 2016 at 5:04 PM
    lockwire24
    lockwire24 Well-Known Member
    Mark
    Vancouver
    2012 MG DBL cab LB TRD sport
    Cobra CB, Firestik II w/ Relentless hood mount, 4x Innovation sliders, Level 8 tracker pro, TRD exhaust, home made grill insert, Leer XR, led bed lights, King shocks, LR uca, Pelfreybuilt front/rear bumpers and skid plates, B.A.M.F. rear shock relocate.
    The police saying the kia is at fault.
  2. Jun 20, 2016 at 8:17 AM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Oh man!! That sucks but hopefully insurance will have a shiny new bumper on there for ya! And damn that KIA, it was actually KIA'd!
    Any airbag deployment on your end??
  3. Jun 20, 2016 at 9:43 AM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    It doesn't even look like anything is wrong with his bumper though :notsure:
  4. Jun 20, 2016 at 10:25 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I would be cautious with that, my front plate bumper got hit last year and unfortunately what they say about them being a damage multiplier proved to be true. At first it appeared that only the point of impact was a bit bent but when I went to pop my hood the hood did not pop up and it was rubbing the latch unlike it ever had before...log story short version - the whole front end was slightly tweaked and had to pulled on a frame machine.
    Crom and deadhed61[QUOTED] like this.
  5. Jun 20, 2016 at 10:35 AM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    I was just saying the bumper doesn't look to have taken any damage aside from the scratches....since it's not his fault a frame check on the Kia owner shouldn't be a problem :)
  6. Jun 20, 2016 at 4:33 PM
    lockwire24
    Mark
    Vancouver
    I have to wait until later this week to verify if there was any other damage. And no the air bag didn't deploy. We weren't going that fast.
  7. Jun 20, 2016 at 8:15 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Kia looked like it was hauling ass with that much damage!
  8. Jun 20, 2016 at 11:09 PM
    Spvrtan
    Spvrtan "Your assembly required."
    Kris
    San Diego (North County)
    SC'd '14 Tundra; 5.5" lift w/ +2.5 LT; 40s on 17s; 4.88s
    Probably an obvious answer but if I regear my rear and leave my front at the stock ratios (to regear in the future to match the rear) then I should be fine (ie. not worry about breaking transmission/transfer) as long as I don't engage 4x4 mode and stay in 4x2, right?
    Edit: I'd basically be running 4.30 up front and 4.88 at the rear with an optionable ARB locker. I'm thinking the only time I may be safe-ish running 4x4 is in the sand or loose gravel but definitely not on pavement or hard rocks where gripping is required.
  9. Jun 20, 2016 at 11:33 PM
    wsurunner
    wsurunner Well-Known Member
    2015 Pyrite Mica DCSB
    I'd disconnect/remove the front driveshaft to prevent the possibility of creating an issue, but maybe that's just me and my old-school thinking. I wouldn't risk re-gearing the rear without also addressing the front given the choice. I wouldn't give up 4wd just to get better gearing (let me know if you disagree - we can swap your parts with my prerunner!)
    nfs257 likes this.
  10. Jun 20, 2016 at 11:33 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    I wouldn't engage 4x at all if the gears don't match. What happens if that sand has grip somewhere in it?
    4WD likes this.
  11. Jun 20, 2016 at 11:41 PM
    Spvrtan
    Kris
    I was just going to disconnect the fuse from the panel that powers the switch to engage 4x4; I'd think that'd be simpler. Yea, given the choice, I wouldn't either. However, for the sake of cost, time, and convenience I may have to regear the rear and wait a few weeks or months until regearing the front -- I'd just have to limit my offroading to 4x2 and brute-forcing my way through climbs without the front engaged.
    I think I'd only risk it if I really needed to and only in the softest of sand.. like out in Glamis and needing to engage the front to get unstuck from a pretty bad hole (of course, that's assuming my traction pads that I'd go to first break).
    nfs257[QUOTED] likes this.
  12. Jun 21, 2016 at 7:12 AM
    wsurunner
    Yes, that may work as well (I'm used to mechanical xfer cases, pulling a fuse didn't occur to me).
  13. Jun 21, 2016 at 8:07 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    That will work. No need to pull the shaft
  14. Jun 21, 2016 at 5:18 PM
    noSKills858
    Alex
    Poway, CA
    Plus, you never know when you might need to drive home on front wheel drive.
    4WD likes this.
  15. Jun 21, 2016 at 6:34 PM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Is buying them separately, waiting until you have both, and installing together an option? :notsure:
    Drainbung likes this.
  16. Jun 21, 2016 at 11:26 PM
    Spvrtan
    Kris
    It is but I was thinking of going to Jason (Speed Freek) to get my rear done since he has done it and said he could help out but also wouldn't be able to do the front (so I'd have to go to a shop for that on another occasion).
    Speed Freek[OP] likes this.
  17. Jun 22, 2016 at 8:31 AM
    Speed Freek
    Yeah I am not experienced with the front clamshell type, in reality I could probably do it but dont want to use anybody besides myself as a guinea pig, lol.
    I still think the ECGS front exchange is the best idea for that, then do an ARB on the rear and I can do all of that at once (including the front swap)
    And if you regear the rear and its different than the front its like riding a dolphin! You will be doing the buck and jerk dance, lol. It would be undriveable unless in super deep sand and even then it might want to bounce.
    This is first hand knowledge, I have been in a truck with different gearing and it was almost comical trying to drive! I drove it in dirt (not sand) and it was like I had entered a Rodeo but forgot my hat and boots.
    4WD, Crom and MadTaco461 like this.
  18. Jun 22, 2016 at 12:20 PM
    noSKills858
    Alex
    Poway, CA
    Yeeehaw!
    4WD likes this.
  19. Jun 22, 2016 at 6:00 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    July 13th is the off road madness car show in El Cajon. Who is going?
  20. Jun 23, 2016 at 1:00 AM
    nfs257
    DFW
    She gone
    Anybody have the stock rear axle breather that I can have? It would be the one you replace when doing the breather mod.
